4K 8bit to 1080p 10bit 4:4:4
Tim Park
I just used the free version of Cliptoolz Convert to change a GH4 4k SooC file:
General
Format                                   : MPEG-4
Format profile                           : Base Media / Version 2
Codec ID                                 : mp42
File size                                : 763 MiB
Duration                                 : 1mn 6s
Overall bit rate mode                    : Variable
Overall bit rate                         : 96.7 Mbps
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : High@L5.1
Format settings, CABAC                   : Yes
Format settings, ReFrames                : 2 frames
Codec ID                                 : avc1
Codec ID/Info                            : Advanced Video Coding
Duration                                 : 1mn 6s
Bit rate mode                            : Variable
Bit rate                                 : 95.1 Mbps
Maximum bit rate                         : 106 Mbps
Width                                    : 3 840 pixels
Height                                   : 2 160 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Constant
Frame rate                               : 25.000 fps
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.459
Stream size                              : 751 MiB (98%)
Color primaries                          : BT.709
Transfer characteristics                 : BT.709
Matrix coefficients                      : BT.709
Audio
Format                                   : PCM
Format settings, Endianness              : Big
Format settings, Sign                    : Signed
Codec ID                                 : twos
Duration                                 : 1mn 6s
Bit rate mode                            : Constant
Bit rate                                 : 1 536 Kbps
Channel(s)                               : 2 channels
Sampling rate                            : 48.0 KHz
Bit depth                                : 16 bits
Delay relative to video                  : 40ms
Stream size                              : 12.1 MiB (2%)
To an output target of ProRes HD/HQ 4:4:4 with scaling to 1920x1080 and got:
General
Format                                   : MPEG-4
Format profile                           : QuickTime
Codec ID                                 : qt
File size                                : 2.13 GiB
Duration                                 : 1mn 6s
Overall bit rate                         : 277 Mbps
Writing application                      : FFmbc 0.7
Video
Format                                   : ProRes
Format version                           : Version 1
Codec ID                                 : ap4h
Duration                                 : 1mn 6s
Bit rate                                 : 275 Mbps
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Color space                              : YUV
Chroma subsampling                       : 4:4:4
Bits/(Pixel*Frame)                       : 5.308
Stream size                              : 2.12 GiB (99%)
Writing library                          : ffm0
Language                                 : English
Audio
Format                                   : PCM
Codec ID                                 : twos
Duration                                 : 1mn 6s
Channel positions                        : Front: L R
Bit depth                                : 16 bits
Stream size                              : 12.1 MiB (1%)
Language                                 : English
Any use? Though do note Cliptoolz Convert is discontinued so you might need to hunt around to find a copy. (It went from paid -> free -> discontinued, I think due to issues with using Prores.) It does claim to handle 4k scaling well, see the site: http://hdcinematics.com/convert-V2.html
(Edit) The download link seems to work, which it didn't a while back:
