NX1 4K DCI vs UHD
Brad Bjornstad
Hey all, just wanted to ask really quickly which setting everyone uses in camera between 4K DCI and UHD. I have heard that you get more resolution (ironically) in the UHD setting. I even believe I might have read that posted by Andrew a while back. I didn't know if maybe that was a firmware issue that was later fixed or not, and wanted to get your guys' thoughts. Thanks.
Unless you are shooting for cinema, use the UHD setting. It does indeed give you better results. However the difference is minuscule.
However some like myself prefer a slight bit of softening (for interviews), so in that case the DCI 4K option is there for you.
I replied in the other thread.
Yes apparently, and it's not firmware, it's just that apparently the sensor 4K is actually 3840x2160 and it's just digital conversion somehow to produce 4096x2160.
I'm curious if the same is true for the NX500, which only offers 24p in 4096x2160. The native 3840x2160 is only offered in 30p on the NX500.
