lucabutera Posted February 2, 2017 Share Posted February 2, 2017 For NX1 NX-KS Hack users: Someone more experienced than me in programming is requested to test the Wifi bitrate hack on NX1 camera. I received this directions from @KinoSeed " here is the remote storage plugin: https://github.com/mewlips/nx-netfs but this is a bit tricky to install if you simply want to test the speed - turn on the FTP with nk-ks, it's same at telnet - (EV+MOBILE), and using FTP client (for transfering files) connect to the camera on the IP shown on the camera-screen." Thank you. Link to comment Share on other sites More sharing options...
Marco Tecno Posted February 2, 2017 Share Posted February 2, 2017 This is very interesting, but I didn't understand exactly what it should/could do: transfer video on wifi directly? If so...in which format? Link to comment Share on other sites More sharing options...
mnewxcv Posted February 8, 2017 Share Posted February 8, 2017 Is there any way for my nx500 to be used for live streaming like a web cam? Link to comment Share on other sites More sharing options...
lucabutera Posted February 8, 2017 Share Posted February 8, 2017 4 hours ago, mnewxcv said: Is there any way for my nx500 to be used for live streaming like a web cam? Follow this link: http://support-us.samsung.com/spsn/detail.jsp?ctg_id=1000&sub_ctg_id&live_id=11&video_id=4179489244001 mnewxcv 1 Link to comment Share on other sites More sharing options...
mnewxcv Posted February 9, 2017 Share Posted February 9, 2017 14 hours ago, lucabutera said: Follow this link: http://support-us.samsung.com/spsn/detail.jsp?ctg_id=1000&sub_ctg_id&live_id=11&video_id=4179489244001 I should have been more clear. I mean stream live to the internet, from a computer (like a webcam, ie skyping) Link to comment Share on other sites More sharing options...
lucabutera Posted February 10, 2017 Share Posted February 10, 2017 On 9/2/2017 at 1:36 PM, mnewxcv said: Avrei dovuto essere più chiaro. Insomma lo streaming in diretta a Internet, da un computer (come una webcam, ovvero skyping) http://www.samsung.com/ie/support/skp/faq/1024999 mnewxcv 1 Link to comment Share on other sites More sharing options...
mnewxcv Posted February 10, 2017 Share Posted February 10, 2017 3 hours ago, lucabutera said: http://www.samsung.com/ie/support/skp/faq/1024999 thanks but it doesnt work. I guess you cannot use the nx series cameras as webcams. Link to comment Share on other sites More sharing options...
lucabutera Posted February 11, 2017 Share Posted February 11, 2017 On 10/2/2017 at 9:07 PM, mnewxcv said: thanks but it doesnt work. I guess you cannot use the nx series cameras as webcams. mnewxcv, SMGJohn, Kisaha and 1 other 4 Link to comment Share on other sites More sharing options...
mnewxcv Posted February 12, 2017 Share Posted February 12, 2017 16 hours ago, lucabutera said: First, thank you very much for really trying to help me through this for days now. Second, the video is great and I am sure a lot of users here could benefit from it. Third, unfortunately it just seems to be impossible for the nx500. The nx500 does not support tethered connection (only the nx1 does), and the nx500 has no setting for USB connection type (which you select "remote" on the nx1) and only functions in mass storage mode. Even if it could be hacked to allow remote usb connection, I am not sure the software would recognize the camera since samsung remote studio may be coded to only work with the NX1. Again, thank you very much for your effort to help me. It is appreciated. Link to comment Share on other sites More sharing options...
Otto K Posted February 12, 2017 Share Posted February 12, 2017 On 1/19/2017 at 8:36 PM, thelongdivider said: Has any work been put into making other file systems accessible in the NX1/NX500? In particular, I would like to use an Ext4 formatted SD card instead of an exfat one. Yes, I have compiled several modules and toyed with them and they work, even NFS mount works (but slowly, very slowly). I didn't want to modify root more than I had to so I put modules in /opt. Following is a proof of concept via file containing the ext2 file system. Quote [root@drime5 ~]# ls -la /opt/usr/devel/modules/lib/modules/3.5.0/ total 24184 drwxr-xr-x 2 root root 4096 Oct 4 23:56 . drwxr-xr-x 3 root root 4096 Oct 4 23:09 .. -rwxr-xr-x 1 root root 102695 Oct 4 23:55 ansi_cprng.ko -rwxr-xr-x 1 root root 758761 Oct 4 23:55 bt8887.ko -rwxr-xr-x 1 root root 346648 Oct 4 23:55 c67x00.ko -rwxr-xr-x 1 root root 3215833 Oct 4 23:55 cfg80211.ko -rwxr-xr-x 1 root root 844435 Oct 4 23:55 ext2.ko -rwxr-xr-x 1 root root 203361 Oct 4 23:55 isp116x-hcd.ko -rwxr-xr-x 1 root root 291720 Oct 4 23:55 isp1362-hcd.ko -rwxr-xr-x 1 root root 290897 Oct 4 23:55 isp1760.ko -rwxr-xr-x 1 root root 2333351 Oct 4 23:55 lockd.ko -rwxr-xr-x 1 root root 431148 Oct 4 23:55 mlan.ko -rw-r--r-- 1 root root 34781 Oct 4 23:56 modules.alias -rw-r--r-- 1 root root 40463 Oct 4 23:56 modules.alias.bin -rw-r--r-- 1 root root 0 Oct 4 23:56 modules.builtin.bin -rw-r--r-- 1 root root 493 Oct 4 23:56 modules.dep -rw-r--r-- 1 root root 1819 Oct 4 23:56 modules.dep.bin -rw-r--r-- 1 root root 52 Oct 4 23:56 modules.devname -rw-r--r-- 1 root root 131 Oct 4 23:56 modules.softdep -rw-r--r-- 1 root root 20085 Oct 4 23:56 modules.symbols -rw-r--r-- 1 root root 24561 Oct 4 23:56 modules.symbols.bin -rwxr-xr-x 1 root root 4122867 Oct 4 23:55 nfs.ko[root@drime5 ~]# dd if=/dev/zero of=/sdcard/ext2 bs=1M count=32 32+0 records in 32+0 records out 33554432 bytes (34 MB) copied, 0.8888 s, 37.8 MB/s [root@drime5 ~]# mkfs.ext2 /sdcard/ext2 mke2fs 1.41.9 (22-Aug-2009) /sdcard/ext2 is not a block special device. Proceed anyway? (y,n) y Filesystem label= OS type: Linux Block size=1024 (log=0) Fragment size=1024 (log=0) 8192 inodes, 32768 blocks 1638 blocks (5.00%) reserved for the super user First data block=1 Maximum filesystem blocks=33554432 4 block groups 8192 blocks per group, 8192 fragments per group 2048 inodes per group Superblock backups stored on blocks: 8193, 24577 Writing inode tables: done Writing superblocks and filesystem accounting information: done This filesystem will be automatically checked every 36 mounts or 180 days, whichever comes first. Use tune2fs -c or -i to override.[root@drime5 ~]# modprobe -d /opt/usr/devel/modules/ ext2 [root@drime5 ~]# lsmod Module Size Used by ext2 49246 0 sd8xxx 459501 1 mlan 391219 1 sd8xxx cfg80211 172035 1 sd8xxx bt8887 722073 1 exfat_fs 27976 1 exfat_core 96435 1 exfat_fs[root@drime5 ~]# losetup -f /dev/loop1[root@drime5 ~]# losetup /dev/loop1 /sdcard/ext2 [root@drime5 ~]# mount /dev/loop1 /tmp/ext2/ [root@drime5 ~]# df -h Filesystem Size Used Avail Use% Mounted on rootfs 507M 480M 23M 96% / /dev/root 507M 480M 23M 96% / devtmpfs 70M 0 70M 0% /dev tmpfs 250M 28K 250M 1% /dev/shm tmpfs 250M 824K 249M 1% /run tmpfs 250M 0 250M 0% /sys/fs/cgroup tmpfs 250M 2.2M 248M 1% /tmp tmpfs 250M 2.2M 248M 1% /var/log tmpfs 250M 2.2M 248M 1% /var/run /dev/loop0 22M 22M 0 100% /usr/share/locale /dev/mmcblk0p11 74M 35M 39M 48% /opt /dev/mmcblk0p14 2.3G 141M 2.1G 7% /opt/usr /dev/mmcblk1 30G 15G 16G 47% /opt/storage/sdcard/dev/loop1 31M 14K 29M 1% /tmp/ext2 For example, to mount NFS from server A.B.C.D to store images directly to it (playback is very slow): busybox mount -o nolock,rw,hard,intr,vers=3 -t nfs A.B.C.D:/mnt/export /opt/storage/sdcard/DCIM/ So, it can be done, but it will be unmounted every time the camera goes to sleep, etc. It can be remounted using auto scripts from keyscan or more feature complete custom mod pack. I wanted to make encrypted container and mount it to DCIM but I haven't had free time lately (it's entirely doable, openssl shows up to 50MB/s depending on the algorithm). type 16 bytes 64 bytes 256 bytes 1024 bytes 8192 bytes rc4 41978.37k 46139.88k 47931.48k 48086.52k 48323.96k aes-128 cbc 20183.59k 21377.81k 21916.21k 21961.44k 21975.41k aes-192 cbc 17364.14k 18274.48k 18664.45k 18798.15k 18802.16k aes-256 cbc 15348.79k 16012.25k 16353.15k 16344.79k 16396.00k type 16 bytes 64 bytes 256 bytes 1024 bytes 8192 bytes des cbc 12303.37k 12949.75k 13082.44k 13153.05k 13177.24k des ede3 4694.62k 4808.55k 4812.70k 4835.26k 4821.14k blowfish cbc 21719.40k 24047.88k 24643.79k 24752.36k 24857.40k All that said, it turns out that performance wise (ex)FAT is very efficient and you wouldn't get better performance using other file systems (I did not test F2FS though). Link to comment Share on other sites More sharing options...
Otto K Posted February 12, 2017 Share Posted February 12, 2017 @mnewxcv have you seen this https://mewlips.github.io/nx-remote-controller-mod/ ? It's also included in NX-KS since version 2.56 and it works on NX500 (but at screen resolution, so quality not high). Link to comment Share on other sites More sharing options...
mnewxcv Posted February 13, 2017 Share Posted February 13, 2017 3 hours ago, Otto K said: @mnewxcv have you seen this https://mewlips.github.io/nx-remote-controller-mod/ ? It's also included in NX-KS since version 2.56 and it works on NX500 (but at screen resolution, so quality not high). thanks for that, looks like a cool piece of software i had not yet tried out. Much prefer it to the samsung app. However, seems the live video stream is like 1-2fps. If only something like that was made for usb tethered connection so the resolution and bitrate could be higher. The nx500/nx1 have a usb 3.0 port don't they? Link to comment Share on other sites More sharing options...
lucabutera Posted March 1, 2017 Share Posted March 1, 2017 After reading this article, you wait before switching to GH5 https://***URL not allowed***/panasonic-gh5-lab-review-10-bit-flaws-vlog-free-gh5-lut/ Marco Tecno 1 Link to comment Share on other sites More sharing options...
SMGJohn Posted March 2, 2017 Share Posted March 2, 2017 A wise man once said, "The audience does not care about image quality, they care about composition and story" This is even more true for the fact that VHS even made such a success as it did despite Beta being the superior format with superior picture quality, Laserdisc even more so and VideoCD outselling DVD's until 2004 Marco Tecno 1 Link to comment Share on other sites More sharing options...
kinoseed Posted March 7, 2017 Share Posted March 7, 2017 On 3/1/2017 at 11:02 PM, lucabutera said: After reading this article, you wait before switching to GH5 https://***URL not allowed***/panasonic-gh5-lab-review-10-bit-flaws-vlog-free-gh5-lut/ wow... how.. disappointing I wish they compared it with the 180Mbps HEVC of Nx500/Nx1 too lucabutera, SMGJohn and kidzrevil 3 Link to comment Share on other sites More sharing options...
Kisaha Posted March 8, 2017 Share Posted March 8, 2017 I wish we could up our game a bit, this codec obviously has its limitations, high ISO performance is not great at all, the noise reduction is killing our video, and I just wish I could magnify for focus while recording. All in all, everything else is super amazing! Kino, you have to pull a rabbit out of your hut dude, don't you have any Balkanic super hacker friends?! Marco Tecno and lucabutera 2 Link to comment Share on other sites More sharing options...
kinoseed Posted March 9, 2017 Share Posted March 9, 2017 On 3/8/2017 at 2:04 AM, Kisaha said: I wish we could up our game a bit, this codec obviously has its limitations, high ISO performance is not great at all, the noise reduction is killing our video, and I just wish I could magnify for focus while recording. All in all, everything else is super amazing! Kino, you have to pull a rabbit out of your hut dude, don't you have any Balkanic super hacker friends?! :)) they have their hands full with "Vault 7" unless someone from Samsung makes the dev tools for the programmable hardware available, I think this is as far things will go. besides (even with silent shutter) camera's life is not indefinite, so maybe in a year the people who still use them will be down to a handful (if any) Link to comment Share on other sites More sharing options...
Kisaha Posted March 9, 2017 Share Posted March 9, 2017 haha! I am sure they do! Nuh..they are not that sensitive, cameras do not broke that easily, you see in various forums that only a few complain about broken NXes, and usually the top dial somehow do not work properly. They seem very well implemented, plus there are quite a lot new ones from Korea. From various sources around the net (and your Fabebook as well) it seems like there are a lot more NX users than I though they were, just not enough obviously. As it seems, my NX1/NX500/NX3000+all the lenses I need (except the 50-150 I do not have) will keep me good company for a few more years. The things I mentioned above are the only concerns, but a breakthrough in any of these could keep the cameras relative for at least a couple more years (until 2020), do not even want to know what will happen if we can extract raw, somehow, out of these, people are buying 5DmarkII for their Magic Lantern capabilities! We will see, it is an interesting journey nevertheless, and thanks for all your effort, much obliged! Marco Tecno, Juxx989, SMGJohn and 1 other 4 Link to comment Share on other sites More sharing options...
Kisaha Posted March 9, 2017 Share Posted March 9, 2017 http://image-sensors-world.blogspot.gr/2017/02/samsung-mobile-processor-supports-4k.html?spref=tw I want this on my NX1 s' il vous plait! kinoseed and Juxx989 2 Link to comment Share on other sites More sharing options...
Marco Tecno Posted March 9, 2017 Share Posted March 9, 2017 I'd even get a nx2 with that on board, provided that it has internal 10bit at 4:2:2. Link to comment Share on other sites More sharing options...
