monica660 Posted August 30, 2016 Share Posted August 30, 2016 Is this tutorial I found on Google helpful? Good luck! Link to comment Share on other sites More sharing options...
fuzzynormal Posted August 30, 2016 Share Posted August 30, 2016 8 hours ago, monica660 said: Is this tutorial I found on Google helpful? Good luck! Grrrrrr... Google serves up that ridiculous piece of software for just about any transcoding question. Brorosoft has vomitted this sort of manufactured content everywhere to exploit SEO. Heaven forbid one actually tries to locate legitimate advice about video transcoding through a search engine --as wading through the algorithmic garbage dump of information is barely useful. But then again, Monica660, you already knew that, didn't'cha? That's why you're here. Phil A and dafreaking 2 Link to comment Share on other sites More sharing options...
FannieJane Posted June 23, 2017 Share Posted June 23, 2017 Export ProRes from Premiere Pro CC which is a little complicated, there are many details you need to pay attention to. Step 1. Import the Video to Premiere Pro CC Start the Premiere Pro CC, then choose File > Import. If you prefer to use keyboard shortcuts, press Command+I to open the standard Import dialog. Step 2. Set A New Sequence Project There are 2 ways to set a Sequence Project, you can click "File" to choose "New", the choose the "Sequence", or you can click the red mark, which is the direct sequence icon,click it and enter the sequence window. Step 3. Set the Editing Mode When you open the New Sequence, the go to the"Setting" and choose the "Editing Mode", at the list, choose the"Custom" which you can set other parameters by yourself. Step 4. Set The Preview File Format After the Editing Mode is done, choose the "Preview File Format", at the drop-down list, choose the"Quick Time" Step 5. Set ProRes Codec Under the Preview File Format, it's the Codec choice, click it and you can see many options of ProRes, such as: Apple ProRes 422, Apple ProRes 422(HQ), Apple ProRes 422(LT), Apple ProRes 422(Proxy), etc. Choose one you want. Step 6. Export ProRes from Premiere Pro CC Go to File>Export>Media. You could also press the shortcut key "control M" on PC or "command M" on Mac. Link to comment Share on other sites More sharing options...
Pavel Radu Posted November 13, 2017 Share Posted November 13, 2017 I came across this discussion searching for an alternative to render prores from premiere pro, however, it seems impossible from PP, but, you can render any prores with another platform called Cruncher https://getcruncher.com it's a stand-alone app and seems to be well built. Link to comment Share on other sites More sharing options...
FannieJane Posted December 29, 2017 Share Posted December 29, 2017 You can export ProRes from Premiere Pro CC by following the steps below: Step 1. Import the Video to Premiere Pro CC Start the Premiere Pro CC, then choose File > Import. If you prefer to use keyboard shortcuts, press Command+I to open the standard Import dialog. Step 2. Set A New Sequence Project There are 2 ways to set a Sequence Project, you can click "File" to choose "New", the choose the "Sequence", or you can click the red mark, which is the direct sequence icon,click it and enter the sequence window. Step 3. Set the Editing Mode When you open the New Sequence, the go to the"Setting" and choose the "Editing Mode", at the list, choose the"Custom" which you can set other parameters by yourself. Step 4. Set The Preview File Format After the Editing Mode is done, choose the "Preview File Format", at the drop-down list, choose the"Quick Time" Step 5. Set ProRes Codec Under the Preview File Format, it's the Codec choice, click it and you can see many options of ProRes, such as: Apple ProRes 422, Apple ProRes 422(HQ), Apple ProRes 422(LT), Apple ProRes 422(Proxy), etc. Choose one you want. Step 6. Export ProRes from Premiere Pro CC Go to File>Export>Media. You could also press the shortcut key "control M" on PC or "command M" on Mac. Link to comment Share on other sites More sharing options...
cantsin Posted December 29, 2017 Share Posted December 29, 2017 6 hours ago, FannieJane said: Step 5. Set ProRes Codec Under the Preview File Format, it's the Codec choice, click it and you can see many options of ProRes, such as: Apple ProRes 422, Apple ProRes 422(HQ), Apple ProRes 422(LT), Apple ProRes 422(Proxy), etc. Choose one you want. Step 6. Export ProRes from Premiere Pro CC Go to File>Export>Media. You could also press the shortcut key "control M" on PC or "command M" on Mac. What you describe, only works under Mac OS X (and is unnecessarily complex for that operating system). Under Windows, there is no encoding support for ProRes in Premiere. ProRes also does not turn up in the Preview File Format options for Quicktime that you mention in your Step 5: Link to comment Share on other sites More sharing options...
Don Kotlos Posted December 29, 2017 Share Posted December 29, 2017 Everyone would be better off in the future if they just use Cineform. When someone asks for Prores delivery, tell them that Cineform is better. If they insist tell them that they should be paying extra for the mac ecosystem, because at the end of the day it is costing you more money. Now it is open source. https://gopro.com/news/gopro-open-sources-the-cineform-codec https://gopro.github.io/cineform-sdk/ I am a mac user, but please stop using proprietary codecs. Especially the ones that don't work across platforms by design like Prores. deezid and Kisaha 2 Link to comment Share on other sites More sharing options...
deezid Posted December 30, 2017 Share Posted December 30, 2017 8 hours ago, Don Kotlos said: Everyone would be better off in the future if they just use Cineform. When someone asks for Prores delivery, tell them that Cineform is better. If they insist tell them that they should be paying extra for the mac ecosystem, because at the end of the day it is costing you more money. Now it is open source. https://gopro.com/news/gopro-open-sources-the-cineform-codec https://gopro.github.io/cineform-sdk/ I am a mac user, but please stop using proprietary codecs. Especially the ones that don't work across platforms by design like Prores. Cineform is more efficient as well Link to comment Share on other sites More sharing options...
Jonesy Jones Posted December 30, 2017 Share Posted December 30, 2017 10 hours ago, Don Kotlos said: Everyone would be better off in the future if they just use Cineform. When someone asks for Prores delivery, tell them that Cineform is better. If they insist tell them that they should be paying extra for the mac ecosystem, because at the end of the day it is costing you more money. Now it is open source. https://gopro.com/news/gopro-open-sources-the-cineform-codec https://gopro.github.io/cineform-sdk/ I am a mac user, but please stop using proprietary codecs. Especially the ones that don't work across platforms by design like Prores. Don, I am very interested in using CineForm. I agree about not using proprietary stuff (this is why I won't really ever go with FCPX). I followed the links you shared and read them, but I am not tech savvy enough to do whatever that second link was describing. I have Adobe Cloud. Is there a simple way for me to get and use CineForm on a Mac? EDIT: Never mind Don, I figured it out. For those also interested, look for "GoPro CineForm" in the drop down menu and not just CineForm. Here's a link from Adobe on the matter. Link to comment Share on other sites More sharing options...
