Administrators Andrew Reid Posted December 1, 2012 Administrators Share Posted December 1, 2012 [url="http://www.eoshd.com/wp-content/uploads/2012/12/bmcc-rewo-1.jpg"][img]http://www.eoshd.com/wp-content/uploads/2012/12/bmcc-rewo-1-660x439.jpg[/img][/url] Above: ReWo caged Blackmagic Cinema Camera. Review of the cages for the BMCC is coming soon (click image to enlarge) [url="http://www.slashcam.de/artikel/Test/Blackmagic-Cinema-Camera---Teil-3--Die-Schattenseiten-und-unser-Fazit.html"]SlashCAM[/url] here in Berlin have been putting their expertise to work on the Blackmagic Cinema Camera. They also had the opportunity to compare their regular test shots with new shots from the Blackmagic. As you can see in the example after the break, the blacks are far cleaner in post than material shot on the Canon C300. SlashCAM have tested an enormous range of camcorders and cameras over the last 10 years. Here they've tested all the important aspects of the BMCC's performance in detail, such as rolling shutter, dynamic range, etc. nahua 1 Link to comment Share on other sites More sharing options...
Chris Santucci Posted December 1, 2012 Share Posted December 1, 2012 You can't compare the ludicrousness of a 2.3 crop factor with the C300. Sorry, you just can't. Link to comment Share on other sites More sharing options...
HurtinMinorKey Posted December 1, 2012 Share Posted December 1, 2012 If you notice, the new demos for the F55 use DaVici Resolve. It's. Where it's at for RAW. Link to comment Share on other sites More sharing options...
FilmMan Posted December 1, 2012 Share Posted December 1, 2012 The article mentions this camera. 2013 should be very interesting. [url="http://www.engadget.com/2012/06/29/worlds-smallest-4k-usb-3-0-camera/"]http://www.engadget.com/2012/06/29/worlds-smallest-4k-usb-3-0-camera/[/url] Link to comment Share on other sites More sharing options...
gene_can_sing Posted December 1, 2012 Share Posted December 1, 2012 You can't compare the ludicrousness of a 2.3 crop factor with the C300. Sorry, you just can't.I am blown away by the image, but this statement is so true. The 2.3x crop factor is a huge draw back that very few BMC fans boys mention. 2 weeks ago, I shot a music video that took place primarily in a car. We had to use a Tokina 11-16 on an FS700. On the 16mm end, it was tough to fit both people in. With a 2.3x crop factor, it would have been impossible to get those shots. I'm not a wide angle shooter at all, in fact I generally prefer longer lenses. With that said, there have been numerous times where I had to pop on the Tokina 11-16 or else the shot just would not have worked because of crazy tight spaces. I think the real revolution will come when BMC comes out with the Super 35mm version with some higher frame rates. Then the S#!T will really hit the fan. But this camera is an great start. After using the FS700 with it's high frame rates which is amazing for projects like music videos, artistic pieces, B-Roll for docs and sports, I just cannot go back to a camera that only shoots 24fps, which is fine for narrative, but 24fps is just too limiting once you've had a taste of high frame rates and the amazing drama and sexiness that is created, especially when done correctly and not gratuitously. For me, I would gladly sacrifice some image IQ for a super 35mm or wider sensor and high frame rates. zephyrnoid 1 Link to comment Share on other sites More sharing options...
LorenzoS Posted December 1, 2012 Share Posted December 1, 2012 Crop factor, what? Oh please. Not a big deal at all. Better image quality than cameras that cost 3 times more = I'll cope; Andrew Reid 1 Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted December 1, 2012 Author Administrators Share Posted December 1, 2012 You can't compare the ludicrousness of a 2.3 crop factor with the C300. Sorry, you just can't. Look it really is time to nail this argument down so hard it can never get up again. By your logic Super 16mm which is a 2.7x crop is also ludicrous. OK but didn't stop The Queen, Black Swan and Moonrise Kingdom being made on it. They're some of the best looking films I've seen in the past 2 years if not THE best looking. Remind me of the advantages of a full frame sensor. So you can defocus everything apart from a tiny sliver of hair? Oh please... It looks rubbish. This is not cinema. In low light at fast apertures, my 5D Mark III makes focus unmanageable at close distances. You cannot shoot a film this way. Like I say if a 2.7x crop is good enough for Darren Aronofsky then 2.3x is good enough for you. Super 16mm films have won multiple Oscars throughout history and nobody complained about the lack of shallow DOF or the film stock being ludicrous! Do you realise how silly it sounds? It isn't even a 2.3x crop factor over the C300. It is a 1.6x crop versus the C300 which is what you are comparing it to, not a photographic camera with a video mode tacked on the back. Super 35mm - the cinema standard - is not the same as full frame. Sean Cunningham, nahua, Ernesto Mantaras and 1 other 4 Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted December 1, 2012 Author Administrators Share Posted December 1, 2012 Gene there are specialist uses of a large sensor (confined spaces) as you rightly point out, and slow mo. But unless your whole film is going to be shot inside a car at 240fps, the Blackmagic is the better choice. I mean look at the history of cinema. How much super slow-mo do you see? Is it really that critical? Don't forget Sigma 8mm will be wide enough for the car shot you're trying. Equivalent to around 18mm on full frame. nahua and Xiong 2 Link to comment Share on other sites More sharing options...
TC Posted December 1, 2012 Share Posted December 1, 2012 You can't compare the ludicrousness of a 2.3 crop factor with the C300. Sorry, you just can't.You can't compare the 'ludicrousness' of 11 stops of dynamic range recorded in 8-bit at 50Mbps to 13 stops of dynamic range recorded in 12-bit raw at 1.1Gbps. Sorry, you just can't. Germy1979, Mondo, Ernesto Mantaras and 1 other 4 Link to comment Share on other sites More sharing options...
cameraboy Posted December 1, 2012 Share Posted December 1, 2012 There's something Freudian about FF sensor obsession ... :) kirk and nahua 2 Link to comment Share on other sites More sharing options...
markm Posted December 1, 2012 Share Posted December 1, 2012 I'd also like to point out that by saying you can't fit people in is a ludicrous statement You should be using lenses designed for the format your shooting on and scale your thinking and lenses down accordingly. As for sensor and out of focus background what are we talking about here the difference between ONE stop? kirk 1 Link to comment Share on other sites More sharing options...
kirk Posted December 1, 2012 Share Posted December 1, 2012 Some of the FF guys seem to want both the background and the subject out of focus most of the time :P Ernesto Mantaras and markm 2 Link to comment Share on other sites More sharing options...
Leang Posted December 1, 2012 Share Posted December 1, 2012 I see. he said ''wider sensor.'' Ernesto Mantaras 1 Link to comment Share on other sites More sharing options...
markm Posted December 1, 2012 Share Posted December 1, 2012 A wider sensor? Link to comment Share on other sites More sharing options...
peederj Posted December 1, 2012 Share Posted December 1, 2012 Also left off the list...low light capability, internal battery, articulated screen, etc... Spend a day with the C100 and you will see the whole thing was intended to be used with an external recorder (Atomos Ninja 2 works a charm). When youzeguys test the C100 out vs. the has-it-actually-shipped-yet BMCC, please for the love of gawd engage Cinema Lock (for Canon Log and its 12 stops of DR) and record direct to ProRes 422 HQ (220 Mbps) and compare that with the RAW or ProRes from the BMCC. And do not neglect to show how nice the footage remains all the way up at ISO 20,000. Dont think the Ninja should be necessary? The internal SDXC's are just safeties. It's the same situation with your BMCC and its battery...the internal is just a safety, and you need an external anyway. Having the Ninja as the external gives a second monitor with peaking etc. for e.g. the focus puller, and if the Ninja goes down your camera still works and can record onto the safeties. Credibility is valuable. I understand crowing about the BMCC and trying to pressure the Japanese companies. But Atomos, another Aussie company, unlocked the capability of the vastly more mature Japanese cameras of this generation for only $1000-$1500, a whole day's worth of batteries and media included. And that's something you know already and shouldn't insist on ignoring just because you want to give your article more zing. Thank you Andrew. Link to comment Share on other sites More sharing options...
Leang Posted December 1, 2012 Share Posted December 1, 2012 A wider sensor?Yes. for a while I was wondering why everyone even brought up FF in the topic and slammering it. It's because Andrew was replying to Gene's comment that he would prefer S35 or a wider sensor as well as higher frame rates. Link to comment Share on other sites More sharing options...
TC Posted December 1, 2012 Share Posted December 1, 2012 Canon have some serious problems. One of the biggest is dynamic range. Canon have never been able to make a sensor with more than 12 stops of dynamic range. The DxO mark for the 5D3 gives it 11.7 stops. The D800 registers 14.4, nearly three stops more. The D600 is almost as high. Canon have made no progress in dynamic range since 2007. Their other big problem is as follows. Despite having quite obviously fallen behind the competition in key areas (dynamic range; high-speed image processing on the video side) they are doing two things which are making them very unpopular. One is high pricing. From the 5D3, to the cinema EOS range, to the EOS-M, to new lenses such as the new 24-70 f4. The other is the obvious and deliberate crippling of their hardware. No clean HDMI out on DLSRs. No time lapse feature in firmware to make you buy the $150 cable release. No focus peaking or zebras on anything other than the C1/3/500. Super low bit-rate on the C100, to differentiate it from the C300 and for no other reason. Hell, even the microphone arm of the C100 is not compatible with the C300, despite the fact that they were almost certainly developed concurrently. Everything is designed with a built in weakness, a built in omission, an obvious and easy-to-implement feature removed. Nothing is designed to be as good as it possibly could be. And reading this and other blogs, it is pretty clear that almost all their customers have woken up to this fact. Canon are becoming very, very unpopular. If they don't change their ways soon it will be too late - they are well on the way to alienating their entire customer base who will chose another brand next time. Link to comment Share on other sites More sharing options...
peederj Posted December 1, 2012 Share Posted December 1, 2012 @TC But of course Canon have the last laugh as they dominate in sales and rentals anyway. Like with the Ninja/Samurai, there are 3rd party workarounds easily available to cover most of Canon's weaknesses (e.g. Magic Lantern) just as there are for RED's accessory price gouging. What there is is a very intensely vocal anti-Canon brigade that tries to drown out all other voices on these blogs and forums. As I wrote, I do understand it, Canon is holding stuff back that they could have included at no additional cost. But their products sell and rent because they just work and are not a pain in the arse in practice. Canon also doesn't gouge on batteries and media and other obnoxious things that Sony, RED, etc. do gleefully. The total cost of ownership is not overpriced and the image is subjectively appealing to many regardless of specs. Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted December 1, 2012 Author Administrators Share Posted December 1, 2012 Also left off the list...low light capability, internal battery, articulated screen, etc... And that's something you know already and shouldn't insist on ignoring just because you want to give your article more zing. Thank you Andrew. It is not about giving something more zing it is about genuine passion for an image. The C100's image is just not as cinematic. I'm sorry, but you cannot compare it to 12bit raw at 2.5K. Low light ability - at ISO 800 and 1600 the shadows go far deeper and cleaner on the Blackmagic Cinema Camera. Granted your ISO 6400 will be better on the C100. But it is also just as nifty on the FS100 and that is $2500 cheaper, with uncompressed HDMI. It also does 1080/60p whilst the C100 maxes out at 30p. Internal battery is not an advantage. You don't get raw. For raw you need an external battery. Why the hell compromise your image for a BATTERY!? Somehow I don't feel compelled to spend double the price on a C100 for a worse image. No idea why!?? :) Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted December 1, 2012 Author Administrators Share Posted December 1, 2012 Credibility is valuable. I understand crowing about the BMCC and trying to pressure the Japanese companies. But Atomos, another Aussie company, unlocked the capability of the vastly more mature Japanese cameras of this generation for only $1000-$1500, a whole day's worth of batteries and media included. Atomos is great but DSLRs cannot make full use of it yet. The image isn't good enough. Look at the D800. Slightly less compression but still a limited dynamic range, 8bit banding, aliasing, moire, low res, line skipping. You compare the HDMI output to the internal codec on the hacked GH2. Better internally! This is a DSLR video blog. That is my focus, and until the HDMI image quality gets better, Atomos isn't worthwhile for me. I have an FS100 and will review the Blackmagic Hyperdeck Shuttle next week. Link to comment Share on other sites More sharing options...
