GH4, variable ND recomendation
Clayton Moore
If you want the one of the best then Heliopan Vario-Graufilter.
Heliopan Vario-Graufilter type 2099 is thicker with front filter thread and type 2199 is a slim type and thinner without front filter threads.
In Europe Helopan 2099 Vario-Graufilter 77mm costs about 200€.
Me and my partner are looking to buy a permanent solution for our ND's, and we've done a lot of research on the internet which one to buy. It allways comes down to heliopan.
You do not wan't to go cheap on these filters, trust me :)
Cheers!
I second the Heliopans! No discernable loss in sharpness and no colour shift. I had the Lightcraft Workshop ones before. They're... okay, but the Heliopans are worth every penny.
I film weddings so need them on/off very quickly and also cannot recommend the Xume magnetic adapters enough too if you require speed. Although go for a larger ND and use step up rings to avoid vignetting.
Cheers, James
