CKheat Posted November 15, 2015 Share Posted November 15, 2015 Hi I'd just like to ask what is the widest taking lens you can pair with a S35 sensor and the Kowa 16H/B&H 2x Anamorphic? I was thinking of getting a 40mm (pentax) or 45 pancake (zeiss Y/C). Will these focal lengths / lenses vignette with the Kowa 16H/B&H?Thanks Link to comment Share on other sites More sharing options...
Tito Ferradans Posted November 16, 2015 Share Posted November 16, 2015 It depends on what you want for your final aspect ratio. If you want the entire 3.56:1 frame, then a 50 would do. If you just need a 2.4:1 crop, you could go around 35, I guess. Link to comment Share on other sites More sharing options...
CKheat Posted November 17, 2015 Author Share Posted November 17, 2015 I should have specified further. For example, URSA mini shooting anamorphic 3072 x 2560 (1:2) then unsqueezing for 2.4:1. Thanks Link to comment Share on other sites More sharing options...
Caleb Genheimer Posted November 17, 2015 Share Posted November 17, 2015 I use a 40mm on NX1 for 2.40 ratio. It's the widest I've found that still covers nicely. Link to comment Share on other sites More sharing options...
CKheat Posted November 17, 2015 Author Share Posted November 17, 2015 I use a 40mm on NX1 for 2.40 ratio. It's the widest I've found that still covers nicely.Caleb what kind of 40mm do you use on your NX1? Link to comment Share on other sites More sharing options...
Caleb Genheimer Posted November 17, 2015 Share Posted November 17, 2015 I use a Konica Hexanon f1.8. It is not a great lens on its own, but it is a pancake with very simple optics, which yields great results with the Kowa if stopped down to f4. I'm looking at getting the Voigtlander 40mm f2 pancake as an upgrade, but I just spent a lot on the rangefinder so it'll have to wait a bit. Here is my first video with the rangefinder on my Kowa/Konica setup: https://vimeo.com/142703300 Link to comment Share on other sites More sharing options...
