Administrators Andrew Reid Posted October 9, 2015 Administrators Share Posted October 9, 2015 DJI are stepping into new areas where GoPro won't dare tread... The DJI Osmo has been initially cast aside as an expensive 'selfie stick' by some - it's anything but. This device has the cinema credentials to be seriously disruptive.Read the full article Link to comment Share on other sites More sharing options...
fuzzynormal Posted October 9, 2015 Share Posted October 9, 2015 I hope it's innovative and shakes things up. However, my DJI Phantom had an impressive spec sheet when it was released a few years back, but the IQ was horrible, so I'll believe it when I see it.No doubt that the tech is evolving for it to be a nice product though... Link to comment Share on other sites More sharing options...
TSV Posted October 9, 2015 Share Posted October 9, 2015 DJI and its horrible support... Yeah! Don't get me wrong I love the idea and would probably get one, but after 3 month of total nightmares dealing with DJI support I fear the worse. Werner H. Graf 1 Link to comment Share on other sites More sharing options...
aldolega Posted October 9, 2015 Share Posted October 9, 2015 Andrew, you are assuming that the X5/X5R cams will fit in/on the Osmo, and that if they do, the Osmo will be strong enough to balance/counteract the much larger/heavier cam and lens. Also, with the X5R recording to SSD, you will need to run HDMI, or whatever cable the cam uses for output, from the cam to the recording module- is the Osmo gimbal set up for this, like I'm assuming the X5 gimbal is? Or are you meaning to use the X5 gimbal instead, simply with the Osmo grip? Link to comment Share on other sites More sharing options...
manueldomes Posted October 9, 2015 Share Posted October 9, 2015 I also don't quite understand how this works. But I guess it will - still you are looking at 650 usd for the gimbal plus 1600 for the X5 if I get it right? Link to comment Share on other sites More sharing options...
Cinegain Posted October 9, 2015 Share Posted October 9, 2015 Andrew, you are assuming that the X5/X5R cams will fit in/on the Osmo, and that if they do, the Osmo will be strong enough to balance/counteract the much larger/heavier cam and lens. Also, with the X5R recording to SSD, you will need to run HDMI, or whatever cable the cam uses for output, from the cam to the recording module- is the Osmo gimbal set up for this, like I'm assuming the X5 gimbal is? Or are you meaning to use the X5 gimbal instead, simply with the Osmo grip?Says so right here:Apparently with a setup like so: Orangenz and Martin Matěj 2 Link to comment Share on other sites More sharing options...
Xavier Plagaro Mussard Posted October 9, 2015 Share Posted October 9, 2015 DJI is the BMD of flying cameras! ;-DI wasn't very convinced about the remote focus (perfect for the Ronin, not for drones), but this is really interesting. And their cameras seems to be improving all the time. As fuzzynormal says their first cameras were much worse than GoPros, but they are surpassing them now..... Link to comment Share on other sites More sharing options...
DBounce Posted October 9, 2015 Share Posted October 9, 2015 DJI is the BMD of flying cameras! ;-DI wasn't very convinced about the remote focus (perfect for the Ronin, not for drones), but this is really interesting. And their cameras seems to be improving all the time. As fuzzynormal says their first cameras were much worse than GoPros, but they are surpassing them now..... From what I've seen the X5 series is pretty good. 13 stops of DR and cinema 4k at 24fps. Certainly good enough for indie film, music videos or documentary work. I'm liking it a lot. The only problem I see is lens support, which right now is limited to only two third party lenses, both of which are fairly wide. Link to comment Share on other sites More sharing options...
Super Members Mattias Burling Posted October 9, 2015 Super Members Share Posted October 9, 2015 Hope it handles the aded weight or a speedbooster + lens. Andrew Reid 1 Link to comment Share on other sites More sharing options...
Oliver Daniel Posted October 9, 2015 Share Posted October 9, 2015 For a future version, it would be really cool to have the MFT camera built into the pistol grip with wireless focus controls (like Aputure) on one side of the grip and pan/tilt on the other. Then this would be one of the most crazy gadgets ever for cinematic work! Flynn 1 Link to comment Share on other sites More sharing options...
Jimbo Posted October 9, 2015 Share Posted October 9, 2015 My god. There's a hefty price tag for both grip and X5 for sure, but 13 stops m43 sensor with 1080p at 60fps... wow.I was never convinced with, what seemed to me, the robotic movement of the nebula but this looks smoother and will undoubtedly be faster to set up. Would be a nice combo with my Leica 15mm. Link to comment Share on other sites More sharing options...
ntblowz Posted October 9, 2015 Share Posted October 9, 2015 Going to ditch pilotfly for this combo (hopefully they come with X5 bundle), I can finally leave the A7s to 28-135mm permanently lol Hopefully they will add more lens in the future, like 25mm/42.5mm/45mm lens, with wireless focus you can get some impressive follow focus on the go with nice bokeh background Link to comment Share on other sites More sharing options...
Xavier Plagaro Mussard Posted October 9, 2015 Share Posted October 9, 2015 The only problem I see is lens support, which right now is limited to only two third party lenses, both of which are fairly wide.You are mostly forced to wide-angles and large DOF, or you need a focus-puller. What we need is a good wide-angle prime with optical stabilization! And learn to walk without bouncing! ;-DHope it handles the aded weight or a speedbooster + lens.The more weight you add, the worse it works and the more power it needs. Even the Osmo X3 seems like a valid option. It cost's the same of a GoPro with gimbal. I love the compactness. Link to comment Share on other sites More sharing options...
Antonis Posted October 9, 2015 Share Posted October 9, 2015 X3 vs X5 sensor size comparison: Link to comment Share on other sites More sharing options...
mdebono Posted October 9, 2015 Share Posted October 9, 2015 I also don't quite understand how this works. But I guess it will - still you are looking at 650 usd for the gimbal plus 1600 for the X5 if I get it right?I'm guessing it will be cheaper since the price you quoted for the Osmo already includes the X3 camera (which won't be needed) and the price for the X5 already includes the 3-axis gimbal (which also won't be needed when combined with the Osmo). We just have to wait & see how much such a bundle will be priced since I'm pretty sure there are many who are eager to get the Osmo with the X5 due to the larger sensor (and better low light performance). Link to comment Share on other sites More sharing options...
Flynn Posted October 9, 2015 Share Posted October 9, 2015 I also don't quite understand how this works. But I guess it will - still you are looking at 650 usd for the gimbal plus 1600 for the X5 if I get it right?Isn't the raw version of the x5 around 3 times more expensive? Wouldn't it be better to just buy a pistol grip gimbal for $500-600 and add the Blackmagic Micro Cinema Camera for $995. Then you have something on a gimbal that can shoot raw for $1,600 instead of $5,500. graphicnatured and Xavier Plagaro Mussard 2 Link to comment Share on other sites More sharing options...
Antonis Posted October 9, 2015 Share Posted October 9, 2015 Isn't the raw version of the x5 around 3 times more expensive? Wouldn't it be better to just buy a pistol grip gimbal for $500-600 and add the Blackmagic Micro Cinema Camera for $995. Then you have something on a gimbal that can shoot raw for $1,600 instead of $5,500.I think you overlooked the part where the X5R shoots 4k and the BM Micro "only" 1080p. graphicnatured 1 Link to comment Share on other sites More sharing options...
Jimbo Posted October 9, 2015 Share Posted October 9, 2015 Isn't the raw version of the x5 around 3 times more expensive? Wouldn't it be better to just buy a pistol grip gimbal for $500-600 and add the Blackmagic Micro Cinema Camera for $995. Then you have something on a gimbal that can shoot raw for $1,600 instead of $5,500.You're not wrong! Although I think these are the best pistol grip gimbal shots I have seen. It's a neatly small device too and I imagine very quick to setup with the officially supported lenses. Link to comment Share on other sites More sharing options...
Flynn Posted October 9, 2015 Share Posted October 9, 2015 You're not wrong! Although I think these are the best pistol grip gimbal shots I have seen. It's a neatly small device too and I imagine very quick to setup with the officially supported lenses.True. It looks like it will be very easy to use. Just wish the camera on the $649 model was more attractive. I think you overlooked the part where the X5R shoots 4k and the BM Micro "only" 1080p.Yeah, I wasn't thinking about that. Link to comment Share on other sites More sharing options...
Jimmy Posted October 9, 2015 Share Posted October 9, 2015 DJI are really on the up.... If they can just find a middle ground between low mbps H264 and uncompressed raw, they will be a major force. Link to comment Share on other sites More sharing options...
