craigbuckley Posted October 6, 2012 Share Posted October 6, 2012 So I bought the 20mm pancake and the canon fd 50mm to go along with my gh2. Both are pretty good, but I feel like the shots are stil not wide enough, can anyone suggest a wider lens for the gh2 ( I have adapter for FD), that won't be crazy in price. Also, is there another lens I should be going with to accompany the 20mm and the 50mm, other lens that I should be acquiring? Link to comment Share on other sites More sharing options...
Mirrorkisser Posted October 6, 2012 Share Posted October 6, 2012 get the panasonic 14mm f2.5, that is the cheapest wide lens available for the gh2. Besides you might want to consider the canon fd 35mm f2 and the 85mm 1.8. craigbuckley 1 Link to comment Share on other sites More sharing options...
Jon de Zwaan Posted October 6, 2012 Share Posted October 6, 2012 A fast wide-angle prime is the SLR Magic Hyperprime 12mm f1.6. It's not that cheap, but very fast and wide. I suppose you already have the kitlens? It starts at 14mm, so if that's wide enough for you and you just need a faster lens, the panny 14mm f2.5 will suit you fine. craigbuckley 1 Link to comment Share on other sites More sharing options...
craigbuckley Posted October 6, 2012 Author Share Posted October 6, 2012 I dont have the kit lens, i just got the 20mm pancake with the gh2 body. Would it be stupid to have the 20mm and the 14mm pancake? And I think I would go maybe for a little higher quality than the 14mm panny, just based on my research with its bad low light. Any other suggestions? HOw do the 14mm panny and the Rokinon 14mm compare? THe panny is 300 dollars cheaper on ebay, and has f.2.5 compared to the rokinon f.2.8.. Thanks again. Link to comment Share on other sites More sharing options...
sanveer Posted October 6, 2012 Share Posted October 6, 2012 [quote name='craigbuckley' timestamp='1349542791' post='19444'] I dont have the kit lens, i just got the 20mm pancake with the gh2 body. Would it be stupid to have the 20mm and the 14mm pancake? And I think I would go maybe for a little higher quality than the 14mm panny, just based on my research with its bad low light. Any other suggestions? HOw do the 14mm panny and the Rokinon 14mm compare? THe panny is 300 dollars cheaper on ebay, and has f.2.5 compared to the rokinon f.2.8.. Thanks again. [/quote] If you already have the 20mm f1.7, get a fast 50mm Nikon or Canon (from ebay), with an adaptor. It will be cheap and the optics are quite good. Link to comment Share on other sites More sharing options...
craigbuckley Posted October 6, 2012 Author Share Posted October 6, 2012 I have the canon fd 50mm I just wanted a wider lens than the 20mm pancake,but not a fish eye.. Link to comment Share on other sites More sharing options...
sanveer Posted October 6, 2012 Share Posted October 6, 2012 Try the SLR Magic HyperPrime Cine 12mm T/1.6 Lens for Micro Four Thirds. Andrew (Reid) has shot some gr8 footage with it, which you could check out. The Olympus M. Zuiko Digital ED 12mm f/2.0 is also a gr8 lens (though more expensive). craigbuckley 1 Link to comment Share on other sites More sharing options...
Axel Posted October 6, 2012 Share Posted October 6, 2012 I have the Oly 12. As with all system lenses, it is clean and sharp, but has no cinematic magic. I bought it for steadicam shots, because the AF is quite good. Before I had the Oly 9-18, same thing, but way too slow. The 12 mm turned out to be a good compromise, but I am determined to buy the SLR magic additionally. There are other options of course, but adapted Canon lenses (for example) are often quite big and heavy, I prefer MFT for the wider angles. Link to comment Share on other sites More sharing options...
craigbuckley Posted October 6, 2012 Author Share Posted October 6, 2012 well my range is only 400 dollars, so between the 14mm and the rokinon 14mm, which would be a better investment? The big turn off with the panasonic is its so small so its hard to focus while I am shooting video Link to comment Share on other sites More sharing options...
Jon de Zwaan Posted October 6, 2012 Share Posted October 6, 2012 Search both lenses on vimeo, like "Panasonic 14mm gh2" and "Rokinon 14mm gh2" (you can replace rokinon with samyang, if you don't find any matches). Look at the images and decide which one of the two you like best. With the panny being faster, the Rokinon has an aperture ring (even clickless with the cine version), which could be an advantage over the panny with video. The rokinon is larger and you have to buy another adapter for it, Nikon or EF to m43. The rokinon also has no filter ring, only a mattebox will be an option for using filters. My two cents; If you're looking for a cinematic like image, go for the rokinon or the SLR magic. If you just want a cheap fast wideangle prime, buy the Panasonic. craigbuckley 1 Link to comment Share on other sites More sharing options...
craigbuckley Posted October 6, 2012 Author Share Posted October 6, 2012 Thanks, would I Need an adapter with the 12mm SLR magic on the gh2? Link to comment Share on other sites More sharing options...
Chrad Posted October 7, 2012 Share Posted October 7, 2012 No, it's a native Micro 4/3 lens. Link to comment Share on other sites More sharing options...
