Blah Blah Posted October 26, 2016 Share Posted October 26, 2016 Kisaha 1 Link to comment Share on other sites More sharing options...
Marco Tecno Posted October 26, 2016 Share Posted October 26, 2016 I mean...could there be an electronic compatibility with K mount?? The image I linked as the space for lens contacts, but definitely NOT for any "conversion hw". Link to comment Share on other sites More sharing options...
Otto K Posted October 26, 2016 Share Posted October 26, 2016 FWIW http://www.pentaxforums.com/articles/photo-articles/evolution-of-pentax-k-mount.html Seems it uses a single digital pin for communication with lens Link to comment Share on other sites More sharing options...
gd1961 Posted October 28, 2016 Share Posted October 28, 2016 On October 25, 2016 at 7:05 AM, lucabutera said: follow focus, iris control and IS stabilizer, wireless for Canon lens: https://www.produzionidalbasso.com/project/conversion-kit-aputure-dec-canon-lens-samsung-nx/ Luca Which Aputure DEC adapter (EF and EF-S-Mount Lenses to E-Mount Cameras or MFT mount cameras) does this conversion kit work with? Link to comment Share on other sites More sharing options...
lucabutera Posted October 28, 2016 Share Posted October 28, 2016 1 hour ago, gd1961 said: Luca Which Aputure DEC adapter (EF and EF-S-Mount Lenses E-Mount Cameras or MFT mount cameras) does this conversion kit work with? Hi build the NX kit conversion for Aputure Dec EF/E mount. Maybe the MFT version it's the same, but I do not shure of this. Link to comment Share on other sites More sharing options...
Blah Blah Posted October 28, 2016 Share Posted October 28, 2016 Is there any access to picture profiles in the hackable files? Link to comment Share on other sites More sharing options...
ClaudioS Posted October 28, 2016 Share Posted October 28, 2016 On 24 ottobre 2016 at 2:06 AM, SMGJohn said: You sure the monitor locks in 1080p on the NX500? Because I have had no issues with ext monitors when I tested them on my NX500 but I cannot remember the brand names. Ninja2 only does 1080p30, got to use Atomos to shoot 4k with the NX500 external When you connect a HDMI socket to nx 500 is set as movie size to 1920x1080 Link to comment Share on other sites More sharing options...
/Chop N Shoot Films/ Posted October 28, 2016 Share Posted October 28, 2016 On 10/22/2016 at 8:42 PM, kinoseed said: here you go: v2.79 added: Custom overlay - start from ( settings> overlay ). It loads your own custom overlay from the root directory of the sdcard ( sdcard/overlay.png ). Once activated the touchscreen will not work, and histogram will be "frozen" until you deactivate it ( reminder: Ev+Ev/Ok to start the menu for nx500/nx1) note that the preview of the playback will not work, however press "ok" for the video playback to start, and the recorded video with the overlay on top will show. you can make any overlay you like, as 720x480 transparent PNG (replace the overlay.png with it) Amazing. Thank you so much. kinoseed and Kisaha 2 Link to comment Share on other sites More sharing options...
kinoseed Posted October 29, 2016 Share Posted October 29, 2016 6 hours ago, /Chop N Shoot Films/ said: Amazing. Thank you so much. There have been some updates after that version.3x3 Grid (thick lines): with camera-ui not freezing (turn on/off from the menu)note: overlay.png is still available as an option, just add your file and it will work (but the rest of the ui will freeze until you unload), if you want to use the non-freezing 3x3, simply remove the overlay.png from your sdcard.2.35 filmgate: with camera-ui not freezing ( turn on/off with EV+OK)note: if you are on NX1 you need to sacrifice another shortcut to use this one, and simply rename EV_OK.sh to the one you like to use, before installing.note2: it is possible to adjust the filmgate, just add the desired proportion as a parameter, but you need to modify the bash command. ex (for 16/9): /opt/usr/nx-ks/onscreen_235 1.77 /Chop N Shoot Films/, Francesco Tasselli and MountneerMan 3 Link to comment Share on other sites More sharing options...
Enrico Parenti Posted October 29, 2016 Share Posted October 29, 2016 Luca's adapter it's interesting. But the prospect of working with a wireless gadget it's not. I just wished he worked on a smart adapter that enables us to change aperture (only) on EF lenses (no autofocus, no IS as those are less important for video) , changing iris trough the camera (or adapter itself) it's crucial for nx1 future use. THAT is the most important thing to videomakers. Kisaha 1 Link to comment Share on other sites More sharing options...
/Chop N Shoot Films/ Posted October 30, 2016 Share Posted October 30, 2016 I'm going to try this out tomorrow Link to comment Share on other sites More sharing options...
SMGJohn Posted October 31, 2016 Share Posted October 31, 2016 @lucabutera Is it more expensive and complex to make the conversion board fit inside the mount or was it just made so that it is easier to adapt to the dumb mount? Link to comment Share on other sites More sharing options...
lucabutera Posted October 31, 2016 Share Posted October 31, 2016 1 hour ago, SMGJohn said: @lucabutera Is it more expensive and complex to make the conversion board fit inside the mount or was it just made so that it is easier to adapt to the dumb mount? both, I'm practical man, not daydream, what I did is already available today. all other projects take a long time, and Samsung nx1 / 500 needs adapters today. a speed booster adapter and an adapter Aputure are very effective for those who need it and reduce the gap with the competition. SMGJohn, Kisaha and Parker 3 Link to comment Share on other sites More sharing options...
gnoober Posted November 13, 2016 Share Posted November 13, 2016 has anyone tried the Quote nr off from this link? https://github.com/ottokiksmaler/nx500_nx1_modding/blob/master/ST%20Commands.md maybe that will turn off noise reduction? Also there was talk about 3D lenses maybe switching off Noise reduction. Has this been tested? lebigmac 1 Link to comment Share on other sites More sharing options...
lucabutera Posted November 19, 2016 Share Posted November 19, 2016 Possible shoot HDR video as a ML hack? Link to comment Share on other sites More sharing options...
Otto K Posted November 20, 2016 Share Posted November 20, 2016 No, ML HDR mode works by two successive exposures at two different ISOs. We don't have that option here. Link to comment Share on other sites More sharing options...
kinoseed Posted November 21, 2016 Share Posted November 21, 2016 On 11/20/2016 at 9:13 AM, Otto K said: No, ML HDR mode works by two successive exposures at two different ISOs. We don't have that option here. It's been a while since I looked at ML, but if memory serves, they were doing parallel readout of different ISOs, something which I think ALEXA is also doing. So instead of blending two frames, they are reading the sensor at two different ISOs by having different amplification for different row-readouts. Something like - read the odd sensor rows at iso100 and read the even rows at iso1600.Not that this changes the answer... which is No, but they do have access to hardware control, which far supersedes the availability here. lucabutera 1 Link to comment Share on other sites More sharing options...
ReinisK Posted November 22, 2016 Share Posted November 22, 2016 Actually ML had two kinds of HDR. The older one called HDR video was recording whole frames at different exposures. One frame at iso 100, the other at 1600, for example. Then came Dual ISO mode (if I remember correctly it was only for raw video). This mode recorded every line of pixels at different iso values, like Kinoseed wrote. But if talking about the first way, which is HDR video, wouldn't it be possible to write a script that would change the shutter speed or iso for every frame? lucabutera 1 Link to comment Share on other sites More sharing options...
kinoseed Posted November 24, 2016 Share Posted November 24, 2016 On 11/22/2016 at 0:30 PM, ReinisK said: Actually ML had two kinds of HDR. The older one called HDR video was recording whole frames at different exposures. One frame at iso 100, the other at 1600, for example. Then came Dual ISO mode (if I remember correctly it was only for raw video). This mode recorded every line of pixels at different iso values, like Kinoseed wrote. But if talking about the first way, which is HDR video, wouldn't it be possible to write a script that would change the shutter speed or iso for every frame? since we don't actually set iso per frame, a command for iso change will have to be executed at least 50 times a second, to get 25 two-frame iso... frankly i doubt we can get the timing right, even if the commands are executed fast enough, which is doubtful Is such footage useful in reality? I guess you gen use something like Fusion to blend both frames... if the objects are not moving fast. Link to comment Share on other sites More sharing options...
Blah Blah Posted November 24, 2016 Share Posted November 24, 2016 I think you can use something like Twixtor before blending the frames. Or you could composite parts, like sky, windows etc. I think the results could be usable. Link to comment Share on other sites More sharing options...
