rzxrey Posted October 29, 2015 Share Posted October 29, 2015 Does it require a lens support? My setup would be a Helios and a Sankor. Link to comment Share on other sites More sharing options...
Caleb Genheimer Posted November 2, 2015 Author Share Posted November 2, 2015 I would suggest a lens support, yeah. I'm probably going to get my Redstan front clamp welded to a lens support for maximum stability. Link to comment Share on other sites More sharing options...
Andrew - SLR Magic Posted November 5, 2015 Share Posted November 5, 2015 Kind of off topic but as the Rangefinder is discussed here I should mention the SLR Magic Rangefinder with Imperial markings is in 77mm thread (http://www.adorama.com/SLRRCA.html) and works directly on our 1.33x and 2x Anamorphot adapters with 77mm front thread. Please note our Rangefinder in 72mm with Near/Normal markings (http://www.ebay.com/itm/SLR-Magic-Rangefinder-adapter-72mm-for-Anamorphic-clamps-/262129589075?hash=item3d08241b53:g:xnwAAOSw7hRWO72Y) does NOT work with our 1.33x and 2x Anamorphot adapters. If you use step-down ring there may be vignetting. The 72mm version would work for 72mm thread Anamorphic Clamps. Link to comment Share on other sites More sharing options...
bzpop Posted November 5, 2015 Share Posted November 5, 2015 72mm version vignettes at 5K, maybe because none of the projection lenses does, and LA 7200 works Ok too, i was expecting it will will be fine , nope;it works OK in 2x ana mode, but i don't like it, it cuts the sides of the image; Dear Andrew, any of the new SLR Magic anamorphic lenses cover 5 or 6K?Thank you! Link to comment Share on other sites More sharing options...
Andrew - SLR Magic Posted November 5, 2015 Share Posted November 5, 2015 I do not fully understand the setup. The LA7200 has no filter thread to use the 72mm Rangefinder? Could you please explain further and send some photos of setup to support@slrmagic.com? thx Link to comment Share on other sites More sharing options...
bzpop Posted November 6, 2015 Share Posted November 6, 2015 Sorry Andrew, didn't want to confuse you, i didn't use LA7200 with rangefinder, i just mentioned it as an example, in s35 at 5k it doesn't vignette, as well as Kowa 16h or ISCO ultra star, from 50mm and up; and putting rangefinder on kowa 16H creates strong vignette, without rangefinder kowa, or blue star , or ultra star don't vignette, but this is in 16;9, switching to 2x anamorphic mode fixes this vignette, but as i said i don't like that mode and prefer 3,5:1, but well;shot some test tonight, 'human feces' will be the next test, but i like this glass. a bit too heavy, i would accept hard plastic framing, cuz for anamorphic setup it is a lens+adapter+rangefinder, gets heavy and bulky, i know, i know, real anamorphics are huge and heavy, just thinking out loud;So, dear Andrew, are any of new SLR Magic anamorphic lenses cover 5 or 6k, because if they do that would be awesome.thanks! christrad and ken 2 Link to comment Share on other sites More sharing options...
christrad Posted November 6, 2015 Share Posted November 6, 2015 Great test bzpop, strange that the annoying blue blobs doesn't appear in your video. Do you have a clue why ?By the way, wich camera did you use (I was thinking of Sony As7 or A7rII) ? Link to comment Share on other sites More sharing options...
bzpop Posted November 6, 2015 Share Posted November 6, 2015 strange that the annoying blue blobs doesn't appear in your video. Do you have a clue why ? my guess is the lens(s) i used, it's Nikon 50mm 1.4 (wide open) and Kowa 16H, shot on Red epic 5K Link to comment Share on other sites More sharing options...
Andrew - SLR Magic Posted November 6, 2015 Share Posted November 6, 2015 I do not have a Red Epic to test but our 50mm and 70mm 2x Anamorphic lens should cover 6k. Our 35mm, 50mm, and 70mm 1.33x Anamorphic lens should cover 6k too.As for the Kowa, it has got to do with the design of your taking lens. You should not use a fast lens and should not use zoom lens to avoid vignetting. Link to comment Share on other sites More sharing options...
bzpop Posted November 7, 2015 Share Posted November 7, 2015 i never use zoom lenses with anamorphic adapters :))), but i always try to shoot with fast glass, 1.4 prime stopped down is f2.8 and 2.8 prime stopped down is f4, ,and when it's dark it's nice to have faster lens. a lot of DPs shoot wide open even when there is enough light:))), i like it too;Thanks Andrew, i am looking forward to to try them all, and see what they can do :)) Link to comment Share on other sites More sharing options...
