paulie Posted November 1, 2015 Share Posted November 1, 2015 Hello everybody. I have a special question to you. See the video below.See the black area on the camera screen, you will check horizoltal and vertical lines. I think this is not a normally way to explain camera video noise. What do you think? Ideas? Link to comment Share on other sites More sharing options...
homestar_kevin Posted November 20, 2015 Share Posted November 20, 2015 This was shot with the d5200. The d5200 and d7100 have a horizontal fixed pattern noise in the blacks. I've been using the d7100 for over 2 years now and sometimes it'll happen very badly, othertimes not so much. It will definitely happen if you're pushing to higher ISOs in low light, but sometimes it can happen in even good light with really dark, shadowy areas. For the d5200 you have, I believe there is a hack which increas the video MBPS rate up and that will take care of it. It seems to be a result of Nikons really low bitrate codec Link to comment Share on other sites More sharing options...
