enny Posted December 1, 2015 Share Posted December 1, 2015 Hi guys i have bmpcc and kowa B&H in premiere how would one go about creating Aspect Ratio: 2.75:1 I know you have to crop or zoom in but how is this done And is there a plugin that would do this auto. And is 2.75:1 standard they use in Hollywood Thanks guys Link to comment Share on other sites More sharing options...
Bioskop.Inc Posted December 1, 2015 Share Posted December 1, 2015 Hi guys i have bmpcc and kowa B&H in premiere how would one go about creating Aspect Ratio: 2.75:1 I know you have to crop or zoom in but how is this done And is there a plugin that would do this auto. And is 2.75:1 standard they use in Hollywood Thanks guys 2.76:1 is the Ultra Panavision 70 and/or MGM Camera 65 widescreen aspect ratio (65mm film used & a 70mm print projected) - 35mm prints were 2.55:1.Normal Hollywood Cinemascope is either 2.35:1 or 2.39:1 - you pick.2K cinemascope is 2048 x 858 (2.39:1) - so you can produce Cinema 2k resolution cinemascope with that combo.No idea how to do this in Premiere - can you do a custom timeline? Link to comment Share on other sites More sharing options...
richg101 Posted December 1, 2015 Share Posted December 1, 2015 Hi guys i have bmpcc and kowa B&H in premiere how would one go about creating Aspect Ratio: 2.75:1 I know you have to crop or zoom in but how is this done And is there a plugin that would do this auto. And is 2.75:1 standard they use in Hollywood Thanks guys create a timeline of 2.75:1so 2970x1080 drag your footage into the timeline, then stretch the footage on the horizontal by 2x. the sides will be cropped off. You might find you can get away with stretching less than 2x - sometimes 1.8x will be ok - particularly for closeups, since anamorphic squeeze ratio is at infinity, when focused closer the squeeze ratio reduces quite drastically. Use your own judgement - by eye is better than by the numbers. Personally I think 2.66:1 is the golden ratio. any wider and things get a little too thin. - Unless you;re Tarrantino / Bob Richardson and able to make it work for the film:) Bold and shanebrutal 2 Link to comment Share on other sites More sharing options...
