User Posted November 4, 2015 Share Posted November 4, 2015 I've been fooling around with the C100 MkII for the past few hours. So far so good but it's now time to start working with the files in PP.I noticed that the file folder structure is different to anything I've seen before so I did a search and came up with this video. Data Import Utility? Can Anyone tell me if this is the way to go or is there a better solution? Also, I'm think that it would be best to import and keep the original files in their folder structure, and then make a Prores copy to a second drive. Does someone have a workflow that works well? Link to comment Share on other sites More sharing options...
QuickHitRecord Posted November 4, 2015 Share Posted November 4, 2015 I'm not sure about the Mark II, but I always use Data Import Utility to import files from my Mark I. If I don't, sometimes I will have a small interruption between longer clips that span multiple files. Data Import Utility combines these spanned clips into single files. This may have been corrected in later versions of Premiere but I still do it out of habit, and I try to avoid working with spanned files whenever possible. User 1 Link to comment Share on other sites More sharing options...
Inazuma Posted November 4, 2015 Share Posted November 4, 2015 I record in MP4 and all the video files go into one folder for each day User 1 Link to comment Share on other sites More sharing options...
User Posted November 4, 2015 Author Share Posted November 4, 2015 Inazuma. The quality of audio is better in AVCHD, is that not a concern for you? Link to comment Share on other sites More sharing options...
docmoore Posted November 5, 2015 Share Posted November 5, 2015 Shootout Pro 5 ... Works with any file ... Nothing come close. Bob User 1 Link to comment Share on other sites More sharing options...
User Posted November 5, 2015 Author Share Posted November 5, 2015 Shootout Pro 5 ... Works with any file ... Nothing come close. BobHi Bob, do you know if Shotput Pro 'stitches' spanned AVCHD files together? Link to comment Share on other sites More sharing options...
Inazuma Posted November 5, 2015 Share Posted November 5, 2015 Inazuma. The quality of audio is better in AVCHD, is that not a concern for you?I didn't know that. How much better are we talking? Link to comment Share on other sites More sharing options...
docmoore Posted November 5, 2015 Share Posted November 5, 2015 Hi Bob, do you know if Shotput Pro 'stitches' spanned AVCHD files together?I have not looked for that function ... I just drop both on the timeline in Premiere and it is seamless...It does error correction sampling and has the ability to offload to more than one drive as a backup ... very fast.If I get a chance I will dig into it a bit more to look at whether I can discern a way to enable it. Bob User 1 Link to comment Share on other sites More sharing options...
User Posted November 5, 2015 Author Share Posted November 5, 2015 I didn't know that. How much better are we talking?It's somewhere in a thread I started on the C100 MkII. Some kind individual remarked about it.But here is what I found from canon:AVCHD AUDIO Linear PCM (16 bits/48 kHz/2 channels) (when 28 and 24 Mbps LPCM is selected) Dolby Digital 2ch (when 28, 24, 17, or 7 Mbps is selected)MP4 AUDIO MPEG-4 AAC-LC (16 bit/48kHz/2 channels) Bit rates: 35-17 Mbps: 256 kbps/less than 4 Mbps: 128 kbps I have not looked for that function ... I just drop both on the timeline in Premiere and it is seamless...It does error correction sampling and has the ability to offload to more than one drive as a backup ... very fast.If I get a chance I will dig into it a bit more to look at whether I can discern a way to enable it. BobI have Shotput Pro 5 also and will try to have a look as well. But even though this is the industry standard transfer utility, I've haven't head anything of it's stitching abilities. Link to comment Share on other sites More sharing options...
