undecided Posted February 8, 2016 Share Posted February 8, 2016 26 minutes ago, Marco Tecno said: in the meanwhile, on dpr: http://***URL removed***/forums/post/57238559 Guys, I am developer but being a developer is different than being a hacker. A developer works with tools that give them the functionality they need. A hacker may have to invent tools for platforms where such tools are not readily available. If we had a publically available SDK and a method to sign and upload the firmware onto the NX1 I am sure I could make changes to it. Matthias Scheja, Pavel Mašek, vaga and 3 others 6 Link to comment Share on other sites More sharing options...
Marco Tecno Posted February 9, 2016 Share Posted February 9, 2016 Undecided, a SDK exists to create apps for pc to tether the nx1. You could still request it, I guess. But from there you won't likely be able to change inner parameters, like bitrate, fps, resolution and so on. But some ppl found some 'backdoors' for uploading scripts and programs to nx. And a guy, who totally disappeared, was able to get rid of recording time limit on nx300, by directly modifying the fw somehow. Pavel Mašek and vaga 2 Link to comment Share on other sites More sharing options...
Pavel D Prichystal Posted February 9, 2016 Share Posted February 9, 2016 Undecided: And can you? Get it or try to get it? As we are neither developers or hackers, "some" of us have no knowledge of what can we do for you to move it forward Link to comment Share on other sites More sharing options...
NX1user Posted February 9, 2016 Share Posted February 9, 2016 I mentioned on personal-view that people here were asking for Vitaliy's opinion and he directed me to this thread: http://www.personal-view.com/talks/discussion/7404/samsung-nx-nx300-cameras-hack#Item_18 Link to comment Share on other sites More sharing options...
Pavel D Prichystal Posted February 9, 2016 Share Posted February 9, 2016 Undecided, can you actually go through it and tell is if in your eyes this is helpful and can be used by somebody skillful to actually making upgrades out of it? Or any other person who actually understand coding/hacking/developing? Link to comment Share on other sites More sharing options...
M Carter Posted February 9, 2016 Share Posted February 9, 2016 2 minutes ago, Pavel D Prichystal said: Undecided, can you actually go through it and tell is if in your eyes this is helpful and can be used by somebody skillful to actually making upgrades out of it? Or any other person who actually understand coding/hacking/developing? Indeed, this is all just wishful thinking without a developer that can unravel the pipeline and (probably a good idea) someone with experience in compression and image pipelines. It's all pretty meaningless until a software engineer gets ID'd. Link to comment Share on other sites More sharing options...
undecided Posted February 9, 2016 Share Posted February 9, 2016 Quick google search for "Samsung Tizen firmware camera" brought me to this article http://www.tizenexperts.com/2015/08/samsung-nx1-smart-camera-software-firmware-updated-to-version-v-1-40/ There is a post by a gentleman named Nabil who claims to have made the camera record 6K at 240fps in 'debug' mode. We probably need to contact him. p.s. I am downloading an NX1.zip file from here: http://opensource.samsung.com/reception/receptionSub.do?method=sub&sub=T&menu_item=photography&classification1=digital cameras Not sure if it's the full OS for the NX1. Marco Tecno 1 Link to comment Share on other sites More sharing options...
SMGJohn Posted February 9, 2016 Share Posted February 9, 2016 Its come to my attention that no one has posted the Open Source code to the NX1, its a 1.3GB sized .zip file its simply just called NX1.zip, maybe there is something in there to help you guys? http://opensource.samsung.com/reception/receptionSub.do?method=sub&sub=T&menu_item=photography&classification1=digital%20cameras vaga 1 Link to comment Share on other sites More sharing options...
undecided Posted February 9, 2016 Share Posted February 9, 2016 5 hours ago, M Carter said: Indeed, this is all just wishful thinking without a developer that can unravel the pipeline and (probably a good idea) someone with experience in compression and image pipelines. It's all pretty meaningless until a software engineer gets ID'd. If we have the full source code everything is doable as long as the hardware can handle it. I can't go into much detail on a web post but basically we can try changing parameters in the source code, then try it. If it doesn't work, try different values. Rinse and repeat until it works. It also depends on how clean the source code is. If it is well documented, the job would be easier. 11 minutes ago, SMGJohn said: Its come to my attention that no one has posted the Open Source code to the NX1, its a 1.3GB sized .zip file its simply just called NX1.zip, maybe there is something in there to help you guys? http://opensource.samsung.com/reception/receptionSub.do?method=sub&sub=T&menu_item=photography&classification1=digital%20cameras Downloading it as we speak but from what I've read, it probably contains only the open source components as Samsung is required buy the licensing to release any changes they made to the open source components. Link to comment Share on other sites More sharing options...
SMGJohn Posted February 10, 2016 Share Posted February 10, 2016 41 minutes ago, undecided said: Downloading it as we speak but from what I've read, it probably contains only the open source components as Samsung is required buy the licensing to release any changes they made to the open source components. I contacted Samsung regarding the release of a developer tool for the NX1, however Samsung US said no such tool was available for them to release. I have no Korean knowledge so if someone would be kind enough to try contact Samsung Korea because they definitely sit on the tools for the camera, they already pulled it out of Europe, America and Australia. As for the Source code, its at least something to begin with, we have more than what Magic Lantern started with so I am not sure we are in a position to complain but developer tools would be welcomed if someone had them, as far as I can understand its quite possible to unlock features through the Tizen OS however implementation to hardware level has to be done differently as its a seprated code apparently so if we wanted lets say CinemaDNG we would have to go into hardware level code in order to implement it but it should be possible to remove the 29 minute record limit through Tizen OS. I might be wrong though but its how I understood it from reading countless of forums regarding the hacking of NX1, none has ever come to fruit this one has to be the most active one I ever seen. Pavel Mašek and vaga 2 Link to comment Share on other sites More sharing options...
derderimmermuedeist Posted February 10, 2016 Share Posted February 10, 2016 +1 including 100€ as donation - no Time limit - higher bitrate - UHD 60 fps - LOG - UHD/30p 10bit Beritar and vaga 2 Link to comment Share on other sites More sharing options...
Marco Tecno Posted February 10, 2016 Share Posted February 10, 2016 Is he Nabil Fathi? The guy who claimed to have hacked a7s? Link to comment Share on other sites More sharing options...
Jimmy Posted February 10, 2016 Share Posted February 10, 2016 The first thing any potential hacker should do is rlist what simply isn't possible or would be a huge undertaking. Things like log, 10 bit etc, 4K/60fps seem like they would be very tough to implement and test, whereas upping the bitrate might be a simpler task. Pavel Mašek 1 Link to comment Share on other sites More sharing options...
Nikkor Posted February 10, 2016 Share Posted February 10, 2016 Look at nikon hacker, the guy finally finds a way to get raw video, and suddenly dissapears forever. Geoff CB 1 Link to comment Share on other sites More sharing options...
undecided Posted February 10, 2016 Share Posted February 10, 2016 Early update, I scoured the source archive looking for any hints of where the HEVC bitrate may be defined. I did not see anything. I did not see any evidence of the camera UI in there either. There are a few binary folders and that means that some parts are just delivered compiled already and not in source code which means they will be hard, if not impossible to modify. Link to comment Share on other sites More sharing options...
Marco Tecno Posted February 10, 2016 Share Posted February 10, 2016 Yes, most important things are just binary. Meaning that you should look into them with hex editor and see if you find interesting 'numbers' or variables... Link to comment Share on other sites More sharing options...
archipelago Posted February 10, 2016 Share Posted February 10, 2016 hi, i bought NX1 couple of weeks ago, so this i'm also following this 'hack' initiative.. found some header files in the NX1.zip. Unzip packages and go to standard-armv7l\usr\include\video\drime5. I'm no C++ programmer, but i guess there are definitions for the video settings there .. so maybe that would be helpful to someone who 'knows'... sandro 1 Link to comment Share on other sites More sharing options...
MountneerMan Posted February 11, 2016 Share Posted February 11, 2016 9 hours ago, archipelago said: hi, i bought NX1 couple of weeks ago, so this i'm also following this 'hack' initiative.. found some header files in the NX1.zip. Unzip packages and go to standard-armv7l\usr\include\video\drime5. I'm no C++ programmer, but i guess there are definitions for the video settings there .. so maybe that would be helpful to someone who 'knows'... I downloaded the source code a while ago and looked at it briefly but never found anything but after reading this tread I was inspired to take a second look and I found a whole folder of C++ files in the kernel package under driver\media\drime5\hevc. I even found this comment in one of them( d5_enc_host_ctrl.c). // Target cycle of 32x32 CU, P-slice // Mode1, LD_LC: 870 -- UHD30p @266MHz w/ 20% margin // Mode2, LD_HE: 1307 -- FHD60p @200MHz w/ 20% margin // Mode3, RA_LC: 1752 -- FHD60p @266MHz w/ 20% margin // Mode4, RA_HE: 2420 -- FHD30p @200MHz w/ 20% margin // Mode5, AI : 870 -- UHD30p @266MHz w/ 20% margin Does anyone here know anything about GNU licenses? My thinking is if they are using the drime5 CPU to code and decode HEVC it would need to be built into the Tizen kernel and would need to be open source. But I dont know for sure. I think its all there folks we just need a Linux/Tizen master to take a look at it. Pavel Mašek and kidzrevil 2 Link to comment Share on other sites More sharing options...
Syme Posted February 11, 2016 Share Posted February 11, 2016 I know a bit about GNU licenses and the Linux kernel, and the short answer is that no, they don't need to include anything about HEVC encoding in the open-source kernel. They could if they wanted to, but they don't have to. All Android phones are like that. The Linux kernel is running on standard ARM cores inside the DRIME5, with binary-blob drivers for things like the GPU, HEVC encoder, etc. Link to comment Share on other sites More sharing options...
kidzrevil Posted February 11, 2016 Author Share Posted February 11, 2016 5 hours ago, MountneerMan said: I downloaded the source code a while ago and looked at it briefly but never found anything but after reading this tread I was inspired to take a second look and I found a whole folder of C++ files in the kernel package under driver\media\drime5\hevc. I even found this comment in one of them( d5_enc_host_ctrl.c). // Target cycle of 32x32 CU, P-slice // Mode1, LD_LC: 870 -- UHD30p @266MHz w/ 20% margin // Mode2, LD_HE: 1307 -- FHD60p @200MHz w/ 20% margin // Mode3, RA_LC: 1752 -- FHD60p @266MHz w/ 20% margin // Mode4, RA_HE: 2420 -- FHD30p @200MHz w/ 20% margin // Mode5, AI : 870 -- UHD30p @266MHz w/ 20% margin Does anyone here know anything about GNU licenses? My thinking is if they are using the drime5 CPU to code and decode HEVC it would need to be built into the Tizen kernel and would need to be open source. But I dont know for sure. I think its all there folks we just need a Linux/Tizen master to take a look at it. This looks promising ! Link to comment Share on other sites More sharing options...
