NX1user Posted January 23, 2016 Share Posted January 23, 2016 Has anybody here done a shoot with these two cameras? I have an NX1 and will have access to a C100 and am wondering by using C-Log and Gamma DR if it would be possible to match shots. The shots are for a short-film narrative production and the director and I are thinking there's one scene where using two cameras would be better than one, but not if the end result looks like it came out of two vastly different cameras.Any thoughts? Link to comment Share on other sites More sharing options...
Geoff CB Posted January 23, 2016 Share Posted January 23, 2016 Skin tones are similar, I've used my NX1 as a B-cam on a feature I'm working on to a C100. https://vimeo.com/143948850 is an example. @3:13 till 3:31 in the video is cross cutting between an NX1 and a C100 during a wedding ceremony. Bride is C100 (Canon 70-200 L) , Groom is NX1 (50-150 S)EDIT: You will have to grade to match, but they are close enough that it should not distract. Just make sure that you have color matched lenses (I.E. if you use Canon glass on one, use canon glass on another) and you should be fine. Liam 1 Link to comment Share on other sites More sharing options...
tugela Posted January 23, 2016 Share Posted January 23, 2016 My understanding was that only Canon cameras can capture skin tones though. Link to comment Share on other sites More sharing options...
NX1user Posted January 23, 2016 Author Share Posted January 23, 2016 Skin tones are similar, I've used my NX1 as a B-cam on a feature I'm working on to a C100. https://vimeo.com/143948850 is an example. @3:13 till 3:31 in the video is cross cutting between an NX1 and a C100 during a wedding ceremony. Bride is C100 (Canon 70-200 L) , Groom is NX1 (50-150 S)EDIT: You will have to grade to match, but they are close enough that it should not distract. Just make sure that you have color matched lenses (I.E. if you use Canon glass on one, use canon glass on another) and you should be fine. Thanks for the info and the example! That's super helpful. I appreciate it!! Link to comment Share on other sites More sharing options...
caseywilsondp Posted January 23, 2016 Share Posted January 23, 2016 My understanding was that only Canon cameras can capture skin tones though.lol Link to comment Share on other sites More sharing options...
NX1user Posted January 26, 2016 Author Share Posted January 26, 2016 Skin tones are similar, I've used my NX1 as a B-cam on a feature I'm working on to a C100. https://vimeo.com/143948850 is an example. @3:13 till 3:31 in the video is cross cutting between an NX1 and a C100 during a wedding ceremony. Bride is C100 (Canon 70-200 L) , Groom is NX1 (50-150 S)EDIT: You will have to grade to match, but they are close enough that it should not distract. Just make sure that you have color matched lenses (I.E. if you use Canon glass on one, use canon glass on another) and you should be fine. Geoff,Did you use C-LOG and Gamma DR? IF not, do you remember what settings you used? I've got a C100 and a Atoms Ninja for the day and I'm trying to get the footage to match with my NX1. Link to comment Share on other sites More sharing options...
Geoff CB Posted January 27, 2016 Share Posted January 27, 2016 I was not running the C100 that day, though knowing the shooter he was running C-log. I was running modified Gamma DR -2 Saturation, -5 Contrast, -10 sharpness, +5 Black Level Link to comment Share on other sites More sharing options...
NX1user Posted January 27, 2016 Author Share Posted January 27, 2016 I was not running the C100 that day, though knowing the shooter he was running C-log. I was running modified Gamma DR -2 Saturation, -5 Contrast, -10 sharpness, +5 Black LevelThanks man! Link to comment Share on other sites More sharing options...
