EliotZ Posted February 22, 2016 Share Posted February 22, 2016 Hey guys! Im thinking of buying atomos ninja assassin and it would be cool if I could use it for 120fps slow motion in my a7s ii. I just cant find anything about recording slow motion on a7s ii on ninja assassin or shogun. So it dosent work or what then because I would really love to have that option. Also can you record 1080p slow motion in camera and 4k 24p in ninja assassin simultaniusly or the other way around? I know it sounds a bjt unreal but I would love that. Link to comment Share on other sites More sharing options...
Guest Ebrahim Saadawi Posted February 22, 2016 Share Posted February 22, 2016 no and no. Sorry! 1- A7s HDMI output is 60p HD & 30p UHD. 2- Your chosen frame rate is how many images the sensor will take in a second, so it obviously has to be one number at one given moment in time, either 30p, 60p, 120p. Those of us who require having both slo-mo and normal speed in the same take, shoot at 60p and use it for slowing down to 30p and for normal speed just discard half the frames to 30p. Works fine. Link to comment Share on other sites More sharing options...
mkabi Posted February 23, 2016 Share Posted February 23, 2016 On 22/02/2016 at 1:23 PM, Ebrahim Saadawi said: no and no. Sorry! 1- A7s HDMI output is 60p HD & 30p UHD. 2- Your chosen frame rate is how many images the sensor will take in a second, so it obviously has to be one number at one given moment in time, either 30p, 60p, 120p. Those of us who require having both slo-mo and normal speed in the same take, shoot at 60p and use it for slowing down to 30p and for normal speed just discard half the frames to 30p. Works fine. You should see the difference between an a7s & a7sii. His question pertains to the a7sii, which does have 120fps internally, his question is whether it can output it through hdmi. Good question. I would hope so.... the shogun or ninja assassin can both record 1080/120p. But, to be honest, I do not know the answer to either question.... would love to know from the owners. The reason why you haven't found an answer is because most that own the original a7s would most likely have a shogun or ninja assassin, whereas people that have an a7sii, mostly likely won't have a shogun or assassin because they have the 4K and 120p internally. The only problem with the a7sii and the 120p is the 2.2 crop - and you can't frame it till after you press record (that's what I read from the sonyalpharumors forum) Link to comment Share on other sites More sharing options...
Super Members Mattias Burling Posted February 23, 2016 Super Members Share Posted February 23, 2016 8 minutes ago, mkabi said: You should see the difference between an a7s & a7sii. His question pertains to the a7sii, which does have 120fps internally, his question is whether it can output it through hdmi. Good question. I would hope so.... the shogun or ninja assassin can both record 1080/120p. But, to be honest, I do not know the answer to either question.... would love to know from the owners. The reason why you haven't found an answer is because most that own the original a7s would most likely have a shogun or ninja assassin, whereas people that have an a7sii, mostly likely won't have a shogun or assassin because they have the 4K and 120p internally. The only problem with the a7sii and the 120p is the 2.2 crop - and you can't frame it till after you press record (that's what I read from the sonyalpharumors forum) Ebrahim already answered. Its no and no. Link to comment Share on other sites More sharing options...
mkabi Posted February 23, 2016 Share Posted February 23, 2016 Just now, Mattias Burling said: Ebrahim already answered. Its no and no. Really? I thought he was only answer for the mark 1. Even the mark 2? That sucks... Link to comment Share on other sites More sharing options...
blafarm Posted February 23, 2016 Share Posted February 23, 2016 No and no. Rinad Amir 1 Link to comment Share on other sites More sharing options...
ntblowz Posted February 23, 2016 Share Posted February 23, 2016 the max out put is 30p in uhd and 60p in 1080p in HDMI, end of story for slow mo you need fs700/fs5/fs7 through SDI Link to comment Share on other sites More sharing options...
Guest Ebrahim Saadawi Posted February 24, 2016 Share Posted February 24, 2016 10 hours ago, mkabi said: Really? I thought he was only answer for the mark 1. Even the mark 2? That sucks... Sorry but yes. No and no. But when you look at it actually 60p through HDMI is pretty damn good, 60p is great for unobtrusive Slo-motion. And no cameras in this category AT ALL outputs 120p, and 60p is pretty rare. Since we opened a thread: does any camera at all output higher than 60p through HDMI interface, at any price point, any shape or any brand? Link to comment Share on other sites More sharing options...
hmcindie Posted February 24, 2016 Share Posted February 24, 2016 1 hour ago, Ebrahim Saadawi said: Since we opened a thread: does any camera at all output higher than 60p through HDMI interface, at any price point, any shape or any brand? No. HDMI is a consumer interface and 1.4b only supports 120hz (at fullhd) ONLY in 3d mode. HDMI 2.0 does support 1080p 120hz but it's rarely supported because most HDMI 2.0 monitors are 4k at 60p. HDMI is a monitor interface. Link to comment Share on other sites More sharing options...
mkabi Posted February 28, 2016 Share Posted February 28, 2016 On 2/24/2016 at 0:55 AM, Ebrahim Saadawi said: Sorry but yes. No and no. But when you look at it actually 60p through HDMI is pretty damn good, 60p is great for unobtrusive Slo-motion. And no cameras in this category AT ALL outputs 120p, and 60p is pretty rare. Since we opened a thread: does any camera at all output higher than 60p through HDMI interface, at any price point, any shape or any brand? Good to know... Now I have to know, between 1080/120 recorded internally (with either a7sii, NX1 or the upcoming 1dx2), vs. 1080/60 externally with Pro Res 8bit 4:2:2. Which one would Txixtor be better with? Less warping and stuff? Link to comment Share on other sites More sharing options...
markjohnsonii Posted February 28, 2016 Share Posted February 28, 2016 I just shot my A7sII at 120FPS out to the Shogun via HDMI and the resulting files on the Shogun list as 1080p 120FPS. They also appear to be high dreams rate so you go figure. I'll try to slow them down and verify. Link to comment Share on other sites More sharing options...
markjohnsonii Posted April 18, 2016 Share Posted April 18, 2016 On February 27, 2016 at 2:36 PM, markjohnsonii said: I just shot my A7sII at 120FPS out to the Shogun via HDMI and the resulting files on the Shogun list as 1080p 120FPS. They also appear to be high dreams rate so you go figure. I'll try to slow them down and verify. JUST 60 TURNS OUT. Link to comment Share on other sites More sharing options...
fundamentalfilms Posted August 3, 2016 Share Posted August 3, 2016 Am I correct in saying that these are the only 2 solutions in recording 120FPS with the Sony A7SII and Shogun/Ninja Flame etc. Record at 1080p 60FPS and use twixtor to slow down to 120FPS. Use the monitor just for monitors use and record 120FPS internally with the camera. Link to comment Share on other sites More sharing options...
