MaxKitaev Posted October 9, 2015 Share Posted October 9, 2015 Hello everyone,I'm using GH4/G7 with Speedbooster XL an looking for a lens that won't lose focus when i zoom in. Basically i'm trying to achieve this zoom effect:https://vimeo.com/141729555What would be the best EF lens for that? Or even a panasonic lens that can do it? I've seen a lot of arguing about 24-105 f4 lens that some people mention works well some say it loses focus.Also, i heard that speedboster ruins it while the lens may keep focus on full frame. Please help. Thank you Link to comment Share on other sites More sharing options...
BrorSvensson Posted October 9, 2015 Share Posted October 9, 2015 I'm 99% sure that the 70-200 f/2.8 Non-IS is parfocal, i used to have one back when i shot canon. Tarantinos crash zoom often end with a very long focal length so 200mm (300mm FF equiv.) will be perfect for what you are doing. MaxKitaev 1 Link to comment Share on other sites More sharing options...
dhessel Posted October 9, 2015 Share Posted October 9, 2015 I don't think there are many still lenses that are really parfocal but some are better than others. Still lens mounts are not accurate enough for them to be anyway. In order for a lens to be parfocal the flange focal distance must be correct and the lens needs to be designed to do so. The reason why some say the canon lens is and some say it isn't is due to the in-accuracy of the lens mount. Basically some are closer to the correct distance than others so results vary. The speed booster is actually a positive because it can be used to adjust the back focus of the lens. If you adjust the booster until infinity hits its mark then you will have better results than you might otherwise. You may find that the canon lens is parfocal enough if you do that. No guarentees I have never tried it. I don't recall which but some of the rumored parfocal canon zooms are only parfocal when zooming tele to wide. MaxKitaev 1 Link to comment Share on other sites More sharing options...
Nick Hughes Posted October 9, 2015 Share Posted October 9, 2015 My 24-105 definitely loses focus zooming in. I've been shooting with a 70-200 2.8 IS (not sure which model), and while it might not be completely parfocal, it does seem to retain focus pretty well when zooming in. MaxKitaev 1 Link to comment Share on other sites More sharing options...
MaxKitaev Posted October 9, 2015 Author Share Posted October 9, 2015 I'm 99% sure that the 70-200 f/2.8 Non-IS is parfocal, i used to have one back when i shot canon. Tarantinos crash zoom often end with a very long focal length so 200mm (300mm FF equiv.) will be perfect for what you are doing.yeah, but on GH4 this will be only good to film the moon in details. i'm looking into 24-70, 24-105 focal length to shoot portraits almost like in the reference i attached. Link to comment Share on other sites More sharing options...
Nikkor Posted October 9, 2015 Share Posted October 9, 2015 yeah, but on GH4 this will be only good to film the moon in details. i'm looking into 24-70, 24-105 focal length to shoot portraits almost like in the reference i attached.Well the thread title states Speed Booster and Tarantino Crash zooms. If you look at that video again you will see that most go around 60-250mm (s35) BrorSvensson 1 Link to comment Share on other sites More sharing options...
BrorSvensson Posted October 9, 2015 Share Posted October 9, 2015 yeah, but on GH4 this will be only good to film the moon in details. i'm looking into 24-70, 24-105 focal length to shoot portraits almost like in the reference i attached.based by the video you linked it looks like it zooms in to around 200-300mm from around 80. so a 70-200 will probably be good but you are the one to choose. Link to comment Share on other sites More sharing options...
MaxKitaev Posted October 9, 2015 Author Share Posted October 9, 2015 based by the video you linked it looks like it zooms in to around 200-300mm from around 80. so a 70-200 will probably be good but you are the one to choose.Absolutely agree. I should have clarified this. 70-200 is too long for my project. Looking into 25-100 lenses. Link to comment Share on other sites More sharing options...
Brian Caldwell Posted October 10, 2015 Share Posted October 10, 2015 Hello everyone,I'm using GH4/G7 with Speedbooster XL an looking for a lens that won't lose focus when i zoom in. Basically i'm trying to achieve this zoom effect:https://vimeo.com/141729555What would be the best EF lens for that? Or even a panasonic lens that can do it? I've seen a lot of arguing about 24-105 f4 lens that some people mention works well some say it loses focus.Also, i heard that speedboster ruins it while the lens may keep focus on full frame. Please help. Thank you3 scenarios here:1) Your zoom lens is perfectly parfocal, meaning the two endpoints and all points in-between focus to the same plane. Adding a properly adjusted Speed Booster to such a lens will have no effect on its parfocality. If the Speed Booster has a small adjustment error you can loosen the set-screw on the side of the lens mount and then thread the optical cell in or out to achieve perfect parfocality.2) Your zoom lens is parfocal at the end points (wide and tele), but drifts in-between. This is a non-linear condition that is normally cured by re-machining the cam in really expensive cine zooms. If your lens cost less than ~$20k then this non-linear error is ignored. A Speed Booster has no effect on it.3) Your zoom is not quite parfocal at the end points. The Speed Booster can be used just like a set of precision shims to fix this condition. However, the Speed Booster will likely not be properly adjusted for your other lenses. So either you need a dedicated Speed Booster for this particular lens, or else consider the parfocality adjustment to be temporary. Nikkor 1 Link to comment Share on other sites More sharing options...
MaxKitaev Posted October 10, 2015 Author Share Posted October 10, 2015 3 scenarios here:1) Your zoom lens is perfectly parfocal, meaning the two endpoints and all points in-between focus to the same plane. Adding a properly adjusted Speed Booster to such a lens will have no effect on its parfocality. If the Speed Booster has a small adjustment error you can loosen the set-screw on the side of the lens mount and then thread the optical cell in or out to achieve perfect parfocality.2) Your zoom lens is parfocal at the end points (wide and tele), but drifts in-between. This is a non-linear condition that is normally cured by re-machining the cam in really expensive cine zooms. If your lens cost less than ~$20k then this non-linear error is ignored. A Speed Booster has no effect on it.3) Your zoom is not quite parfocal at the end points. The Speed Booster can be used just like a set of precision shims to fix this condition. However, the Speed Booster will likely not be properly adjusted for your other lenses. So either you need a dedicated Speed Booster for this particular lens, or else consider the parfocality adjustment to be temporary.Thank you Brian. This is a helpful info. I think before adjusting my speedbooster i'd need to decide on the more or less parfocal lens to rent. I don't own anything but canon ef 24-105 3.5-5.6 stm so would need to rent some. Link to comment Share on other sites More sharing options...
The Chris Posted October 10, 2015 Share Posted October 10, 2015 I have the old Tokina/Angineux ATX Pro 28-70 f/2.6-2.8 and its parfocal. Even though it's an AF lens, you pull the focus ring toward the camera to engage MF and it has hard stops, so pulls are repeatable. Best part - it's an amazing lens and I paid $300. It's even usable wide open, best bargain in a zoom IMO. There are a few different versions, Google the lens for a rundown on which version to look for, they pop up on eBay all the time. MaxKitaev 1 Link to comment Share on other sites More sharing options...
manueldomes Posted October 10, 2015 Share Posted October 10, 2015 Does it have to be used on speedbooster? I'm under the strong impression that the angenieux 17-68 2.2 is parfocal and it almost covers the gh4 4k crop. With minimal cropping in post it should be roughly 50-200 FF equivalent. MaxKitaev 1 Link to comment Share on other sites More sharing options...
MaxKitaev Posted October 10, 2015 Author Share Posted October 10, 2015 I have the old Tokina/Angineux ATX Pro 28-70 f/2.6-2.8 and its parfocal. Even though it's an AF lens, you pull the focus ring toward the camera to engage MF and it has hard stops, so pulls are repeatable. Best part - it's an amazing lens and I paid $300. It's even usable wide open, best bargain in a zoom IMO. There are a few different versions, Google the lens for a rundown on which version to look for, they pop up on eBay all the time. this is very useful. i might buy it. not expensive and since it's parfocal sounds like a option for me. Thank you Does it have to be used on speedbooster? I'm under the strong impression that the angenieux 17-68 2.2 is parfocal and it almost covers the gh4 4k crop. With minimal cropping in post it should be roughly 50-200 FF equivalent.doesn't have to. thank you I have the old Tokina/Angineux ATX Pro 28-70 f/2.6-2.8 and its parfocal. Even though it's an AF lens, you pull the focus ring toward the camera to engage MF and it has hard stops, so pulls are repeatable. Best part - it's an amazing lens and I paid $300. It's even usable wide open, best bargain in a zoom IMO. There are a few different versions, Google the lens for a rundown on which version to look for, they pop up on eBay all the time. do you mean hard stops for zoom? how is that? i'd need to pull the zoom smoothly from 28 to 70 and keep the focus? will this lens do it? Link to comment Share on other sites More sharing options...
Cinegain Posted October 10, 2015 Share Posted October 10, 2015 Agreed. Fantastic lens!The focus ring itself has a certain travel between its hard stops, it makes pulling focus from subject A to subject B easy, should you need to. It's just additional information for you. Hasn't got to do with zoom. If want to zoom in on subject A, and want subject A to be in focus during the zoom, with a parfocal lens you don't need any focus pulling of course. So yes, should work exactly like you want. Link to comment Share on other sites More sharing options...
MaxKitaev Posted October 12, 2015 Author Share Posted October 12, 2015 Agreed. Fantastic lens!The focus ring itself has a certain travel between its hard stops, it makes pulling focus from subject A to subject B easy, should you need to. It's just additional information for you. Hasn't got to do with zoom. If want to zoom in on subject A, and want subject A to be in focus during the zoom, with a parfocal lens you don't need any focus pulling of course. So yes, should work exactly like you want.I can only find constant 2.8 lens not 2.6-2.8. do you know if it has the same characteristics? Link to comment Share on other sites More sharing options...
