Administrators Andrew Reid Posted August 9, 2017 Administrators Share Posted August 9, 2017 I recently decided to find out which of the current 1080/120fps capable cameras does it the best. Read the full article dahlfors, Inazuma, Eno and 2 others 5 Link to comment Share on other sites More sharing options...
thecouchguy Posted August 9, 2017 Share Posted August 9, 2017 Very good test, thank you for doing this mate. A valuable resource for anyone shopping for these cameras. Andrew Reid 1 Link to comment Share on other sites More sharing options...
Eno Posted August 9, 2017 Share Posted August 9, 2017 Thank you very much for the slow motion comparison test @Andrew Reid! Andrew Reid 1 Link to comment Share on other sites More sharing options...
Oliver Daniel Posted August 9, 2017 Share Posted August 9, 2017 There's a plugin that gives some kind of resolution voodoo which I use for 120fps clips. It's called Finisher. (also known as Crumplepop Finisher). The plugin dramatically increases the perceived resolution with clever sharpening. I've found it doesn't work too well on Canon DSLR's, but is awesome for Panasonic and Sony. Andrew Reid 1 Link to comment Share on other sites More sharing options...
Super Members BTM_Pix Posted August 9, 2017 Super Members Share Posted August 9, 2017 I'll second that about Finisher. I like the simplicity of CrumplePop's stuff Oliver Daniel 1 Link to comment Share on other sites More sharing options...
rdouthit Posted August 9, 2017 Share Posted August 9, 2017 Note that you can conform 120p to 24/30p internally with the A7SII and the A99II. Link to comment Share on other sites More sharing options...
gt3rs Posted August 9, 2017 Share Posted August 9, 2017 Thx for the test and after using quite a bit the 1Dx II in 120 fps I agree with you that is definitely not the strong point of the camera... usable but not great. The difference in quality between 4k 60p and 1080p 120fps is huge. Link to comment Share on other sites More sharing options...
anax276 Posted August 9, 2017 Share Posted August 9, 2017 Thanks for the great overview. By the way, how do I set the 120 fps VFR on the GH5? I can only select 100, 125, 150, 175, 180 fps. Link to comment Share on other sites More sharing options...
Deadcode Posted August 9, 2017 Share Posted August 9, 2017 Thank you for the test, very informative. Did any of you noticed that the 1Dx Mark II's motion "candence" seem like it's much more fluid than the others? It's like 30p. Link to comment Share on other sites More sharing options...
jcs Posted August 9, 2017 Share Posted August 9, 2017 4 hours ago, Oliver Daniel said: There's a plugin that gives some kind of resolution voodoo which I use for 120fps clips. It's called Finisher. (also known as Crumplepop Finisher). The plugin dramatically increases the perceived resolution with clever sharpening. I've found it doesn't work too well on Canon DSLR's, but is awesome for Panasonic and Sony. Looks like a combination of unsharp mask with a normal radius (somewhat small) and LCE (local contrast enhancement), which uses unsharp mask with a very large radius (e.g. 300). It's too bad PP CC doesn't GPU accelerate unsharp masking, however it is possible to achieve the effect with GPU acceleration by copying the video track, blurring it (Gaussian blur: 300), scaling the original (ProcAmp: Contrast & Saturation: 200) and subtracting the Gaussian blurred copy (Blend: Subtract). I've been using 1DX II 1080p24 to get full frame shallow DOF and smaller files with nice results (sharpen around 50 in Lumetri/Creative in PP CC). Along with a little bit of fine noise grain, sharpening 1DX II along with LCE can look very filmic, even with the initially soft 120fps 1DX II 1080p. Regarding Andrew's tests: every one of those 120fps cameras produce acceptable results. Was surprised to see the Alexa and Phantom missing though Link to comment Share on other sites More sharing options...
jcs Posted August 9, 2017 Share Posted August 9, 2017 This will work with all cameras, especially the soft-ish Canon 1080p To fix aliasing we need Super Resolution , which uses aliasing information to create new, real detail (not trivial, but perhaps will be available someday). Link to comment Share on other sites More sharing options...
OliKMIA Posted August 9, 2017 Share Posted August 9, 2017 3 hours ago, anax276 said: By the way, how do I set the 120 fps VFR on the GH5? I can only select 100, 125, 150, 175, 180 fps. Check your FPS settings: PAL, NTSC, Cine. For 120 I believe you must set it to 24p Link to comment Share on other sites More sharing options...
anax276 Posted August 10, 2017 Share Posted August 10, 2017 8 hours ago, OliKMIA said: Check your FPS settings: PAL, NTSC, Cine. For 120 I believe you must set it to 24p OK, thanks! That must be the reason, I had 25 fps... Link to comment Share on other sites More sharing options...
Michael Rivers Posted August 10, 2017 Share Posted August 10, 2017 I assume you are testing the Leica SL with firmware 3.0? I find that L log seems to work a bit better in camera (although I really save it for an external recorder). Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted August 10, 2017 Author Administrators Share Posted August 10, 2017 Yes Leica SL is running V3.0 firmware. I think the 4K is excellent (not yet tried 10bit 4K via HDMI) but the compressed 8bit 1080p combined with the flatness and high black level of L-LOG = banding hell! Link to comment Share on other sites More sharing options...
OliKMIA Posted August 10, 2017 Share Posted August 10, 2017 9 hours ago, Andrew Reid said: Yes Leica SL is running V3.0 firmware. I think the 4K is excellent (not yet tried 10bit 4K via HDMI) but the compressed 8bit 1080p combined with the flatness and high black level of L-LOG = banding hell! Hi Andrew. Did you receive my email with a publication request for this article ? Let me know. Thanks Link to comment Share on other sites More sharing options...
ND64 Posted August 11, 2017 Share Posted August 11, 2017 Another proof that binning is not the problem, processing is. Link to comment Share on other sites More sharing options...
Trek of Joy Posted August 11, 2017 Share Posted August 11, 2017 Nice test Andrew, thanks for putting this together! Link to comment Share on other sites More sharing options...
funkyou86 Posted August 11, 2017 Share Posted August 11, 2017 This was my very first time shooting 180fps with the GH5. I was too affraid that the image will be soft, but now, I'm good with it. It is soft, but for youtube, still above average :D Please do not laugh loudly, we did our best to do something stupid (PS: there are english lyrics, just wait for it). sgreszcz 1 Link to comment Share on other sites More sharing options...
Laser Blue Posted August 11, 2017 Share Posted August 11, 2017 Andrew, Thank you for the test! It's my understanding that aliasing or softened detail can be made worse by smaller bitrates. Would the 120 fps image improve on the NX1 with a bitrate increase to say 160mbps from the standard 80? 96 fps on the GH4 lost detail relative to 60 fps at the same bitrate. Thoughts? Link to comment Share on other sites More sharing options...
