lafilm Posted January 17, 2016 Share Posted January 17, 2016 I have a tech question if anyone here can help. We "locked" some video files on the Canon 1DC dslr, (for safety) and forgot to "unlock" the video clips in the camera, before we downloaded into Premeire Pro.Now, in Premeire Pro, the files are locked and we cannot edit them.Of course the original CF cards have been swiped, so no going back.Is there a special program that will "unlock" these video clips, or are we out of luck?Thanks guys Link to comment Share on other sites More sharing options...
lafilm Posted January 18, 2016 Author Share Posted January 18, 2016 Never happened to me but have you tried eos movie utility? Franz, thanks for your response. Yes, it's a no go with eos movie utility. You would think that it would work, but it does not. Unfortunately. Hopefully someone out there has made a similar mistake and was able to open up there locked video files. I cannot seem to find anything on this on the Internet. Perhaps someone on this forum? Thanks Link to comment Share on other sites More sharing options...
sandro Posted January 18, 2016 Share Posted January 18, 2016 Will it Work if you put them back on the card and unlock them from the camera? Link to comment Share on other sites More sharing options...
jhnkng Posted January 18, 2016 Share Posted January 18, 2016 Not sure if this is the problem but it's worth a try:If you're on a Mac, go to the files that are locked in the Finder, select the file that's locked, right/two finger click on the locked file and select "Get Info". In the box that comes up, near the top where it has all the date information there should be a checkbox that says "Locked", and if I'm right then it should be checked. You should be able to uncheck the box and close the window and the file will be editable.I'm pretty sure it's a similar process in Windows, opening the file info window in Explorer and there'll be something in there that says locked.Hopefully it's that simple, good luck! Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted January 18, 2016 Administrators Share Posted January 18, 2016 Will it Work if you put them back on the card and unlock them from the camera?If jhnkng's suggestion doesn't work, I'd suggest that would be the only way. The lock is probably a Canon thing and not to do with any standard file system. Maybe take the card into a rental shop and beg them for a 1D C for a couple of mins? Link to comment Share on other sites More sharing options...
Nikkor Posted January 18, 2016 Share Posted January 18, 2016 When premiere imports the files, does it do any transformation? If not you might want to try copying the thing on the CF again in the same place where it's supposed to be and unlock it inside the camera. I have never used a 1dc, but it might be worth the try if it's doable. Link to comment Share on other sites More sharing options...
lafilm Posted January 21, 2016 Author Share Posted January 21, 2016 Not sure if this is the problem but it's worth a try:If you're on a Mac, go to the files that are locked in the Finder, select the file that's locked, right/two finger click on the locked file and select "Get Info". In the box that comes up, near the top where it has all the date information there should be a checkbox that says "Locked", and if I'm right then it should be checked. You should be able to uncheck the box and close the window and the file will be editable.I'm pretty sure it's a similar process in Windows, opening the file info window in Explorer and there'll be something in there that says locked.Hopefully it's that simple, good luck!jhnkng, that did it! Thank you very much!! If jhnkng's suggestion doesn't work, I'd suggest that would be the only way. The lock is probably a Canon thing and not to do with any standard file system. Maybe take the card into a rental shop and beg them for a 1D C for a couple of mins?Thanks Andrew. I appreciate your feedback. jhnkng suggestion worked. Fortunately was able to fix the problem. jhnkng 1 Link to comment Share on other sites More sharing options...
lafilm Posted January 21, 2016 Author Share Posted January 21, 2016 When premiere imports the files, does it do any transformation? If not you might want to try copying the thing on the CF again in the same place where it's supposed to be and unlock it inside the camera. I have never used a 1dc, but it might be worth the try if it's doable.Thanks araucaria for the feedback. I appreciate it. Will it Work if you put them back on the card and unlock them from the camera?Thanks sandro, got it. Link to comment Share on other sites More sharing options...
