5d III ML Raw
zerocool22
Hey,
I just installed the 5D iii ML hack but I can only choose up to 1920*1080p resolution, no bigger resolution. I am using a computerbay 1000x card, and read this should be sufficient. However if i change aspect ratio I can choose other resolutions. What is the best combo for regular video and what is the best resolution for anamorphic shooting (4:3)? As I thought you could shoot up to 2.5k video.
Thanks!
3 hours ago, zerocool22 said:
Hey,
Thanks!
1920 x 1080 is highest resolution, higher resolutions can only be reached if you go into the 5x crop mode.
Thats right but in fact the highest resolution possible in normal (not cropped) mode is 1920x1290 (3:2 aspect).
