richg101 Posted August 20, 2012 Share Posted August 20, 2012 https://vimeo.com/15689248 not a flare in sight. but no normal lens could create this look. the culprit??? The Iscorama 54 mammoth. God I want one of these! Link to comment Share on other sites More sharing options...
QuickHitRecord Posted August 20, 2012 Share Posted August 20, 2012 This is stunning footage. No flares necessary. I like this more than anything that I have seen from the Iscorama 36. Thanks for the share. Link to comment Share on other sites More sharing options...
richg101 Posted August 20, 2012 Author Share Posted August 20, 2012 [quote name='QuickHitRecord' timestamp='1345489015' post='16090'] I like this more than anything that I have seen from the Iscorama 36. Thanks for the share. [/quote] My thoughts exactly. It is simply the best dslr+'non modern cinema standard' anamorphic footage I have seen. If anything some of the nicest footage I have seen from the huge vimeo archive. And certainly the best 'test footage' of anamorphic out there. Link to comment Share on other sites More sharing options...
richg101 Posted August 20, 2012 Author Share Posted August 20, 2012 The wide shot is on a par with the quality of imagery in the first scene of Inglorious Basterds. its like a moving painting Link to comment Share on other sites More sharing options...
septemberdawn Posted August 23, 2012 Share Posted August 23, 2012 "Isco 54 attached to the Canon 50mm F1.4" (on a 7D possibly @ f/2.8) "Filmed at 1080 30p and slowed down to 24 in post. Grading was done in Photoshop CS4." Would the 'shot at 30p and slowed to 24p have much impact on the overall result? How would Photoshop be used as far as ''grading' is concerned? [i]still learning....appreciate the discussion, thanks for uploading the link to the clip.[/i] Link to comment Share on other sites More sharing options...
richg101 Posted August 23, 2012 Author Share Posted August 23, 2012 You can import up to 15 seconds of jpegs into photoshop within the 'animation' mode. Opening up the amazing power of image post processing within photoshop. far superior to most other grading techniques. the rgb curves in photoshop seems nicer to use than those in premiere. the change from 30p to 24p will have a slight smoothing result to the footage without making it look very 'slow-mo'. it adds a degree of weight to some types of footage. Check out footage from the OM-D, shot at 30p and changed to 24p. when you add the amazing image stabilisation into the equation the footage looks really amazing. Link to comment Share on other sites More sharing options...
