iamoui Posted June 13, 2016 Share Posted June 13, 2016 17 minutes ago, MKSN said: Tested Vasile´s patch v4.12 today. Clips 100fps and 50fps 1080p. NX1 with Canon 50mm 1.8 FD lens. ISO100 GammaDR / Sat -3 / Sha -7 / Hue -9 / MBL +15 M31 Lut + curves Dropped frames at 0:20? What bitrate were you using? Link to comment Share on other sites More sharing options...
kidzrevil Posted June 13, 2016 Share Posted June 13, 2016 It would be cool if we had the ability to save luts in place of the 3 custom picture profiles. Could be the path to LOG imagery on nx bodies Link to comment Share on other sites More sharing options...
Sten Posted June 13, 2016 Share Posted June 13, 2016 24 minutes ago, kidzrevil said: It would be cool if we had the ability to save luts in place of the 3 custom picture profiles. Could be the path to LOG imagery on nx bodies NX1 Camera - How to Download Custom Modes for Your Samsung NX1 Camera http://www.samsung.com/ca/support/skp/faq/1078523 Link to comment Share on other sites More sharing options...
MKSN Posted June 13, 2016 Share Posted June 13, 2016 2 hours ago, iamoui said: Dropped frames at 0:20? What bitrate were you using? I think warp stabilizer is causing that. I need to check original footage again. Bitrate was 180mbps vaga 1 Link to comment Share on other sites More sharing options...
iamoui Posted June 13, 2016 Share Posted June 13, 2016 16 minutes ago, MKSN said: I think warp stabilizer is causing that. I need to check original footage again. Bitrate was 180mbps Are you sure? I'm shooting with Vasile's newest 5.02 patch and even at 120mbps I'm getting a variable frame rate when shooting 120fps, instead of a constant 120fps. edit: Just tried 60fps at 180mbs and getting a constant 60fps. I wonder what's up with the 120mbs 120fps. With KS mod pack I was getting constant 120fps with 120mbps edit: Tried 120fps at 110mbps and got a constant 120fps! Link to comment Share on other sites More sharing options...
MKSN Posted June 13, 2016 Share Posted June 13, 2016 2 hours ago, MKSN said: i checked my footage, its ok. Some clips were around 99,80fps but clips used in project was constant. There is actually duplicated frames in 00:20, most likely caused by stabilizer. I shoot PAL format so 180mbps works for me usually. Link to comment Share on other sites More sharing options...
kidzrevil Posted June 15, 2016 Share Posted June 15, 2016 On 6/13/2016 at 3:31 PM, Sten said: NX1 Camera - How to Download Custom Modes for Your Samsung NX1 Camera http://www.samsung.com/ca/support/skp/faq/1078523 would it be possible to convert a LUT somehow into one of those Samsung custom profiles ? Link to comment Share on other sites More sharing options...
vaga Posted June 15, 2016 Share Posted June 15, 2016 I'm pretty sure that's what those profiles are. Is there any instructions on how to make profiles? Link to comment Share on other sites More sharing options...
kidzrevil Posted June 15, 2016 Share Posted June 15, 2016 @vaga not that I know of. If we could find out how they are made that's a big step forward Link to comment Share on other sites More sharing options...
Sten Posted June 15, 2016 Share Posted June 15, 2016 8 hours ago, kidzrevil said: would it be possible to convert a LUT somehow into one of those Samsung custom profiles ? starts at 2:30 - [Video How-to Guide] Pro Suggest Market-Setup and Customize Films http://www.samsung.com/ae/support/skp/htv/16258 kidzrevil 1 Link to comment Share on other sites More sharing options...
vaga Posted June 16, 2016 Share Posted June 16, 2016 Hmm I guess that's the same thing. Can someone try loading a profile? @kidzrevil Link to comment Share on other sites More sharing options...
omega1978 Posted June 20, 2016 Share Posted June 20, 2016 Samsung NX1 16-50S Hack: Vasile 5.01 150mps Normal Gamma, Costum profil, Premiere CC with R709 LUT, Filmconvert Grain 50% vaga, kidzrevil, Liam and 3 others 6 Link to comment Share on other sites More sharing options...
Marco Tecno Posted June 21, 2016 Share Posted June 21, 2016 Omega, outstanding colors, especially for normal gamma! P.s. did you use dis? Link to comment Share on other sites More sharing options...
omega1978 Posted June 21, 2016 Share Posted June 21, 2016 This is the profil from caseywilsondp with his R709 LUT. yes i used the dis, all shot handheld Link to comment Share on other sites More sharing options...
Popular Post shanebrutal Posted June 25, 2016 Popular Post Share Posted June 25, 2016 Shot with vasile's 140 mbps. Still from 4k on 1080 timeline. Andrew's gamma DR settings but no LOG LUT. Just used visioncolor impulz rec.709 tetrachrome FC + Curves, saturation boost and vignette. Used 16-50S lens. Sick footage everyone! I'm surely having fun with the NX1!! Marco Tecno, tokhee, iamoui and 7 others 10 Link to comment Share on other sites More sharing options...
SMGJohn Posted June 26, 2016 Share Posted June 26, 2016 On 13.6.2016 at 9:31 PM, Sten said: NX1 Camera - How to Download Custom Modes for Your Samsung NX1 Camera http://www.samsung.com/ca/support/skp/faq/1078523 This one is pretty useless, you somehow have to obtain the file created and configure it in some program on your PC because the options for it are shit, you basically just making a preset for your camera to shoot after, you select it in the smart mode on your NX1 or NX500, its same as those other fancy stuff they have, its basically just a pre filter they add on afterwards but instead of doing it yourself the camera does it for you. Marco Tecno, vaga and kidzrevil 3 Link to comment Share on other sites More sharing options...
kidzrevil Posted July 4, 2016 Share Posted July 4, 2016 180 mbps Kinoseed hack even with master black level at +15 there is absolutely NO macroblocking ! Link to comment Share on other sites More sharing options...
iamoui Posted July 4, 2016 Share Posted July 4, 2016 6 hours ago, kidzrevil said: 180 mbps Kinoseed hack even with master black level at +15 there is absolutely NO macroblocking ! Honestly man this looks great, but I still see macroblocking in the shadows at times. Link to comment Share on other sites More sharing options...
kidzrevil Posted July 4, 2016 Share Posted July 4, 2016 can you download the original off of my vimeo ? I don't see any macroblocking in the raw files but im sure if you catch some its due to vimeo compression. @iamoui Link to comment Share on other sites More sharing options...
iamoui Posted July 4, 2016 Share Posted July 4, 2016 20 minutes ago, kidzrevil said: can you download the original off of my vimeo ? I don't see any macroblocking in the raw files but im sure if you catch some its due to vimeo compression. @iamoui Ahhh, right. I don't see an option to download on the vimeo page. Link to comment Share on other sites More sharing options...
