sidi Posted March 13, 2016 Share Posted March 13, 2016 13 minutes ago, Syme said: Seems to me like there's a pretty good chance Samsung just used the fast dedicated 4k HEVC encoder they were already developing for their cell phones. I would also assume it uses dedicated chip for HEVC encoding. On 3/7/2016 at 3:20 AM, Chant said: page 3 main pcb shows the full sd slot.https://fccid.io/pdf.php?id=2394050 Higher resolution photos would help to identify at least some of the chips. 12 hours ago, Marco Tecno said: Chant and sidi: http://***URL removed***/forums/post/57361842 Thanks, still looking for NX1 bottom connector. Link to comment Share on other sites More sharing options...
Syme Posted March 13, 2016 Share Posted March 13, 2016 I'm pretty sure the encoder is integrated into the main SoC. I can't imagine Samsung using a separate physical chip when the main one is already a custom SoC they made for their cameras. sidi 1 Link to comment Share on other sites More sharing options...
lucabutera Posted March 13, 2016 Share Posted March 13, 2016 On 6/3/2016 at 9:56 AM, sandro said: 8 minutes ago, sidi said: 14 hours ago, Chant said: There has been a few stating that they would like to tip/donate, which would of course be muchhelp,, as I seem to be doing this more than my 9-5 haha! But it is not at a quantifiable stage at the moment, What I have found out is pretty much just a key, and if the key can open the lock is not yet determined. Even with the sdk things of this nature are not 100% At any step of the way if they did something undocumented it can halt progress to a point the modification cant be done. Ive been lucky so far with things is all! But if knowing that what Im doing may not bring a firmware mod to light people still wish to donate then I can put something together. But I started this not knowing there was anyone wanting this camera modded, and I would still do this if no one wanted to tip/donate. That being said the next stages of what I am doing are copious research. There are white paper behind paywalls but my local university seems to have most of the books on file so I will be acquiring those to get a better idea of the way samsung chose to code. Personally I am also interested in the lens mount for a working adapter to other lens systems. So the control files are something I am also looking into. As well as if hevc is the best choice for encoding or if something like the redcoderaw would be more suitable which is just their modded version of mjpeg2000. dct vs wavelet is something interesting to read about. Pavel Mašek 1 Link to comment Share on other sites More sharing options...
Chant Posted March 13, 2016 Share Posted March 13, 2016 The samsung srp research is also to see if thats what they used, but it it was an onboard hevc asic there would be a lot less code for what Im finding if you go by what tends to control hardware. With luck its srp because Ive found examples of it beings used to do a full 8k6p stream with a very small srp block and the drime-v is a very different beast from the exynos. But ill just leave these excerpts here. "eSensorModeRollingStillModeOff eSensorModeRollingStillModeOn eSensorModePanoramaFull" "30CBayerImageInformationLiveview 34CBayerImageInformationLiveviewWide 36CBayerImageInformationLiveview120fps 36CBayerImageInformationLiveview240fps" "LVIEW_PP_CORE_UD LVIEW_PP_CORE_UD_24FPS LVIEW_PP_CORE_120FPS LVIEW_PP_CORE_240FPS" "eFrameRate24fps eFrameRate25fps eFrameRate30fps eFrameRate33_3fps eFrameRate40fps eFrameRate50fps eFrameRate60fps eFrameRate100fps eFrameRate120fps eFrameRate200fps eFrameRate240fps" "binningoff HVbinningon Hbinningon Vbinningon" lucabutera, SMGJohn and saintsimon2016 3 Link to comment Share on other sites More sharing options...
Marco Tecno Posted March 13, 2016 Share Posted March 13, 2016 Chant: Not sure if I understand. You mean that if nx1 has this programmable chip, it could be able to output at 240fps? Doesn't this depend also on the sensor? 3 hours ago, sidi said: Thanks, still looking for NX1 bottom connector. You mean the one for the grip? Link to comment Share on other sites More sharing options...
Chant Posted March 13, 2016 Share Posted March 13, 2016 The code excerpts I posted are from the firmware. The statement about the camera being able to do 240fps is something they didnt remove. Also found a bunch of tizen watch stuff. Bad housekeeping is good news. But I have yet to find a video output path that is concise. Tons of data on the hevc and everything else, but its what pointed me to the srp and needing to do more research. There way a camera would dump data to an onboard hevc is pretty well documented. Follow the mipi csi-2 bridge a few steps to get to the encoder. but the difference is, if it was indeed just a "hard" core hevc in the drime-v it would be more self contained. Taking what I know of chip construction and "hard" core asic implementation. The more I do the more I find on how it works and what can be done. Marco Tecno, Kisaha, MKSN and 4 others 7 Link to comment Share on other sites More sharing options...
hirsti Posted March 13, 2016 Share Posted March 13, 2016 Here is a quick video showing the brilliant work Otto has been doing on the NX500 and NX1 using the SD Card hack. All details can be found on https://github.com/ottokiksmaler/nx500 Marco Tecno, Liam, MountneerMan and 6 others 9 Link to comment Share on other sites More sharing options...
sidi Posted March 13, 2016 Share Posted March 13, 2016 1 hour ago, Marco Tecno said: Chant: Not sure if I understand. You mean that if nx1 has this programmable chip, it could be able to output at 240fps? Doesn't this depend also on the sensor? You mean the one for the grip? That's the one. Link to comment Share on other sites More sharing options...
Marco Tecno Posted March 13, 2016 Share Posted March 13, 2016 I guess you can only pass some energy (external battery) and few commands from there, like shutter. Link to comment Share on other sites More sharing options...
Claudio Lisco Posted March 13, 2016 Share Posted March 13, 2016 this process i work also with 3d part lens? Link to comment Share on other sites More sharing options...
sidi Posted March 13, 2016 Share Posted March 13, 2016 2 hours ago, Marco Tecno said: I guess you can only pass some energy (external battery) and few commands from there, like shutter. Sure, I just don't have the grip to probe pogo pins on it. Link to comment Share on other sites More sharing options...
Popular Post hirsti Posted March 13, 2016 Popular Post Share Posted March 13, 2016 Here is a quick video showing the NX1 and NX500 SD Card Hack for Focus Buttons. This program allows you to record up to 6 focal points, these are stored on the SD card and will work after a camera restart. This works for photography, especially good for storing infinity focal point to re-use when it is dark for Astro Photography. Works in video allows you to do focus pulling from one focal point to another. Thanks again to Otto for all the hard work, All details can be found on https://github.com/ottokiksmaler/nx500 RieGo, Kisaha, MountneerMan and 12 others 15 Link to comment Share on other sites More sharing options...
Marco Tecno Posted March 13, 2016 Share Posted March 13, 2016 Thx for these informative videos. The nx community is stronger than ever. Link to comment Share on other sites More sharing options...
Administrators Popular Post Andrew Reid Posted March 14, 2016 Administrators Popular Post Share Posted March 14, 2016 Some great work here Thread is now a sticky topic. kidzrevil, saintsimon2016, sandro and 8 others 11 Link to comment Share on other sites More sharing options...
MountneerMan Posted March 14, 2016 Share Posted March 14, 2016 I really want to see this story picked up by some popular camera news websites, help build some more momentum. Hanriverprod 1 Link to comment Share on other sites More sharing options...
Hanriverprod Posted March 14, 2016 Share Posted March 14, 2016 2 minutes ago, MountneerMan said: I really want to see this story picked up by some popular camera news websites, help build some more momentum. Good idea, the angle could be: Samsung abandons their loyal nx1 customers, but a community tries to keep the future of the camera alive. Marco Tecno, Pavel Mašek, Beritar and 1 other 4 Link to comment Share on other sites More sharing options...
Connor Rickman Posted March 14, 2016 Share Posted March 14, 2016 6 hours ago, hirsti said: Here is a quick video showing the NX1 and NX500 SD Card Hack for Focus Buttons. This program allows you to record up to 6 focal points, these are stored on the SD card and will work after a camera restart. This works for photography, especially good for storing infinity focal point to re-use when it is dark for Astro Photography. Works in video allows you to do focus pulling from one focal point to another. Thanks again to Otto for all the hard work, All details can be found on https://github.com/ottokiksmaler/nx500 This is an amazing advancement for 1-person shooters. Any chance it could work via wifi and the remote app? Link to comment Share on other sites More sharing options...
kidzrevil Posted March 14, 2016 Author Share Posted March 14, 2016 2 hours ago, Andrew Reid said: Some great work here Thread is now a sticky topic. Thank you for the support. Link to comment Share on other sites More sharing options...
Geoff CB Posted March 14, 2016 Share Posted March 14, 2016 6 hours ago, hirsti said: Here is a quick video showing the NX1 and NX500 SD Card Hack for Focus Buttons. This program allows you to record up to 6 focal points, these are stored on the SD card and will work after a camera restart. This works for photography, especially good for storing infinity focal point to re-use when it is dark for Astro Photography. Works in video allows you to do focus pulling from one focal point to another. Thanks again to Otto for all the hard work, All details can be found on https://github.com/ottokiksmaler/nx500 In certain focus pulling situations this will be incredibly useful. Thanks Otto! Great to see continued work on this project. Pavel Mašek 1 Link to comment Share on other sites More sharing options...
Liam Posted March 14, 2016 Share Posted March 14, 2016 awesome! has anyone tried the 2.5k on the nx500 yet? Link to comment Share on other sites More sharing options...
