Liam Posted February 14, 2016 Share Posted February 14, 2016 2 hours ago, Mattias Burling said: Anybody know of any A7sii Slog-3 for download? original files from Andrew still available here, right? - https://vimeo.com/album/3613956 Mattias Burling 1 Link to comment Share on other sites More sharing options...
omar Posted February 17, 2016 Share Posted February 17, 2016 Attached are three .DNG frames from three separate raw clips I shot on the URSA Mini 4K. They were all shot in 4K RAW 400 ASA. If you want to see the clips in action, check out my video on vimeo: Fazer_1_2016-02-10_2344_C0016_000609.dng Fazer_1_2016-02-11_0023_C0005_000194.dng Fazer_1_2016-02-11_0023_C0005_000566.dng benymypony and Nikkor 2 Link to comment Share on other sites More sharing options...
raf702 Posted March 3, 2016 Share Posted March 3, 2016 Anyone kind enough to share some ungraded FS7 cine-ei s-log3 4K xavc-i clips. Would love to do some grade tests, as I'm saving up for an FS7. Thanks! Link to comment Share on other sites More sharing options...
jgharding Posted March 6, 2016 Share Posted March 6, 2016 I've cleaned the thread of most of the non footage posting stuff. It was arbitrary job, apologies if your post has disappeared, but the thread need to be mostly footage links and footage requests in order to serve its purpose properly. This is proving to be a valuable resource. Feel free to continue discussion, just be aware that it may be cleaned up intermittently to keep the thread useful to newcomers. Please try to keep your links alive insofar as you can. Gadhai 1 Link to comment Share on other sites More sharing options...
jgharding Posted March 6, 2016 Share Posted March 6, 2016 Here is some original footage from the Canon XC10. The white balance is off, dull cloudy daylight coming in from the right in a low kelvin tungsten environment, which allows you to test pushing the grade around. Autofocus, maximum available stabiliser. ISO500 4K - 1GB file - https://dl.dropboxusercontent.com/u/9922139/A004C004_150124YQ_CANON.MXF 1080p - 110mb file - https://dl.dropboxusercontent.com/u/9922139/A003C007_1501247H_CANON_01.MXF I prefer 1080 for the most part, the oversampling 1080 is nicer than 4K bayer for me. Link to comment Share on other sites More sharing options...
Super Members Mattias Burling Posted March 8, 2016 Super Members Share Posted March 8, 2016 Ungraded Slog2 Selfie, http://www.filedropper.com/ungradedslog Here is what I did, Link to comment Share on other sites More sharing options...
bunk Posted March 9, 2016 Share Posted March 9, 2016 16 hours ago, Mattias Burling said: Ungraded Slog2 Selfie, Thanks for sharing Mattias! had to adjust my workflow ...first time I used contrast pivot and shadow in DaVinci. Without it I could not hold the shadow under the roof. lesson learned. Attached my settings. delog_slog2_mattias_1.14.1.dpx Link to comment Share on other sites More sharing options...
Super Members Mattias Burling Posted March 11, 2016 Super Members Share Posted March 11, 2016 Here you go, BMPCC TIFFs and D16 DNGs. REMEMBER: This was the old D16 firmware, with the old Matrix, therefor it must be switched to BMCC or preferably BMPC4K Gamma. Otherwise its very magenta. You can do so i Resolve or After Effects if you have the BMDFilm converter. http://www.filedropper.com/frames Link to comment Share on other sites More sharing options...
bunk Posted March 12, 2016 Share Posted March 12, 2016 23 hours ago, Mattias Burling said: Here you go, BMPCC TIFFs and D16 DNGs. Thanks for sharing. I like the BMPCC footage better as it easier to handle and is way more neutral. Mattias Burling 1 Link to comment Share on other sites More sharing options...
Super Members Mattias Burling Posted March 12, 2016 Super Members Share Posted March 12, 2016 Looks good. As the "talent" I would be more comfortable with your D16 grade. In your BMPCC I look a bit grey. But both are fine. Link to comment Share on other sites More sharing options...
Super Members Mattias Burling Posted March 18, 2016 Super Members Share Posted March 18, 2016 Here is some 5D Mark III Raw that show its Dynamic Range. In the shot I closed the blinds behind me so the window infront is basically the only light source. So yeah, very much backlit. Same in camera settings on all, exposed with ND. In my examples I set the highlights and shadows the same on all, then I boosted the mids as far as I thought was somewhat usable. I used highlight recovery for the clips with blown highlights. No grading. (Please note that resolve interoperates WB wrong, so set it manually.) Number 1: ETTR, no highlights blown at all. Before After Number 2: ETTR Medium, some blown highlights outside, great job by the recovery. Before After Number 3: ETTR Low, Blew almost the entire window. Before After (look at them clouds returning ) The files:http://www.filedropper.com/justdngs Dropped a LUT on the last one just to give an idea. Not adjusted. kaylee, SMGJohn, mercer and 1 other 4 Link to comment Share on other sites More sharing options...
bunk Posted March 18, 2016 Share Posted March 18, 2016 7 hours ago, Mattias Burling said: I used highlight recovery for the clips with blown highlights. That's one cool feature. Didn't realize it was there. Thanks for sharing Link to comment Share on other sites More sharing options...
kaylee Posted March 19, 2016 Share Posted March 19, 2016 9 hours ago, Mattias Burling said: Here is some 5D Mark III Raw that show its Dynamic Range. imo 5d3 raw is somehow simultaneously the most real image around and the prettiest it makes the ordinary extraordinary. a few seconds in post with ETTR_low and it starts looking like a vermeer how do you like it, mattias? ive been looking forward to hearing your thoughts Link to comment Share on other sites More sharing options...
Super Members Mattias Burling Posted March 19, 2016 Super Members Share Posted March 19, 2016 4 hours ago, kaylee said: imo 5d3 raw is somehow simultaneously the most real image around and the prettiest it makes the ordinary extraordinary. a few seconds in post with ETTR_low and it starts looking like a vermeer how do you like it, mattias? ive been looking forward to hearing your thoughts I like it. Cant really think of anything negative to say really. Lots of positive though. Link to comment Share on other sites More sharing options...
BrorSvensson Posted March 20, 2016 Share Posted March 20, 2016 On 2016-03-19 at 7:51 AM, Mattias Burling said: I like it. Cant really think of anything negative to say really. Lots of positive though. Now that you have all the CF cards and stuff for magic lantern raw it would be fun to see what you could do with the 150$ Canon 50D Link to comment Share on other sites More sharing options...
Super Members Mattias Burling Posted March 20, 2016 Super Members Share Posted March 20, 2016 25 minutes ago, BrorSvensson said: Now that you have all the CF cards and stuff for magic lantern raw it would be fun to see what you could do with the 150$ Canon 50D I tried to buy one a few weeks ago, but the deal fell through. Link to comment Share on other sites More sharing options...
BrorSvensson Posted March 20, 2016 Share Posted March 20, 2016 19 minutes ago, Mattias Burling said: I tried to buy one a few weeks ago, but the deal fell through. ah, bummer Link to comment Share on other sites More sharing options...
Stathman Posted March 20, 2016 Share Posted March 20, 2016 Thank you all for kindly sharing your footage. Very helpful. I thing i'm in love with the old fat 5d3's raw image... BrorSvensson, Mattias Burling and kaylee 3 Link to comment Share on other sites More sharing options...
Super Members Mattias Burling Posted March 25, 2016 Super Members Share Posted March 25, 2016 Here are some files from the JVC LS300. Checkout the thread with he review for more info. One is a test of the Dynamic Range. It was shot in s35 with a m4/3 kit lens so there is s one severe barrel distortion, but no vignette. The other is a portrait of Gunpowder with a vintage Yashikor 55mm My advice for grading is to treat it as Rec709 and don't push the shadows to much. The mids and highlights can take more of a beating. DR test Ungraded No highlights blown, sky is preserved for the sake of the test. With a quick grade Gunpowder ungraded Quick Grade 1 Quick Grade 2 The files can be downloaded here: http://www.filedropper.com/jvc Link to comment Share on other sites More sharing options...
fuzzynormal Posted March 28, 2016 Share Posted March 28, 2016 XPRO2, high ISO's: https://www.dropbox.com/sh/wvddndv1y1nkhzn/AABMu380redCknSoktKDuoosa?dl=0 Link to comment Share on other sites More sharing options...
