Administrators Andrew Reid Posted November 12, 2015 Author Administrators Share Posted November 12, 2015 Then the Ninja Blade offers way more functionality for the same price.Blade is only a 720p screen and it doesn't do 1080/60p recording either.Also it only takes SSDs. Doesn't record to your existing camera SDXC cards. So factor a few of them into the price. Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted November 12, 2015 Author Administrators Share Posted November 12, 2015 Yeah it's a personal thing.Personally I never use peaking or zebras.Hell, I rarely even look at the histogram.Just give me a good monitor that is sharp as hell and accurate. Link to comment Share on other sites More sharing options...
Fredrik Lyhne Posted November 12, 2015 Share Posted November 12, 2015 So if I understand correctly the VA downscales 4K via HDMI to 1080p10 bit 422 prores on the GH4 making it perfect for V-Log L? Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted November 12, 2015 Author Administrators Share Posted November 12, 2015 So if I understand correctly the VA downscales 4K via HDMI to 1080p10 bit 422 prores on the GH4 making it perfect for V-Log L? No I repeat... that is via the 4K SDI input only. It does not accept a 4K signal via HDMI. I've tried on multiple cameras including GH4 and A7S II. Link to comment Share on other sites More sharing options...
Don Kotlos Posted November 12, 2015 Share Posted November 12, 2015 Also it only takes SSDs. Doesn't record to your existing camera SDXC cards. So factor a few of them into the price.But that is actually an advantage of the Blade. You can get faster SSDs with larger capacity much much cheaper than SDXC. For example a 128gb Sandisk Extreme Pro is $100.A 120gb SSD is less than $50 ... endlessmikehellstrom, IronFilm, TheRenaissanceMan and 1 other 4 Link to comment Share on other sites More sharing options...
sudopera Posted November 12, 2015 Share Posted November 12, 2015 No I repeat... that is via the 4K SDI input only. It does not accept a 4K signal via HDMI. I've tried on multiple cameras including GH4 and A7S II.Finally one reason to buy that YAGHE brick for GH4 Orangenz 1 Link to comment Share on other sites More sharing options...
Nick Hughes Posted November 12, 2015 Share Posted November 12, 2015 No I repeat... that is via the 4K SDI input only. It does not accept a 4K signal via HDMI. I've tried on multiple cameras including GH4 and A7S II.Might be a clever way to sell some of these. Link to comment Share on other sites More sharing options...
kyle Posted November 13, 2015 Share Posted November 13, 2015 All I really want is to add peaking to my D800 since the screen on it is a total POS, do not care about prores so I'll pass on this and keep looking for a screen Link to comment Share on other sites More sharing options...
Bandido Posted November 13, 2015 Share Posted November 13, 2015 Andrew, you said that maybe your SD card needed to be defragmented. Isn’t "Defrag" something you do only when dealing with hard drives?. Wouldn’t be enough to just format the card?. Link to comment Share on other sites More sharing options...
premini Posted November 13, 2015 Share Posted November 13, 2015 Who should buy this? doesnt seem a very appealing product to me. Link to comment Share on other sites More sharing options...
Jonesy Jones Posted November 13, 2015 Share Posted November 13, 2015 Who should buy this? doesnt seem a very appealing product to me.Is this the only 1080P 5" monitor that records to prores that inputs and outputs both SDI and HDMI and (I assume) cross converts between the two? I believe so. It won't surprise me at all if zebras, focus peaking, false color, etc are added eventually, though I wouldn't buy it with that assumption. Link to comment Share on other sites More sharing options...
Clayton Moore Posted November 13, 2015 Share Posted November 13, 2015 I actually got my hands on one of these and an URSA Mini not long ago and knew right away how BMD has the potential, if they stay focused, to push the competition very hard in (affordable by the masses) digital cinema in the next 36 months. Its not always how well developed a product is at release, but how it effects the market and this release is actually petty important in that way because it puts the competition on notice to stay competitive or loose out. IronFilm and zetty 2 Link to comment Share on other sites More sharing options...
Bandido Posted November 13, 2015 Share Posted November 13, 2015 Can the BMD Video Assist be calibrated like the Atomos Ninja Blade? Atomos advertises the Ninja Blade as a “Director Quality Monitor” that can be calibrated with the optional Spyder. I know the Video Assist is higher resolution than the Ninja Blade, but Is the screen also an IPS? Link to comment Share on other sites More sharing options...
animan Posted November 13, 2015 Share Posted November 13, 2015 no mention of colour accuracy/brightness/performance in daylight/viewing angles in the review? this would be useful.. thanks visionrouge 1 Link to comment Share on other sites More sharing options...
visionrouge Posted November 13, 2015 Share Posted November 13, 2015 no mention of colour accuracy/brightness/performance in daylight/viewing angles in the review? this would be useful.. thanksYes, please.Also, what about the pulldown in HDMI (http://www.provideocoalition.com/blackmagic-announces-video-assist-recorder-monitor-at-nab) seems that they forgot this also?! Link to comment Share on other sites More sharing options...
bunk Posted November 13, 2015 Share Posted November 13, 2015 So if I understand correctly the VA downscales 4K via HDMI to 1080p10 bit 422 prores on the GH4 making it perfect for V-Log L? You won't see any difference between 'UHD DownCovert' and scaling UHD to 1080 in post unless you look at it at around 400 to 800% ...and even than at most you will see the differences but you won't be able to tell wich is wich if someone shuffled the files, unless you do it for a living and know what to look for. The same way you won't see any difference between 'UHD DownCovert' and the VA downscaling via SDI (I take, it's up to par to what the GH4 can do).So there is no need for a down scaling recorder when you own a GH4. The GH4 can do this for you. You can't load a preview LUT on the VA so that might be a reason not to buy one ...but I have the PIX-E5H which can load preview LUT's but never use it while recording as I don't like it. Link to comment Share on other sites More sharing options...
Mathieu Semiond Posted November 13, 2015 Share Posted November 13, 2015 Hi, Don't see the mention of lut support so i suppose i does not, someone have info ? Thanks Link to comment Share on other sites More sharing options...
Super Members Mattias Burling Posted November 13, 2015 Super Members Share Posted November 13, 2015 Hi, Don't see the mention of lut support so i suppose i does not, someone have info ? Thanksit does not. Link to comment Share on other sites More sharing options...
Fredrik Lyhne Posted November 13, 2015 Share Posted November 13, 2015 You won't see any difference between 'UHD DownCovert' and scaling UHD to 1080 in post unless you look at it at around 400 to 800% ...and even than at most you will see the differences but you won't be able to tell wich is wich if someone shuffled the files, unless you do it for a living and know what to look for. The same way you won't see any difference between 'UHD DownCovert' and the VA downscaling via SDI (I take, it's up to par to what the GH4 can do).So there is no need for a down scaling recorder when you own a GH4. The GH4 can do this for you. You can't load a preview LUT on the VA so that might be a reason not to buy one ...but I have the PIX-E5H which can load preview LUT's but never use it while recording as I don't like it. Thanks for the reply.Since recording downscaled 4K internally gives better results than recording 1080p I assumed that was also the case when recording externally. I need 10 bit for V-log and I'm not ready to spend 1600 $ (price for PIX-E5 in Norway) for a 4K recorder yet. I'm not sure if the Atomos recorders as the downscaling feature but as Andrew and jakoblewis pointed out the screen is much better plus is does 60p. How do you like the PIX-E5?Can anyone comment on the externally recorded 1080p image quality from a GH4 btw? Link to comment Share on other sites More sharing options...
mercer Posted November 13, 2015 Share Posted November 13, 2015 I also have a Nikon D5500 at the moment but not sure about that, it may have to go back because the HDMI seems stuck at 29.97p or needs pulldown from interlaced signal. Can't get native 24p or 25p out of it.Review of the D5500 is in the works by the way, aside from that issue it is rather nice for a cheap 1080p camera. Very small and light for a DSLR.Dang. That sucks about the HDMI out with the D5500, I love what I have seen of that flat profile and thought it would be great with a recorder. But from everything I've seen, it seems like it's a good dslr that shoots good video... I assume it's better than the rebel line or the eos-m?Anyway, sorry that was off topic... Look forward to your review. Link to comment Share on other sites More sharing options...
