chetacallahan Posted December 7, 2012 Share Posted December 7, 2012 Hey guys, so im waiting for my redstan clamp that should be here any day now but am looking at my setup ( Kowa Bell & Howell and a Helios m42 lens) and comparing it with the gh2 body mount and im a little worried it might need some support. I remember it mentioned somewhere, possibly the anamorphic guidebook but it was quite expensive, but am wondering if there are any cheap support options you guys have found?Much thanks :) Link to comment Share on other sites More sharing options...
powderbanks Posted December 7, 2012 Share Posted December 7, 2012 what's your budget? baseplate x 15mm rails for $99 [url="http://www.bhphotovideo.com/c/product/875117-REG/IndiPRO_Tools_indi_base_DSLR_Baseplate_15mm_Rods.html"]http://www.bhphotovideo.com/c/product/875117-REG/IndiPRO_Tools_indi_base_DSLR_Baseplate_15mm_Rods.html[/url] lens support for $25 [url="http://www.amazon.com/Opteka-15mm-Lens-Support-Bracket/dp/B007R3Z8OG/ref=sr_1_1?ie=UTF8&qid=1354900120&sr=8-1&keywords=15mm+lens+support"]http://www.amazon.com/Opteka-15mm-Lens-Support-Bracket/dp/B007R3Z8OG/ref=sr_1_1?ie=UTF8&qid=1354900120&sr=8-1&keywords=15mm+lens+support[/url] i got the indipro tools friction follow focus (i need to do some tweaking to get it to work smoother/better) but mostly i use the rail system for supporting my lens. i found something similar to the opteka support and it works just fine crappy pic from my ipod touch, but you get the idea. [img]http://i7.photobucket.com/albums/y278/guiteej3/BB3C25D4-EA6F-4863-B2AF-C3727675CC3E-3906-000000A826F09EDD.jpg[/img] Link to comment Share on other sites More sharing options...
QuickHitRecord Posted December 7, 2012 Share Posted December 7, 2012 [url="http://www.cavision.com/rods/R15-60LS06U.htm"]http://www.cavision.com/rods/R15-60LS06U.htm[/url] Link to comment Share on other sites More sharing options...
chetacallahan Posted December 7, 2012 Author Share Posted December 7, 2012 Hey guys, thanks for your responses I ended up doing some more searching around and found a cheap solutionHere is a rail setup with adjustable lens support, the 4 reviews it has speaks very highly of the construction quality[u][url="http://www.amazon.com/Fotga-DP500-Support-System-Matte/dp/B00857R0TE/ref=sr_1_1?ie=UTF8&qid=1354902567&sr=8-1&keywords=fotga+500"]http://www.amazon.com/Fotga-DP500-Support-System-Matte/dp/B00857R0TE/ref=sr_1_1?ie=UTF8&qid=1354902567&sr=8-1&keywords=fotga+500[/url][/u]I ended up finding it cheaper on ebay with a matte box here[url="http://www.ebay.com/itm/Fotga-DP500-DSLR-Matte-Box-w-15mm-Rail-Rod-Support-for-Follow-Focus-Rig-5DII-60D-/310419572936?pt=LH_DefaultDomain_0&hash=item484672c8c8"]http://www.ebay.com/itm/Fotga-DP500-DSLR-Matte-Box-w-15mm-Rail-Rod-Support-for-Follow-Focus-Rig-5DII-60D-/310419572936?pt=LH_DefaultDomain_0&hash=item484672c8c8[/url] I ended up ordering it so ill review it once i get it and let you guys know! Link to comment Share on other sites More sharing options...
Sean Cunningham Posted December 7, 2012 Share Posted December 7, 2012 If you don't need, or don't want, or can't use a full-on baseplate and rod support there's also the VELBON SPT-1 which I read about on these forums. I've also seen examples of it adapted for use with one of the smaller, DSLR-specific support rails options, for use with follow-focus but still without the bulk of a full baseplate... [img]http://www.velbon.biz/_src/sc1187/SPT-1.jpg[/img] Link to comment Share on other sites More sharing options...
brucker Posted December 8, 2012 Share Posted December 8, 2012 i've been using that ^^^ and its nice and compact, and sturdy, and the hardware store has a bunch of brackets that you can use to support a lens if you're tight,... otherwise one of them canon telephoto rings will do the job. Link to comment Share on other sites More sharing options...
