elgabogomez Posted December 4, 2015 Share Posted December 4, 2015 I see 3 options on eBay that may work on a kowa 16s, a rápido technology adapter (wich requires 3 or 4 pieces from their website), a vid atlantic clamp that is "universal" for small anamorphic adapters (kowa, sankor, sun, etc.) or a Raf camera adapter for the kowa 16h... The kowa 16h is different from the 16s, but as far as the backend of the 16s, it appears that 52mm is the diameter so it should work with the raf camera adapter.What option would you buy? rápido tech, vid atlantic or raf camera?? Link to comment Share on other sites More sharing options...
valid Posted December 4, 2015 Share Posted December 4, 2015 Redstan. http://www.redstan.com/index.php?route=product/product&product_id=68 (this includes front clamp too, but maybe you can message to find one with just the back, if that's what you want)PS - 16s has a 39mm back thread, not 52mm elgabogomez 1 Link to comment Share on other sites More sharing options...
Tim McC Posted December 4, 2015 Share Posted December 4, 2015 Redstan, no question. I've used one on a Kowa 16d and if fit like a glove! Link to comment Share on other sites More sharing options...
Caleb Genheimer Posted December 5, 2015 Share Posted December 5, 2015 Trust us when we say Redstan. It may be tempting to cheap out, but seriously. Proper alignment is of utmost importance with anamorphics, and when it comes to alignment, Redstan is just the best. Accept no substitute. valid 1 Link to comment Share on other sites More sharing options...
elgabogomez Posted December 8, 2015 Author Share Posted December 8, 2015 A couple of things are preventing me to go with the Redstan clamp, first is sadly Price, i live in Mexico and the pounds to pesos convertion is making it expensive (100 dollars to pesos is 1650.00, 100 pounds to pesos is 2600.00). Second is the time it will take from UK to California (i live at walking distance to San Diego, Ca) and third, judging from the pictures at Redstan, it looks like the adapter doesn't go flat with the end of the kowa at the taking lens connection, it seems to be a few mm recessed so it will vignette a bit more when on a wider lens. Any users of a kowa 16s and a redstan clamp that can assure me that it is really worth it?? Link to comment Share on other sites More sharing options...
Tim McC Posted December 8, 2015 Share Posted December 8, 2015 Is it worth it? If you're planning on using your Kowa for any kind of actual shoot, then yes. If you just want to play around with anamorphics, shoot some tests, etc. then you could probably get away with a cheaper option. Link to comment Share on other sites More sharing options...
Ian Edward Weir Posted December 8, 2015 Share Posted December 8, 2015 A couple of things are preventing me to go with the Redstan clamp, first is sadly Price, i live in Mexico and the pounds to pesos convertion is making it expensive (100 dollars to pesos is 1650.00, 100 pounds to pesos is 2600.00). Second is the time it will take from UK to California (i live at walking distance to San Diego, Ca) and third, judging from the pictures at Redstan, it looks like the adapter doesn't go flat with the end of the kowa at the taking lens connection, it seems to be a few mm recessed so it will vignette a bit more when on a wider lens. Any users of a kowa 16s and a redstan clamp that can assure me that it is really worth it??There are other alternatives but Redstan's clamps will get you closest to you taking lens. They are also the easiest to use, the safest being your anamorphic lens will not fall to the ground when your adjusting your alignment, and the sexiest in my option. You get what you pay for. Redstan is the man and his clamps are amazing but if you are in a crunch for time and money, Jim at Rapidotechnolgy could have a alternative. http://www.rapidotechnology.com/ Jim Chang and elgabogomez 2 Link to comment Share on other sites More sharing options...
Jim Chang Posted December 10, 2015 Share Posted December 10, 2015 There are other alternatives but Redstan's clamps will get you closest to you taking lens. They are also the easiest to use, the safest being your anamorphic lens will not fall to the ground when your adjusting your alignment, and the sexiest in my option. You get what you pay for. Redstan is the man and his clamps are amazing but if you are in a crunch for time and money, Jim at Rapidotechnolgy could have a alternative. http://www.rapidotechnology.com/ Thanks, Ian. Hi, Elgabogomez, Check this link here for the setup of your Kowa 16S using Rapido Adapter: http://www.rapidotechnology.com/products-services/customized-step-up-down-rings/adapter-for-kowa-lens/kowa-16s The differences between Rapido Adapter and Redstan Adapters are: 1): You could reuse the main adapter for other anamorphic lenses if you have, just get customized step-down ring to match the rear thread of other anamorphic lens. Usually the step-down ring is between 15$-5$. 2): Quick processing/shipping time, I usually ship from Los Angeles in 2-3 days if I have parts in stock. :-)3): Quick customer support, you can always find me on Facebook by searching rapido.technologies@gmail.com. I will verify every details, before shipping the adapter to you, just to make sure you will get what you need. 4): Customization is possible: if you have some special requirement, I can modify the existing adapter to meet your need. Btw, there is a recent review video from Tito about my adapter, check the link below: https://rapidotechnology.wordpress.com/2015/11/29/rapido-adapters-is-reviewed-by-tito-ferradans/I also have some pictures to show you how the system works: https://rapidotechnology.wordpress.com/2015/11/15/pictures-from-recent-customers/ Please let me know if anything that I can help. :-) Jim ChangRapido Technology Link to comment Share on other sites More sharing options...
bzpop Posted December 31, 2015 Share Posted December 31, 2015 Redstan is very good, slightly cheaper, but also very good solution is RaftCamera Link to comment Share on other sites More sharing options...
tweak Posted March 14, 2016 Share Posted March 14, 2016 Raf make a 16-s adapter... also it's perfectly machined to fit the back size (as is the 16h version). Yes it's not a 2-piece adapter, but with a small bit of ingenuity you can modify it to be . It's price is very good and even if you don't make it a two piece alignment will be super easy because it's a mm perfect fit around the back end. Link to comment Share on other sites More sharing options...
rafcamera Posted May 20, 2016 Share Posted May 20, 2016 Hi everybody. I heard that Redstan stopped to manufacture these adapters, and just selling remaining stock at the moment. So, I suppose he'll not object copying of his design now. That is why we made first adapter of this type (M62 filter thread to Kowa-16H and others with 52mm rear diameter). Here is the link http://www.rafcamera.com/en/adapter-52mm-to-m62x0-75-rr Limited quantity is made to check demand. Our version of this adapter keeps 1.5mm distance between rear end of Kowa and front glass of taking lens. It is possible to get closer for my particular lens, but I suppose it may be unsafe for some other lenses, so our adapter allows Kowa rear end to go only 0.5mm besides front plane of a taking lens filter rim. Another feature is intermediate flat spring preventing damage of Kowa barrel by adapter tightening screws (3 of M5 screws are used). Current price is $45 + shipping. If you need some customized adapter, we are ready to make it (average time of availability since drawing is approved is 10 days). Thanks. Raf. Link to comment Share on other sites More sharing options...
ken Posted May 20, 2016 Share Posted May 20, 2016 For mounting 16H, I used 52 to 50 step down ring (for Nikon 50mm 1.8). Link to comment Share on other sites More sharing options...
tweak Posted May 23, 2016 Share Posted May 23, 2016 Nice work Raf! I actually modified one of your original 58mm Kowa 16-H adapters to work in the exact same way! haha. Link to comment Share on other sites More sharing options...
