exomonkeyman Posted November 4, 2015 Share Posted November 4, 2015 Hello There guys i have a simple but important question to ask.Let's say i wanna buy a samyang 85mm t1.5, is it worth buying a E Mount base straight for my A7RII or an EF mount base than adapt that with the adapter.Iv'e seen that some lenses have a lower scores because of there mount (nikon,sony,canon) is this because when a lens is adapted from EF to E or the other way around, it get's reduced sharpness because it simply works better on EF fit.Curious if it's just best to keep the EF fit then adapt it to sony to guarantee the best optical performance? Or just buy an E mount glass to fit with no adapter?. Sound stupid i know but is this a known problem with 3rd party lenses? Sigma,Samyang,Tamron etc etc. Source: DXOMARK comparason Link to comment Share on other sites More sharing options...
BrorSvensson Posted November 4, 2015 Share Posted November 4, 2015 Hello There guys i have a simple but important question to ask.Let's say i wanna buy a samyang 85mm t1.5, is it worth buying a E Mount base straight for my A7RII or an EF mount base than adapt that with the adapter.Iv'e seen that some lenses have a lower scores because of there mount (nikon,sony,canon) is this because when a lens is adapted from EF to E or the other way around, it get's reduced sharpness because it simply works better on EF fit.Curious if it's just best to keep the EF fit then adapt it to sony to guarantee the best optical performance? Or just buy an E mount glass to fit with no adapter?. Sound stupid i know but is this a known problem with 3rd party lenses? Sigma,Samyang,Tamron etc etc. Source: DXOMARK comparason First of all a adapter with no glass will not effect image quality so the E mount version of the sammy is not less sharp than the canon mount.I'd push you to buy the nikon mount samyang 85mm becuase nikon mount is the most adaptable and can be used on most cameras."Iv'e seen that some lenses have a lower scores because of there mount (nikon,sony,canon) is this because when a lens is adapted from EF to E or the other way around, it get's reduced sharpness because it simply works better on EF fit."That is because the different mounts have difference sensors, lets say canon has a 50mp sensor and sony a 36mp sensor. The lens will score higher on the canon because you can see more detail. exomonkeyman 1 Link to comment Share on other sites More sharing options...
exomonkeyman Posted November 4, 2015 Author Share Posted November 4, 2015 First of all a adapter with no glass will not effect image quality so the E mount version of the sammy is not less sharp than the canon mount.I'd push you to buy the nikon mount samyang 85mm becuase nikon mount is the most adaptable and can be used on most cameras."Iv'e seen that some lenses have a lower scores because of there mount (nikon,sony,canon) is this because when a lens is adapted from EF to E or the other way around, it get's reduced sharpness because it simply works better on EF fit."That is because the different mounts have difference sensors, lets say canon has a 50mp sensor and sony a 36mp sensor. The lens will score higher on the canon because you can see more detail. Oh awesome, Might look into Nikon mountsSeems strange to rate a lens because of it's body's megapixels, thought a lens comparison site would have had more equal tests but i guess things change as the years go by.Thanks i kinda thought that the lower score on the charts meant that something was wrong with the lens on certain mounts you see. Much appreciated. Link to comment Share on other sites More sharing options...
BrorSvensson Posted November 4, 2015 Share Posted November 4, 2015 Oh awesome, Might look into Nikon mountsSeems strange to rate a lens because of it's body's megapixels, thought a lens comparison site would have had more equal tests but i guess things change as the years go by.Thanks i kinda thought that the lower score on the charts meant that something was wrong with the lens on certain mounts you see. Much appreciated.yes i agree but sharpness is a though one to messure because the sensor changes it so much. The vingetting, chromatic aberation and distortion is equal on all sensors. exomonkeyman 1 Link to comment Share on other sites More sharing options...
tupp Posted November 4, 2015 Share Posted November 4, 2015 I'd push you to buy the nikon mount samyang 85mm becuase nikon mount is the most adaptable and can be used on most cameras.+1 Nikon F mount can be physically adapted to almost any camera, but keep in mind that the electronics (AF, image stabilization) may not work. exomonkeyman 1 Link to comment Share on other sites More sharing options...
