Geoff CB Posted September 5, 2016 Share Posted September 5, 2016 4 minutes ago, kinoseed said: for NX500: Mod-menu > Custom Func. > Mod Resolutions > (select) DC as 2.5K in camera-settings set and record DC video, it will be 2.5K at 24fps That is amazing, does the bitrates carry over as well, 150 mbps+? Thank you so much for the info and work on this. When my NX500 arrives I plan to do an extensive testing with this mode. Link to comment Share on other sites More sharing options...
kinoseed Posted September 5, 2016 Share Posted September 5, 2016 5 minutes ago, Geoff CB said: That is amazing, does the bitrates carry over as well, 150 mbps+? Thank you so much for the info and work on this. When my NX500 arrives I plan to do an extensive testing with this mode. yes, bitrate stays the same if not modified in the menu for 4K (by default it's 180Mbps) Cheers Link to comment Share on other sites More sharing options...
lucabutera Posted September 5, 2016 Share Posted September 5, 2016 29 minutes ago, kinoseed said: yes, bitrate stays the same if not modified in the menu for 4K (by default it's 180Mbps) Cheers it's possible UHD 50fps on Nx1? Tnx! Link to comment Share on other sites More sharing options...
kinoseed Posted September 6, 2016 Share Posted September 6, 2016 9 hours ago, lucabutera said: it's possible UHD 50fps on Nx1? Tnx! UHD at 50/60 fps was reported as possible only as HDMI output (via the VGA channel), however I have not personally tested it. lucabutera 1 Link to comment Share on other sites More sharing options...
Sten Posted September 6, 2016 Share Posted September 6, 2016 3 hours ago, kinoseed said: UHD at 50/60 fps was reported as possible only as HDMI output (via the VGA channel), however I have not personally tested it. Can't you write a script for RAW video via tha VGA channel? Link to comment Share on other sites More sharing options...
Pavel Mašek Posted September 6, 2016 Share Posted September 6, 2016 BTW - some new nice comment by Andrew regarding NX1 here :-) 1st and 3rd post lucabutera 1 Link to comment Share on other sites More sharing options...
kinoseed Posted September 7, 2016 Share Posted September 7, 2016 19 hours ago, Sten said: Can't you write a script for RAW video via tha VGA channel? for recording - nope if you think of using HDMI - no idea (and I can't test it here) Change the VGA resolution, and see what comes out on the HDMI you can play and change the HDMI output: The possible settings are: 576P / 720P / 1080i / UD / UD_4K st cap capdtm setusr HDMIOUT 0x350001 st cap capdtm getusr HDMIOUT UserData is HDMIOUT_576P (0x350001) st cap capdtm setusr HDMIOUT 0x350002 st cap capdtm getusr HDMIOUT UserData is HDMIOUT_720P (0x350002) st cap capdtm setusr HDMIOUT 0x350003 st cap capdtm getusr HDMIOUT UserData is HDMIOUT_1080I (0x350003) st cap capdtm setusr HDMIOUT 0x350004 st cap capdtm getusr HDMIOUT UserData is HDMIOUT_UD (0x350004) st cap capdtm setusr HDMIOUT 0x350005 st cap capdtm getusr HDMIOUT UserData is HDMIOUT_UD_4K (0x350005) MountneerMan and lucabutera 2 Link to comment Share on other sites More sharing options...
lucabutera Posted September 7, 2016 Share Posted September 7, 2016 31 minutes ago, kinoseed said: for recording - nope if you think of using HDMI - no idea (and I can't test it here) Change the VGA resolution, and see what comes out on the HDMI you can play and change the HDMI output: The possible settings are: 576P / 720P / 1080i / UD / UD_4K st cap capdtm setusr HDMIOUT 0x350001 st cap capdtm getusr HDMIOUT UserData is HDMIOUT_576P (0x350001) st cap capdtm setusr HDMIOUT 0x350002 st cap capdtm getusr HDMIOUT UserData is HDMIOUT_720P (0x350002) st cap capdtm setusr HDMIOUT 0x350003 st cap capdtm getusr HDMIOUT UserData is HDMIOUT_1080I (0x350003) st cap capdtm setusr HDMIOUT 0x350004 st cap capdtm getusr HDMIOUT UserData is HDMIOUT_UD (0x350004) st cap capdtm setusr HDMIOUT 0x350005 st cap capdtm getusr HDMIOUT UserData is HDMIOUT_UD_4K (0x350005) are you saying that could shot in raw with external recorder? MountneerMan 1 Link to comment Share on other sites More sharing options...
kinoseed Posted September 7, 2016 Share Posted September 7, 2016 16 minutes ago, lucabutera said: are you saying that could shot in raw with external recorder? as I said - "no idea", as I can't test HDMI-out here Link to comment Share on other sites More sharing options...
lucabutera Posted September 7, 2016 Share Posted September 7, 2016 29 minutes ago, kinoseed said: as I said - "no idea", as I can't test HDMI-out here If this were possible that would be great!! MountneerMan 1 Link to comment Share on other sites More sharing options...
kinoseed Posted September 7, 2016 Share Posted September 7, 2016 47 minutes ago, lucabutera said: If this were possible that would be great!! Give it a try, and let us know how it goes: Mod-menu > Custom Func. > Mod Resolutions > (select) VGA as UHD *note: if you have NX1, you need nx-ks v2.49 Set your camera to VGA, and check what comes out from the HDMI To tweak the hdmi-out, you can execute the codes above (via telnet), and see if there's any (there may not be any) difference in the output. MountneerMan and Kisaha 2 Link to comment Share on other sites More sharing options...
lucabutera Posted September 8, 2016 Share Posted September 8, 2016 no one has tried if it works? Marco Tecno 1 Link to comment Share on other sites More sharing options...
MountneerMan Posted September 8, 2016 Share Posted September 8, 2016 1 hour ago, lucabutera said: no one has tried if it works? I am confused as to what exactly you guys are trying to do? Are you trying to get the camera to dump the RAW sensor data out the HDMI port? I dont know how external recorders work but I am sure it would have no idea what its looking at meaning every camera's RAW output would look different. Geoff CB and MKSN 2 Link to comment Share on other sites More sharing options...
/Chop N Shoot Films/ Posted September 8, 2016 Share Posted September 8, 2016 Trying to output 4k60p kidzrevil, MountneerMan and Marco Tecno 3 Link to comment Share on other sites More sharing options...
Dean Posted September 9, 2016 Share Posted September 9, 2016 Hi. Is this the mod most people are using with the NX1? https://github.com/ottokiksmaler/nx500_nx1_modding/tree/master/video-bitrate-mods/nx-patch I might try and instal it tonight. Link to comment Share on other sites More sharing options...
lucabutera Posted September 9, 2016 Share Posted September 9, 2016 11 hours ago, MountneerMan said: 4 hours ago, Dean said: Hi. Is this the mod most people are using with the NX1? https://github.com/ottokiksmaler/nx500_nx1_modding/tree/master/video-bitrate-mods/nx-patch I might try and instal it tonight. I use NX-KS, never problem, very good hack! https://www.facebook.com/NXKS2/ Link to comment Share on other sites More sharing options...
Dean Posted September 9, 2016 Share Posted September 9, 2016 1 hour ago, lucabutera said: Thanks for that. I might try this first as the instructions look pretty basic for a person like me Can I ask what bitrate you are using without any issues? Also, I have U3 95MB/s SanDisk Extreme Pro Cards (64Gb and 128GB) ... will these be OK with the high bitrates? Cheers. Link to comment Share on other sites More sharing options...
Geoff CB Posted September 9, 2016 Share Posted September 9, 2016 3 hours ago, Dean said: Thanks for that. I might try this first as the instructions look pretty basic for a person like me Can I ask what bitrate you are using without any issues? Also, I have U3 95MB/s SanDisk Extreme Pro Cards (64Gb and 128GB) ... will these be OK with the high bitrates? Cheers. I have the 64gb version of that card and I was hitting 220 mbps. But the default 180 is already a huge improvement if your worried about issues. kidzrevil and Dean 2 Link to comment Share on other sites More sharing options...
NX1user Posted September 9, 2016 Share Posted September 9, 2016 7 hours ago, Dean said: Thanks for that. I might try this first as the instructions look pretty basic for a person like me Can I ask what bitrate you are using without any issues? Also, I have U3 95MB/s SanDisk Extreme Pro Cards (64Gb and 128GB) ... will these be OK with the high bitrates? Cheers. Buried in one of these threads and on test videos from youtube, my recollection is that there wasn't a huge improvement in image quality above 180-200, that's why 180 is the default. Going from the factory 80 to 180, you will notice a huge improvement in what you can do with the image in post. Also, small tight patterns like asphalt or distant tree leaves look much better. Which hack to use depends on what you want. KS has more features, is reliable, but takes a few seconds to load when turning on the camera. Vasile's hack loads immediately, is reliable, but has less features and takes more steps to install initially. If you just want bitrate, Vasile's might be a better choice. Check out KS features though, he's done some amazing work, you may decide his is better for you. Kisaha, Marco Tecno and lucabutera 3 Link to comment Share on other sites More sharing options...
Geoff CB Posted September 9, 2016 Share Posted September 9, 2016 On 9/5/2016 at 6:29 PM, kinoseed said: for NX500: Mod-menu > Custom Func. > Mod Resolutions > (select) DC as 2.5K in camera-settings set and record DC video, it will be 2.5K at 24fps 2.5K mode on the NX500. Very impressive RS performance. NX1user, Liam, amanofan and 4 others 7 Link to comment Share on other sites More sharing options...
