Parker Posted August 3, 2016 Share Posted August 3, 2016 Even though I've been using Vasile's hack for quite a while now, I still follow Kinoseed's KS hacks Facebook page. Yesterday he posted the camera settings he uses, and I thought they were pretty bizarre/unique, certainly a bit different from what I expect most of us have been using. I haven't tried them or anything, as I'm perfectly satisfied with my current settings, but I am curious to see what such strange settings do to the picture, take a look: Link to comment Share on other sites More sharing options...
Marco Tecno Posted August 3, 2016 Share Posted August 3, 2016 I saw them as well. Are they for nx1 or nx500? Link to comment Share on other sites More sharing options...
Parker Posted August 3, 2016 Share Posted August 3, 2016 3 hours ago, Marco Tecno said: I saw them as well. Are they for nx1 or nx500? I would assume that they're meant to work for either camera, since he makes no mention of master black level or gamma dr, which are the only video settings exclusive to the NX1. Link to comment Share on other sites More sharing options...
Marco Tecno Posted August 3, 2016 Share Posted August 3, 2016 10 minutes ago, Parker said: I would assume that they're meant to work for either camera, since he makes no mention of master black level or gamma dr, which are the only video settings exclusive to the NX1. Yep, hence basically for normal dr. Link to comment Share on other sites More sharing options...
cojocaru27 Posted August 11, 2016 Share Posted August 11, 2016 guys, just wonder why don't you move the topic under nx1 separate page on the forum? is one of the most interesting thread about nx1 and i think it should be there. thx MKSN and sandro 2 Link to comment Share on other sites More sharing options...
sandro Posted August 12, 2016 Share Posted August 12, 2016 This is my first attempt with ricardo's settings. However I didn't use delut cause I wasn't able to make it work, instead I used Premiere's SL GOLD RUSH LDR with personal tweaks (no input LUT). I'm satisfied with the result expect for sky banding present on the original footage. Maybe a higher bitrate would been useful. I used the stock 80Mbit 120p. Anyway I'm impressed by the amount of details this sensor deliver at 1080p from 28MP at 120fps. Samsung really made a beast. I could only imagine what a NX2 could have been like! Pavel Mašek 1 Link to comment Share on other sites More sharing options...
sandro Posted August 13, 2016 Share Posted August 13, 2016 On 2/6/2016 at 3:15 AM, kidzrevil said: I've been shooting gamma c at default contrast -10 sharpness and -1 / -2 saturation and wow. Blown away. These were shot with 16-235 but Today i am experimenting with 16-255 as I've read technicolor cinestyle used that range to optimize the image for the encoder. 16-235 remapped to 0-255 automatically in premiere and I assume the same would apply to the 16-255 footage ! for this look I did NOT use LUT's aS I noticed LUT's were exaggerating compression artifacts in the image even when denoising before applying the lut. I went old school and just installed my own toe and shoulder using curves and kept the curve in the midtone region linear. Using the zeiss milvus lenses it looks my theory is true. You can beat the in camera sharpening if you use a high contrast lens that can resolve up to 6k. I assume the noise reduction and sharpening algorithim sees the areas of the image are true detail and leaves those areas filled with fine detail alone. This camera deserves the moniker "baby red" because the image quality is stunning WHEN TREATED CORRECTLY. Sorry to quote this old post but I just love this look, it's my favorite. It's incredible this has no MBL! Do you have any particular color correction setting "saved" for this look? Link to comment Share on other sites More sharing options...
Sten Posted August 13, 2016 Share Posted August 13, 2016 22 hours ago, sandro said: Anyway I'm impressed by the amount of details this sensor deliver at 1080p from 28MP at 120fps. Samsung really made a beast. I could only imagine what a NX2 could have been like! Excellent, it seems the 18-200 performs better with 1080p footage ... Link to comment Share on other sites More sharing options...
kidzrevil Posted August 13, 2016 Share Posted August 13, 2016 @sandro it was gamma c at 16-235. I forgot which settings I used for Gamma C but I am working on some new ones anyway. Really wish I didn't have to use 16-235 but I dont have a choice til I find something to use other than premiere Link to comment Share on other sites More sharing options...
sandro Posted August 13, 2016 Share Posted August 13, 2016 1 hour ago, kidzrevil said: @sandro it was gamma c at 16-235. I forgot which settings I used for Gamma C but I am working on some new ones anyway. Really wish I didn't have to use 16-235 but I dont have a choice til I find something to use other than premiere You just color corrected manually? Link to comment Share on other sites More sharing options...
sandro Posted August 14, 2016 Share Posted August 14, 2016 Is anyone using DIS with vintage lenses? I tried and when I pan even slowly i see some weird jello effect making it basically useless... Link to comment Share on other sites More sharing options...
Geoff CB Posted August 14, 2016 Author Share Posted August 14, 2016 1 hour ago, sandro said: Is anyone using DIS with vintage lenses? I tried and when I pan even slowly i see some weird jello effect making it basically useless... It's useless unless your holding the camera steady. Wish they had a menu item for how intense the effect is. Or that you could set the focal length like with the a7r 2 sandro 1 Link to comment Share on other sites More sharing options...
sandro Posted August 14, 2016 Share Posted August 14, 2016 Is there a limit for YT for bitrate? The video I posted before I just noticed it has dropped frames and decoding errors. It's full of "jumps" from here https://youtu.be/emhe9MzVOcE?t=190 Link to comment Share on other sites More sharing options...
kidzrevil Posted August 14, 2016 Share Posted August 14, 2016 22 hours ago, sandro said: You just color corrected manually? yeah curves and saturation Link to comment Share on other sites More sharing options...
sandro Posted August 16, 2016 Share Posted August 16, 2016 Does DIS reduce resolution? Link to comment Share on other sites More sharing options...
ricardo_sousa11 Posted August 29, 2016 Share Posted August 29, 2016 Bringing this back to life, this time with a picture : amanofan, Kisaha, kidzrevil and 5 others 8 Link to comment Share on other sites More sharing options...
Blah Blah Posted September 4, 2016 Share Posted September 4, 2016 I just got an NX1. Do you use the SmartRange+ -setting for video? I tested it and it seems to raise shadows and lower the highlights, making shots more evenly lit. Link to comment Share on other sites More sharing options...
Blah Blah Posted September 5, 2016 Share Posted September 5, 2016 First one is without SmarRange+ and second is with it on. Pavel Mašek 1 Link to comment Share on other sites More sharing options...
kidzrevil Posted September 5, 2016 Share Posted September 5, 2016 @Blah Blah damn that is a HUGE difference ! notice anything weird like macroblocking or random changes in exposure ? Link to comment Share on other sites More sharing options...
NX1user Posted September 5, 2016 Share Posted September 5, 2016 I thought I remember reading here (buried in a 1,000 post thread) that there was a critical downside to using SmartRange+. I don't remember what the downside was though. Link to comment Share on other sites More sharing options...
