Alex Moreán Posted January 13, 2016 Share Posted January 13, 2016 Hey guysSo I'm taking my first steps in this 4K world and actually by now all I want to do is shoot 4K and export FHD.Probably I would reframe some shots and fake some camera movements in post, so what would be the best approach:- 4K composition + overscaling the footage I want to reframe -> Export in FHD- FHD composition + downscaling all the 4K footage to fit FHD -> Export in FHDI have actually noticed that whenever I make a FHD project, stick all the 4k footage and downscale it, everything just slows down so I guess it takes a lot of processing power... I'm I right?Thanks! Link to comment Share on other sites More sharing options...
Geoff CB Posted January 13, 2016 Share Posted January 13, 2016 Yeah it's always faster to edit at native resolution. Option one does all the processing on export, option 2 does it while your editing. Go with option 1 for speed. Link to comment Share on other sites More sharing options...
Sekhar Posted January 13, 2016 Share Posted January 13, 2016 Hey guysSo I'm taking my first steps in this 4K world and actually by now all I want to do is shoot 4K and export FHD.Probably I would reframe some shots and fake some camera movements in post, so what would be the best approach:- 4K composition + overscaling the footage I want to reframe -> Export in FHD- FHD composition + downscaling all the 4K footage to fit FHD -> Export in FHDI have actually noticed that whenever I make a FHD project, stick all the 4k footage and downscale it, everything just slows down so I guess it takes a lot of processing power... I'm I right?Thanks!Well, you're going to be scaling regardless: scaling up or down. I've done a number of projects with 4K projects delivered as 1080p with downscaling and fake camera moves/zooms, all in 1080p timelines with keyframed scaling/movement. No problems with playback.I'm not sure what NLE you're using, but if you use Premiere Pro, be sure to select graphics card acceleration, the scaling will be MUCH faster. It will also reduce the render time ENORMOUSLY. I have the GTX 980, which has been good. Link to comment Share on other sites More sharing options...
