Sony A7RII (With EF-S Lenses?) In S35 Mode
exomonkeyman
I know it sounds silly... well that's because it is silly, but i'm curious if it's possible to get an adapter for a A7RII for EF-S lenses not EF. And if it is possible would they work in S35 mode as it's kinda close to an APS-C crop.
Really interested to know if possible and what adapter and the side effects for doing this is.
P.S
Samuel
Sam, you can use EF-S lenses on EF mounts (doesn't require a special EF-S mount). The projected image just isn't intended to cover fullframe sensors.
This is a note on the Metabones site: 'Vignetting at corners may occur for certain EF-S lenses because they are designed to cover a 1.6x crop image circle but Sony NEX has a 1.5x crop sensor'.
Guest Ebrahim Saadawi
Nothing silly about the question, we all do it. EF-S lenses work perfectly.
If you set the A7 to FF mode, then you'll have a large black circle around the image, so flicking to s35 is required to get rid of it.
Guest
Reply to this topic...
  Only 75 emoji are allowed.
