jeffpb7 Posted January 14, 2013 Share Posted January 14, 2013 Hello, I have recently discovered the beauty of anamorphic lenses, and decided to purchase an Ekie 16c. Unfortunately, it's soft and the seller won't take it back, so I'm going to try to fix it myself. Can someone please explain the steps in taking apart and aligning the lenses? Or maybe there's a tutorial or diagram that I could look at? I watched a video tutorial on how to take one apart, but it's very blurry, and I can't make out all of the parts clearly. I know it's difficult, but if someone that has some experience in the matter can tell me what to avoid or look for when taking it apart, I would greatly appreciate it. Thanks! Jeff Link to comment Share on other sites More sharing options...
JohnBarlow Posted January 14, 2013 Share Posted January 14, 2013 My first advice is - don't do it but if you want to proceed these are the steps for complete disassembly only, remember to mark things and take photos! 1. Unscrew front lens hood anticlockwise 2. Remove three grub screws and unscrew focus retaining ring 3. Unwind focus ring - it unwinds toward rear of lens (mark where helicoid comes apart) 4. Remove screws from brass guide rails and remove rails from guide slots 5. Part inner tube from outer tube 6. Using lens wrench remove front lens retaining ring, shim and rubber seal if present 7. Using lens wrench remove rear lens retaining ring, shim and rubber seal if present 8. Apply acetone to rim of lenses to loosen glue 9 Push lenses out from the inside using a makeshift daub, if stubborn repeat from step 8. You may not need to go beyond step 4 if the guide rails are worn, either replace or run a trace of solder along the edges to fatten them up. The rest is up to you. YOYO = You're On Your Own :P Link to comment Share on other sites More sharing options...
jeffpb7 Posted January 14, 2013 Author Share Posted January 14, 2013 Thanks John, that's great! Any advise on which way to rotate the glass, or which piece to rotate(front or back)? It's almost sharp right now, but it seems like it's off a hair. At long distances it's sharper. I'd have it fixed by a professional, but I can't seem to find any techs in the Sacramento area. I did find one in LA that I'm going to call today, but I'm afraid of what they mite charge me, so I wanted a plan B to take it apart. I also have another Ekie, that is very sharp, but has fungus on the inside, which I need to get cleaned. Both lenses were allegedly in mint condition. The seller of the one with fungus is going to pay for the cleaning(because Ebay has frozen his payment until resolved), the other said he's going to send me $50(I'm not holding my breath). I also bought a Sankon 16c, that is perfect, so the third time was a charm, but I need to fix the other 2 if I want to sell them for what I paid for them. Thanks again for the info! :) Link to comment Share on other sites More sharing options...
JohnBarlow Posted January 14, 2013 Share Posted January 14, 2013 Before messing with the glass, get to step 4 and swap the guides over and/or rotate them - total 4 combinations, they may have been taken out before and put in the wrong way. Take a picture after each combo and decide. Link to comment Share on other sites More sharing options...
itimjim Posted January 14, 2013 Share Posted January 14, 2013 Doing it by eye sight without the proper workshop gear, give yourself many, many hours to get alignment. It's nano-degrees of adjustment, and simply tightening things up can mis-align again. Link to comment Share on other sites More sharing options...
JohnBarlow Posted January 14, 2013 Share Posted January 14, 2013 +1 but nano degrees is a gross assessment. 1 milliradian accuracy is sufficient Link to comment Share on other sites More sharing options...
jeffpb7 Posted January 14, 2013 Author Share Posted January 14, 2013 Thanks Jon and itimjim, I think I'm going to give it a shot. Hopefully it's a bad combination like John said. but if I have to move to rotate it I should to tiny adjustments, right? How can I make such tiny adjustments? Can you tell me any cheap tools I can pick up that mite be useful? Wound a laser help with alignment? I have screwdrivers and a lens wrench, but that's it. I'm going to get some acetone. Also, my other lens is sharp, but it needs cleaning on the inner elements. Can I clean it easily without mis-aligning it? Thanks a lot, you guys are a huge help! Link to comment Share on other sites More sharing options...
JohnBarlow Posted January 14, 2013 Share Posted January 14, 2013 There are two more combinations by rotating the inner tube 180 degrees, giving 8 combos in total with the guides. Try this first before messing with the glass. As for fungus, get to step 5 and use cotton swap dipped in PONDS cream over affected area. Leave overnight and rinse off with zippo lighter fluid. Dont rub too hard - the inner coatings will rub off = be warned Link to comment Share on other sites More sharing options...
jeffpb7 Posted January 14, 2013 Author Share Posted January 14, 2013 Great, thanks again! While I'm at it, the focus rings are stiff, is there anything I can do to make them move more freely? The Sankor I have moves very freely and is pretty easy(compared to the others) to focus quickly, without jiggling the lens. Link to comment Share on other sites More sharing options...
JohnBarlow Posted January 16, 2013 Share Posted January 16, 2013 You should remove all traces of the old helicoid grease using lighter fluid and an old toothbrush and use a modern synthetic grease from say ebay - use sparingly. Link to comment Share on other sites More sharing options...
jeffpb7 Posted January 17, 2013 Author Share Posted January 17, 2013 Thanks again John... would you happen to know the best brand to use? Link to comment Share on other sites More sharing options...
