kidzrevil Posted July 4, 2016 Share Posted July 4, 2016 @iamoui I just enabled it let me know if you can DL now Link to comment Share on other sites More sharing options...
iamoui Posted July 5, 2016 Share Posted July 5, 2016 4 hours ago, kidzrevil said: @iamoui I just enabled it let me know if you can DL now Downloaded. I can still seem some in the original file, just not as noticeable as it is on Vimeo. Examples: 0:31 very left side of the frame. 0:35 the black under-side of whatever that is. 1:11 basically everything in the shadows. After you open the iris it's just in her hair. What kind of file format is the original file? When I downloaded it and opened it in QuickTime it had to convert before it played. Link to comment Share on other sites More sharing options...
kidzrevil Posted July 5, 2016 Share Posted July 5, 2016 Its cineform so it probably broke down during your conversion @iamoui i am not seeing anything but the grain i added in post Link to comment Share on other sites More sharing options...
cojocaru27 Posted August 11, 2016 Share Posted August 11, 2016 just a qucik 100p test using the hack. too bad youtube compression wrecked my blacks, should move to vimeo. Kisaha 1 Link to comment Share on other sites More sharing options...
sandro Posted August 11, 2016 Share Posted August 11, 2016 Really like it. What bitrate did you use? Anyway with the latest version what bitrate can you push to get a stable 120p footage? Link to comment Share on other sites More sharing options...
kidzrevil Posted August 11, 2016 Share Posted August 11, 2016 @sandro 110 mbps for 120fps and 160 for 60fps Link to comment Share on other sites More sharing options...
Daniel Galli Posted August 11, 2016 Share Posted August 11, 2016 First video with 120fps at 720p upscaled to 1080p, i think there are 60mbps on bitrate. Liam 1 Link to comment Share on other sites More sharing options...
MountneerMan Posted August 11, 2016 Share Posted August 11, 2016 1 hour ago, Daniel Galli said: First video with 120fps at 720p upscaled to 1080p, i think there are 60mbps on bitrate. Why 720 upscaled and not 1080 in camera? Link to comment Share on other sites More sharing options...
Daniel Galli Posted August 11, 2016 Share Posted August 11, 2016 i forgot to say, i got nx500. Link to comment Share on other sites More sharing options...
MountneerMan Posted August 11, 2016 Share Posted August 11, 2016 1 hour ago, Daniel Galli said: i forgot to say, i got nx500. I thought the NX500 did 1080 120p as well? Link to comment Share on other sites More sharing options...
Daniel Galli Posted August 12, 2016 Share Posted August 12, 2016 Nope, just 1080 60p or 120 at 720p Link to comment Share on other sites More sharing options...
sandro Posted August 14, 2016 Share Posted August 14, 2016 On 8/12/2016 at 4:58 AM, Daniel Galli said: Nope, just 1080 60p or 120 at 720p Lens used? Link to comment Share on other sites More sharing options...
Daniel Galli Posted August 14, 2016 Share Posted August 14, 2016 3 hours ago, sandro said: Lens used? 16-50 kit Link to comment Share on other sites More sharing options...
omega1978 Posted August 19, 2016 Share Posted August 19, 2016 https://vimeo.com/179306887 NX1 -16-50S vasile 5.01 140mb, 4K 25p mixed with 1080-50/100p,only first scene on tripod, rest handheld, still a small amount of banding, maybe from variable ND. sandro, Hanriverprod and lucabutera 3 Link to comment Share on other sites More sharing options...
vaga Posted August 21, 2016 Share Posted August 21, 2016 That was really nice! Thank you for not using ridiculous colors (like excessive orange/pink and teal/aquamarine). Was the flower scene at around 38 seconds with DIS? Link to comment Share on other sites More sharing options...
omega1978 Posted August 21, 2016 Share Posted August 21, 2016 Thank you, i like colours there are near reality. With normal gamma i find the NX1 has the best colour rendition(only DR is limited). All scene are with DIS, only 3-4 inital are on tripod.. If you have an object very near you can notice DIS very well(same as warp stabilizer) in a bad way... vaga and kidzrevil 2 Link to comment Share on other sites More sharing options...
kidzrevil Posted August 26, 2016 Share Posted August 26, 2016 Gamma C @ 180mbps . Contax Zeiss Lens set with tiffen warm black pro mist Link to comment Share on other sites More sharing options...
Veselin Karavelov Posted August 30, 2016 Share Posted August 30, 2016 On 8/21/2016 at 10:57 PM, omega1978 said: Thank you, i like colours there are near reality. With normal gamma i find the NX1 has the best colour rendition(only DR is limited). All scene are with DIS, only 3-4 inital are on tripod.. If you have an object very near you can notice DIS very well(same as warp stabilizer) in a bad way... What profile settings have you used for the normal gamma? Highlights and shadows are well preserved, especially the highlights Link to comment Share on other sites More sharing options...
omega1978 Posted August 30, 2016 Share Posted August 30, 2016 5 hours ago, Veselin Karavelov said: What profile settings have you used for the normal gamma? Highlights and shadows are well preserved, especially the highlights under costum foto profil sharpness -10, contrast -5. levels 16-235 and i check the zebra to avoid clipping highlights. in post apply a rec709 lut Hanriverprod and Veselin Karavelov 2 Link to comment Share on other sites More sharing options...
shanebrutal Posted August 30, 2016 Share Posted August 30, 2016 On 8/26/2016 at 11:45 AM, kidzrevil said: Gamma C @ 180mbps . Contax Zeiss Lens set with tiffen warm black pro mist I started using gamma c after seeing your recent work. Really like it at +12 mbl. I'm curious about the tiffen black pro mist. If you get some free time would you mind doing a comparison of with and without it on the nx1? kidzrevil 1 Link to comment Share on other sites More sharing options...
