redimp Posted October 14, 2015 Share Posted October 14, 2015 Since my Rangefinder is on it's way I am thinking of maybe buying a double-focus high quality anamorphic lens. I've read Kowa B&H beats the iscos in terms of image quality and sharpness. Are there any other lens that you personally consider hands down best double focus anamorphics? Want to shoot 50 mm 1.2 lens of FF wide open too. Link to comment Share on other sites More sharing options...
ken Posted October 14, 2015 Share Posted October 14, 2015 I don't think so. IMO, the best sharpness is ISCO high definition attachment.And kowa bh/16h/8z is the widest lens, on FF only reach to 75mm at max. But looks SLR 2X lens might be wider, not sure. Link to comment Share on other sites More sharing options...
Visual Amco Posted October 14, 2015 Share Posted October 14, 2015 Can you use a kowa bell and howell on a 50mm taking lens on a Full frame sensor? I always thought you could? Link to comment Share on other sites More sharing options...
ken Posted October 14, 2015 Share Posted October 14, 2015 Can you use a kowa bell and howell on a 50mm taking lens on a Full frame sensor? I always thought you could?No way. 70mm has a little vignetting already. Here is a ISCO HD attachment's sample image, original size is available there. I think in terms of sharpness only, Schneider ES lens would beat Kowa too. All these are excellent optics, but size matters. Link to comment Share on other sites More sharing options...
Hans Punk Posted October 14, 2015 Share Posted October 14, 2015 You can get away with 58 - 65mm on Kowa B&H in FF when shooting ML raw 4:3 mode on Canon DSLR.Ken is right about sharpness terms - the Schneider ES and Isco MC types are generally sharper than Kowa, but at the cost (to some) of a nicer vintage look. The multi-coating of the later anamorphic projection lenses such as these increases contrast and are less sensitive to flare.Kowa has the edge on FF (IMHO) - as it has a more cinematic 'look'. It can go a bit wider on taking lens before vignette, Schneider ES cinelux and similar require 85mm + to be vignette free due to body length of lens. Link to comment Share on other sites More sharing options...
Bioskop.Inc Posted October 14, 2015 Share Posted October 14, 2015 Kowa for B&H is hands down the best x2 dual focus.You're never going to be able to use a 50mm with an anamorphic on FF.The good news is, using an 85mm with a x2 anamorphic will give you the FOV of a 42mm & a 100mm will give you same FOV of a 50mm (simple maths - you divide the taking lens by 2). Hans Punk 1 Link to comment Share on other sites More sharing options...
Visual Amco Posted October 14, 2015 Share Posted October 14, 2015 Thanks for the info, almost bought a 50mm What EF lenses can you recommend then for full frame anamorphic? (how do you like the Canon 85mm f/1.8 USM?) Link to comment Share on other sites More sharing options...
ken Posted October 14, 2015 Share Posted October 14, 2015 Thanks for the info, almost bought a 50mm What EF lenses can you recommend then for full frame anamorphic? (how do you like the Canon 85mm f/1.8 USM?)IMO, EF85 1.8 works fine and the widest basically, but EF100 f2 is better a little bit in all, except wide angle. Jim Chang 1 Link to comment Share on other sites More sharing options...
Rudolf Posted October 14, 2015 Share Posted October 14, 2015 I am a die-hard Moeller fan... For me nothing comes close in terms of sharpness, imagequality, color, flare. These are so versatile and wonderful built. They have so much character. Maybe the difference is they were made for filming and the 16mm version could work on FF like any Kowa. I would definately go for Moeller 16/32 with Rangefinder if I had the money. On the other way they are so easy to handle... you don't need a rangefinder Arun Karthick, Jim Chang, Ian Edward Weir and 1 other 4 Link to comment Share on other sites More sharing options...
tigerbengal Posted October 15, 2015 Share Posted October 15, 2015 as Rudolf said, the bolex-moller anamorphot 16/32/1.5 will cover full frame, using the helios 44 58mm no problem, image is really good, sharp, color is great , and blue flares!, you can focus to 1mt I believe , (the little one 8/19/1.5 goes to 0.5m, but it will not cover full frame) without diopters. Awesome optics without breaking the bank!! Rudolf 1 Link to comment Share on other sites More sharing options...
itimjim Posted October 17, 2015 Share Posted October 17, 2015 I love my Moeller 16/32/1.5 that much, I might be buried with it. You can keep your Iscos thanks. Rikoshet, eris and valery akos 3 Link to comment Share on other sites More sharing options...
enny Posted October 17, 2015 Share Posted October 17, 2015 Can you use a kowa bell and howell on a 50mm taking lens on a Full frame sensor? I always thought you could?yes you can i have Kowa B&H and yashica 35mm with canon 5dmark 3 no problems i went with Kowa B&H i find Schneider and Isco MC types to be way to sharp like video sharp kowa is sharp but not that video sharp has something to it. I am using 35mm yahsica 2.8 with bmpcc and no vigenting at all also on 60d and full frame 5dm3 Link to comment Share on other sites More sharing options...
roccoforte Posted October 17, 2015 Share Posted October 17, 2015 I recently had a dramatic situation at my house where I had to grab the things that were most valuable to me. I grabbed a few hard drives and my Bolex Moller 8/19/1.5 ;o)It pairs really well with my 50 Karl Zeiss Jena 1.8 as well as some old Nikon AI-S lenses. My brand new Rectilux is being tinkered with right now and I'm getting some good sharpness with this three lens combo. (See still). Although I've lost my close focus but I'll take that loss now that I can focus quickly. Rudolf 1 Link to comment Share on other sites More sharing options...
Visual Amco Posted October 17, 2015 Share Posted October 17, 2015 yes you can i have Kowa B&H and yashica 35mm with canon 5dmark 3 no problemsi went with Kowa B&H i find Schneider and Isco MC types to be way to sharp like video sharp kowa is sharp but not that video sharp has something to it. I am using 35mm yahsica 2.8 with bmpcc and no vigenting at all also on 60d and full frame 5dm3Are you shooting RAW on the 5dMIII? As I am worried if I buy a 50mm and then use the bell and howell it will not work.. Link to comment Share on other sites More sharing options...
Nikkor Posted October 17, 2015 Share Posted October 17, 2015 Just buy a cheap ass helios 44-2 which is 58mm and is probably the widest you want to go. The 35mm enny is talking about are a mystery to me, I'd like to see some samples. Link to comment Share on other sites More sharing options...
enny Posted October 17, 2015 Share Posted October 17, 2015 Are you shooting RAW on the 5dMIII? As I am worried if I buy a 50mm and then use the bell and howell it will not work.. i don't get it i shoot raw with bmpcc and before that i shoot raw with b5m3 why do you think it would be a problem? Just buy a cheap ass helios 44-2 which is 58mm and is probably the widest you want to go. The 35mm enny is talking about are a mystery to me, I'd like to see some samples.i dont shoot 35mm its to wide i do 50mm and up but like i said i can do 35mm yashica full frame with kowa no vignetting there is only vignetting if i point to strong light source Link to comment Share on other sites More sharing options...
Nikkor Posted October 18, 2015 Share Posted October 18, 2015 I would love to see 35 on fullframe with the kowa. Link to comment Share on other sites More sharing options...
Bioskop.Inc Posted October 18, 2015 Share Posted October 18, 2015 Wow! I'd like to see someone using a 35mm with the Kowa on a FF camera too, cause I can't use a 35mm with the Kowa on my 60D!I guess that enny is using RAW in 4:3 mode on his 5D3.The Bollex Moller is a lovely lens, but is x1.5. Whilst the Kowa is a x2, which is the best stretch for an anamorphic (IMHO). Hans Punk 1 Link to comment Share on other sites More sharing options...
Nikkor Posted October 18, 2015 Share Posted October 18, 2015 4:3 in raw is waz bigger than cropping from 16:9 without raw, so this remains a mystery to me. Link to comment Share on other sites More sharing options...
Caleb Genheimer Posted October 19, 2015 Share Posted October 19, 2015 I'll jump on the Kowa bandwagon too. It's capable of going the widest out of any 2x projection Ana. It's not obscenely large. It is plenty sharp, but doesn't look "Zeiss clinical" like modern Schneider/ISCO lenses. It flares nicely, but it reacts well to changing the "taking" lens. Want to change the look of your Kowa? Just change the taking lens! I've used a Mir-1b and it just about nails the "LOMO" look. In short, it's by far the best all-rounder/bang-for-your-buck lens (all flavors: 16-H, 8Z, Bell&Howell) Link to comment Share on other sites More sharing options...
