DBounce Posted December 10, 2015 Share Posted December 10, 2015 Below is a comparison of the two. The results are to me at least not surprising. Comments welcomed. Link to comment Share on other sites More sharing options...
maxotics Posted December 10, 2015 Share Posted December 10, 2015 It's an interesting test in that it proves just how misleading camera specifications can be. Based on that test one would feel a fool to spend $5,000 for an FS5 body, instead of $1,000 for a NX1. The test shows that, resolution-wise, both cameras output similar footage in a static scene with objects lit within (my guess) 2 stops of each other (if that!), between the white of the photograph paper border and the black in the wall, depicted in the picture.There's a reason Andrew puts lamps, strings of lights and shadow-producing objects in his test scenes. It is difficult to shoot a scene of wide dynamic range using reflected light only. In the real world, where the sky is in the scene outside, or even coming through the windows, there will be 10-20 stops of dynamic range, or brightness from dark to light where each stop at the high or low end would show more or less detail (contrast).So when a filmmaker looks at Andrew's test scenes, for example, he will look to see how much detail is preserved in the string of lights, or in a shadow. The book on the table is mostly to show color at middle gray.Point both cameras at a person sitting on a couch, say, with light streaming through the window, with a mix of highly reflective objects, and light absorbing objects, and then let's see the difference between the FS5 and NX1 Zach Goodwin 1 Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted December 10, 2015 Administrators Share Posted December 10, 2015 This is a very basic test but it does show the resolution advantage of oversampling 4K from a 6.5K sensor on the NX1Doesn't show much else, like what it is like to grade or dynamic range, where the FS5 definitely has an advantage with S-LOG and the 10bit outputInternal 1080p is also much better on the FS5 but good 1080p is pretty commonplace these days so not jumping up and down in excitement too much for that at $5000I absolutely love my NX1 and the H.265 codec maintains a TON of fine detail in the mids... not so much in the shadows or places where there's not much detail anywayNX1 with the Novoflex A mount adapter and Sony / Minolta / Zeiss lenses by the way = MEGA!! Zach Goodwin and IronFilm 2 Link to comment Share on other sites More sharing options...
neosushi Posted December 10, 2015 Share Posted December 10, 2015 Thanks for the test. I see a lot of resolution, low light and dynamic range test on the internet, but if I may, I would love to see more tests of color grading - meaning, how well does the codec holds up in a color grading situation. Cameras can really be split up in two groups : 420 8 bits internal on one side and PRORES/RAW recording on the other side.The camera of the first group are all subject to banding / macroblocking or noise issues - especially more visible when grading. Link to comment Share on other sites More sharing options...
DBounce Posted December 10, 2015 Author Share Posted December 10, 2015 This is a very basic test but it does show the resolution advantage of oversampling 4K from a 6.5K sensor on the NX1Doesn't show much else, like what it is like to grade or dynamic range, where the FS5 definitely has an advantage with S-LOG and the 10bit outputInternal 1080p is also much better on the FS5 but good 1080p is pretty commonplace these days so not jumping up and down in excitement too much for that at $5000I absolutely love my NX1 and the H.265 codec maintains a TON of fine detail in the mids... not so much in the shadows or places where there's not much detail anywayNX1 with the Novoflex A mount adapter and Sony / Minolta / Zeiss lenses by the way = MEGA!!What fast lenses would you recommend with the Novoflex NX adapter? Link to comment Share on other sites More sharing options...
Cinegain Posted December 10, 2015 Share Posted December 10, 2015 Yeah, saw it over at SARumors. To me it's a rubbish test though. Let's take video of a 2D plane with no depth and motion... yeah... Link to comment Share on other sites More sharing options...
AaronChicago Posted December 10, 2015 Share Posted December 10, 2015 I've sorta changed my tune recently on 4K. I really like true 1080 better for everything except product/landscape shots. maxotics and Zach Goodwin 2 Link to comment Share on other sites More sharing options...
Nick Hughes Posted December 10, 2015 Share Posted December 10, 2015 I've sorta changed my tune recently on 4K. I really like true 1080 better for everything except product/landscape shots.Especially for cameras such as the FS5, which has 10 bit 422 in 1080, but only 8 bit 420 in 4k. Link to comment Share on other sites More sharing options...
AaronChicago Posted December 10, 2015 Share Posted December 10, 2015 The resolution that I see from the C100/BMCC is ideal for me. I think what has made me reconsider is the new Blackmagic cameras. They just don't look as rich as the original models. The DR looks nice but it's just too sterile and digital-esque. Yeah I made that word up. Shield3, Chrad and Zach Goodwin 3 Link to comment Share on other sites More sharing options...
Shield3 Posted December 10, 2015 Share Posted December 10, 2015 I've sorta changed my tune recently on 4K. I really like true 1080 better for everything except product/landscape shots.I have as well. Last year I upgraded our 3 main sets to 4k (well, UHD) and playing back downscaled 4k I see no real difference between that and 1080p. At least not on a 60" set. I remind myself that the TVs all do some 4k sort of 4k upscaling. People also forget that really good 1080p *can* be cropped, panned, etc. in post as well. Yes you lose a bit of resolution but if you have really good 1080p it shouldn't matter. I have 720 blurays that look stunning on a 4k TV. I sure as hell don't miss the file size / conversion / reduced FPS headache that went along with shooting 4k. Link to comment Share on other sites More sharing options...
majoraxis Posted December 11, 2015 Share Posted December 11, 2015 I'm fine with good 1080P as a delivery size. I like to pan, zoom and stabilize with 4k NX1 footage - the extra resolution is a plus when editing. The BMCC has so much going for it when it come to DR, color and short flange distance with the M43 mount, and if the person you purchase from includes the Resolve dongle, having the noise reduction as a part of Resolve is a plus when it comes to playing well with my CPU/GPU. Link to comment Share on other sites More sharing options...
Cinegain Posted December 11, 2015 Share Posted December 11, 2015 Still not sure why between 1080p and 4K there's a void on these puppies.Why won't they be like GoPro... they offer you 1440p and 2.7K. Blackmagic figured 2.5K would help. Subtle pans, zooms, re-framing, stabilizing. Just a little wiggle room. No need to get 200% overscale with 4x the real estate 1080p has. Plus, you can get still record in high resolution, but at higher framerates/better bitdata than 4K, if you're going to put it into a 1080p project anyways. That's what I'd love to see. I agree, 4K might be a little overkill and good 1080p still is more than fine, but a little something something extra to work with would be nice... Link to comment Share on other sites More sharing options...
Marco Tecno Posted December 11, 2015 Share Posted December 11, 2015 Samsung nx500, in its beta iteration, used to support 2.5k (with supposedly full sensor readout). That'd have been much better, imo, then the cropped 4K they implemented in the final version. Unfortunately all the NX hackers have been MIA lately, otherwise they could have easily been able to turn that setting on again. iamoui 1 Link to comment Share on other sites More sharing options...
norliss Posted December 11, 2015 Share Posted December 11, 2015 I have as well. Last year I upgraded our 3 main sets to 4k (well, UHD) and playing back downscaled 4k I see no real difference between that and 1080p. At least not on a 60" set. I remind myself that the TVs all do some 4k sort of 4k upscaling. People also forget that really good 1080p *can* be cropped, panned, etc. in post as well. Yes you lose a bit of resolution but if you have really good 1080p it shouldn't matter. I have 720 blurays that look stunning on a 4k TV. I sure as hell don't miss the file size / conversion / reduced FPS headache that went along with shooting 4k.As a matter of interest, which Blu-rays do you have that are 720p? I've never heard of any before now.... Link to comment Share on other sites More sharing options...
M Carter Posted December 12, 2015 Share Posted December 12, 2015 Still not sure why between 1080p and 4K there's a void on these puppies.Why won't they be like GoPro... they offer you 1440p and 2.7K. Blackmagic figured 2.5K would help. Subtle pans, zooms, re-framing, stabilizing. Just a little wiggle room. No need to get 200% overscale with 4x the real estate 1080p has. Plus, you can get still record in high resolution, but at higher framerates/better bitdata than 4K, if you're going to put it into a 1080p project anyways. That's what I'd love to see. I agree, 4K might be a little overkill and good 1080p still is more than fine, but a little something something extra to work with would be nice...If BMC had ever actually given us 60p at 2.5 k, I'd own one now… beautiful image, I just find 60p to be really handy sometimes. Link to comment Share on other sites More sharing options...
DBounce Posted December 16, 2015 Author Share Posted December 16, 2015 More Link to comment Share on other sites More sharing options...
Marco Tecno Posted December 16, 2015 Share Posted December 16, 2015 If BMC had ever actually given us 60p at 2.5 k, I'd own one now… beautiful image, I just find 60p to be really handy sometimes.nx1 could do that imo, if hacked. Beritar and IronFilm 2 Link to comment Share on other sites More sharing options...
Mozim Posted December 17, 2015 Share Posted December 17, 2015 I have a hard time believing that the NX1s 1080p looks better or at least equal than the FS5s 4K and 1080p. Link to comment Share on other sites More sharing options...
Marco Tecno Posted December 17, 2015 Share Posted December 17, 2015 Mozim, perhaps not better, but even not too much worse, at least in "normal" average conditions. Link to comment Share on other sites More sharing options...
Mozim Posted December 17, 2015 Share Posted December 17, 2015 Well in the video that was posted above, the FS5 looks awful and the NX1 looks great, no matter what mode it was shot in. It's hard to tell the difference between NX1 4K and NX1 1080p and it's hard to tell the difference between FS5 4K and FS5 1080p. Both FS5 modes look way worse than both NX1 modes, even the FS5 4K looks worse than the NX1 1080p. The NX1 performs great but that FS5 footage is seriously flawed, so it's hard to compare it to the NX1 really. Link to comment Share on other sites More sharing options...
