Metabones Speed Booster review
A change to the effective F/stop that would affect the DOF means a physical change to the size of the opening created by the shutter blades.  Nowhere in the documentation does it state or even suggest that this happens.
If you were to take a picture, print it out and hold it up to your face close enough that you couldn't see its edges, that represents pre-Metabones or how your smaller-sensor camera sees the scene depicted in the photograph.  Now, hold the photograph out further, far enough so that you can see all the way to the edges or close.  That represents how your smaller-sensor camera sees the scene depicted in the photograph after installing the Metabones adapter.
No change in DOF.  The optical reduction doesn't alter the FOV of the lens it alters how much of it your sensor can see.  This isn't a wide-angle converter that also makes the image brighter.  The effective T-Stop difference is from the compression of the light meant for a large aperture imaging layer into the space of a smaller one.  Light is additive.
In image processing terms, when you scale an image from 2K to 1K the brightness of the image doesn't change because neighboring pixels from the 2K source are averaged to create a new pixel for the 1K result.  Light doesn't work that way.  Resizing would do something similar to what this adapter does if, instead of averaging, you were scoot neighboring pixels from the 2K source inward such that the 1K final still contained all of the original pixels from the 2K but some of them were now stacked on top of the other and their values were now added to each other rather than averaged.
The Metabones adapter doesn't stack the photons of light on top of each other because it's not limited to the spaces available in a fixed grid like an image but they are hitting the imaging surface much closer together now and so they produce an image that's brighter.   Like how a magnifying glass makes the light passing through it brighter when focused.
Barrel distortion and not as sharp.
Still a great product, but this hurts being used on narrative film.
Doc users will be all over this. Maybe BMCC users as well because they are in dyer need of wide. I don't think F5 or F55 users would touch this if given for free.
Would it even fit on their F5/F55 if they wanted to? They don't use the E-mount.
True they use FZ mount but the flange is the same as E-mount ,18mm. That is the important thing - enough room to accommodate the Speed Booster. FZ just has a wider diameter to accommodate some rear elements on PL glass and has a tougher locking system, and adapters to PL out of the box.
seems in addition to sharpness loss at the frame edges this adapter produces additional aberration effect...
Sharpness loss at the edge of frame is mostly a function of the lens itself.  It's only apparent to the smaller sensor after using this adapter because it could never see it before, it only saw the "sweet spot".  In point of fact, sharpness at the edge of frame is better through the adapter on a smaller sensor than the same lens mounted to a FF camera.
Seems lots of people still aren't bothering to really investigate or grok what they've read so that they can add meaningful discussion.
edit: it cracks me up that, even though the adapter IS performing a kind of magick, its critics now feel compelled to criticize the magick itself as if it just weren't miraculous enough for their standards....
"Yeah, you turned water into wine...but you didn't raise anyone from the dead.  Fail.  You suck."
That is why I said effective f/stop. And according to the documentation, with the Speed Booster, the effective focal length and f/stop are indeed changed. I'm not confused.
Tzedekh, you are correct. Using the speedbooster changes the lens. It reduces the lens image circle, decreases the lens f-stop, decreases the lens focal length, and increases its field of view. A lens with the speedbooster is optically very different than the same lens without the speedbooster. BurnetRhoades is confused on this and many other points. For example, he seems to (incorrectly) believe that depth-of-field depends on "the size of the opening created by the shutter blades".  When in fact DOF depends only on the aperture of the lens, the lens focal length, sensor size, and the distance from the focal plane to the subject. THE SHUTTER DOES NOT AFFECT DOF IN ANY WAY. Also he does not understand what is an f-stop and how it differs from a t-stop. At any given f-stop setting, adding the speedbooster increases the actual f-stop of the lens at that setting. Yes, after you add the speedbooster, all the f-stop settings on your lens are now incorrectly labeled!
This is an image of the Canon 24-105 F4L at 50mm on a 5D3 and FS700+Speed Booster blended 50/50. Max aperture set on 5D3 (F4) and FS700+SB (F4 full-frame DOF with F2.8-like light transmission performance).
[attachment=393:FS700+SB_5D3_DOF.jpg]
Close up of bokeh:
[attachment=394:bokeh_match.jpg]
The FS700 S35 sensor with Speed Booster gives full-frame performance with a 1.09 crop, approximately same DOF and FOV performance as full frame, and effectively 1-stop faster light transmission performance. In this example, F4 DOF for both cameras, with the FS700+SB providing F2.8-like light transmission. Where a T-stop is exactly the same as an f-stop with 100% light transmission, then a lens rated with a T-stop of 4 on the 5D3 would have a T-stop rating of 2.8 with the FS700 + Speed Booster.
Wow, that is a magic trick then, changing a lens after the fact and not changing how much of what the lens already saw your sensor can now see.
Some kind of optical reach-a-round I suppose.
The lens itself doesn't physically change. The lens plus Speed Booster has different properties. The same with a teleconverter -- putting a 2x extender on a 10-100 mm f/2.4 renders it effectively a 20-100 mm f/4.8.
Where F2.4 has an Aperture Value of 2.5, then the next Aperture Value is 3.5, the next stop is 3.4.
sqrt(2^2.5) = 2.378 or 2.4, sqrt(2^3.5) = 3.364 or 3.4.
Wolfram Alpha is an excellent tool: http://www.wolframalpha.com/input/?i=sqrt%282%5E3.5%29 (not just for simple calculations- can solve complex equations).
Either I'm doing the math wrong or some of the tables on the internet aren't rounded correctly.
http://en.wikipedia.org/wiki/F-number
http://www.fineart-photography.com/fstop.html
Why don't manufacturers combine something like this with backside-illuminated smaller (1/2- to 2/3-inch) sensors?
Beats me. Because there's more profit in making a larger CMOS sensor and a lens that covers that I suppose?
I suppose that with too small a sensor size, the required optics would probably introduce too many aberrations. Also, with a crop factor of about 3.9-4 for a 2/3-inch sensor, you might expect, in theory, a .25 factor and a four-stop decrease in f/stop. Well, the latter seems especially unlikely.
That should be effectively a 20-200mm f4.8 .
It appears that the 5d3 "sharpened" has much more detail than the FS100; at least the 1:03 to 1:04 mark.  Look at the differences in detail in the snow as well as the trees on the left.  We all sharpen (at least everyone I know) our 5d3 footage; why not just always include that?
Thanks,
Shawn
There is definitely a little more noise due to the glass...or so it seems... I just shelled out $399 on the Smart Adapter II... Gonna be a while before I splurge some cash on the Speed Booster. I've seen some clips that I am impressed with and some that I am not. Hopefully the price lowers sooner than later. $599 is understandable to a degree, but a lot of us don't have loads of cash to spend on these adapters...unfortunately, ha! Well some do..but yeah.
Can anyone offer me any advice as a new GH2 shooter before I invest in lenses? To me, this changes everything. I'd rather not buy 4/3 lenses as I am in no other way invested in the system (I am a Fuji X-E1) user. Therefore, I'd like to use something like Nikon primes, and naturally with the GH2 I don't like the inherent loss of shallow DoF due to its sensor. So a 1.8 prime becomes very attractive. Is this thinking right? Shall I hold off buying anything till its ok next month? Thanks!
  • 2 weeks later...
