Administrators Andrew Reid Posted March 22, 2016 Administrators Share Posted March 22, 2016 I see the NX1 and NX500 have an MJPEG codec, but it's only used for the 640x480 recording mode. But the codec is there, right? Maybe we could persuade it to record at a higher resolution and bitrate in 4:2:2 like the Canon 1D C. (Ok, wild leap there, but any improvement would be an interesting discovery). Also the silent shutter, in this mode it does raw from a rolling shutter scan of the sensor, just like a video mode... the raw data must be lurking in the buffer somewhere whilst it runs in video mode... now what we need is a genius to dive in a grab it Liam, Pavel Mašek, lucabutera and 5 others 8 Link to comment Share on other sites More sharing options...
Popular Post SMGJohn Posted March 22, 2016 Popular Post Share Posted March 22, 2016 Chant said he might look into increasing resolution and maybe bitrate for the MJPEG, honestly I think the focus should be more on the MJPEG rather than the HEVC which is just painful to work with already and any higher bitrate will make it even more painful to work with than it already is, so instead of having a thorn in our bums, MJPEG would be the better pick here for easy editing. /Chop N Shoot Films/, Kisaha, Alborat and 7 others 10 Link to comment Share on other sites More sharing options...
kidzrevil Posted March 24, 2016 Share Posted March 24, 2016 On 3/22/2016 at 9:23 PM, SMGJohn said: Chant said he might look into increasing resolution and maybe bitrate for the MJPEG, honestly I think the focus should be more on the MJPEG rather than the HEVC which is just painful to work with already and any higher bitrate will make it even more painful to work with than it already is, so instead of having a thorn in our bums, MJPEG would be the better pick here for easy editing. I never worked with MJPEG but you are making a lot of sense. The HEVC codec is so demanding on the system. Hopefully we can get high quality files with minimum processing out of the mjpeg as well Link to comment Share on other sites More sharing options...
sandro Posted March 24, 2016 Share Posted March 24, 2016 yup and even though size will raise a lot it doesn't matter since sd card are so cheap right now Link to comment Share on other sites More sharing options...
kidzrevil Posted March 24, 2016 Share Posted March 24, 2016 25 minutes ago, sandro said: yup and even though size will raise a lot it doesn't matter since sd card are so cheap right now yup I'm willing to deal with big file sizes for better bit rates & compression. Its time to really take advantage of the nx1's unique sensor Link to comment Share on other sites More sharing options...
Sawstory Posted June 16, 2016 Share Posted June 16, 2016 i wonder why the hackers did not try that? Link to comment Share on other sites More sharing options...
MountneerMan Posted June 16, 2016 Share Posted June 16, 2016 13 hours ago, Sawstory said: i wonder why the hackers did not try that? They have tried to get this working with no results.... yet, I think there is still hope for MJPEG but right now no clear path on how to get there. Link to comment Share on other sites More sharing options...
vaga Posted June 16, 2016 Share Posted June 16, 2016 @kinoseed seems to have found a way to change the resolutions and framing parameters M's l passed to the camera so there may be some advances in this regard soon. Link to comment Share on other sites More sharing options...
MountneerMan Posted June 17, 2016 Share Posted June 17, 2016 I am definitely out of the loop on the NX-KS patch ever since he decided to focus his interactions on his facebook page oppose to on here and DPreview but last I understood was that it was only possible to change the resolution setting of given slots in the menu eg set UHD to the HD setting. I was told by Vasile who helped discover this mod that the first thing he tried was to replace VGA-MJPEG with UHD and it doesn't work http://***URL removed***/forums/post/57862276 Perhaps Kinoseed has discovered a new mod I am not aware of though. Link to comment Share on other sites More sharing options...
kinoseed Posted June 17, 2016 Share Posted June 17, 2016 NX500/NX1 have programmable hardware and in essence you set up the hardware which resized the input for the encoder. We found the registers, but working with them directly is problematic as soon as you update part of the registers stream gets out of sync and drops out (outerbeat gets the credit for that one). Modifying the encoder's resolution can't be effective at all by itself, as no matter how you change it's recording resolution the feeding video will be already downsized. This at least should be quite clear. You can change any resolution to any other (with NX-KS it was available even for the last firmware) as they in fact only shuffle the available resolution, so you don't set anything "real". When it comes to MJPEG, something similar will be much easier achievable by setting IPeriod: 1 (or 0?), thus forcing HEVC with I-frames only. This is something that I shared with the vasile more than a month ago, when there was still some illusion for cooperative work. ; ) My linux skills are far less advanced and takes me more time to figure some of the things, and this was not on my list. cheers Marco Tecno, iamoui, kidzrevil and 1 other 4 Link to comment Share on other sites More sharing options...
kidzrevil Posted June 17, 2016 Share Posted June 17, 2016 @kinoseed that sounds very interesting. HEVC with I-frames only is basically ALL-I mode on the NX1. That sounds like a very promising way of squeezing a bit more IQ out of the nx1 or nx500 Link to comment Share on other sites More sharing options...
vasile Posted June 17, 2016 Share Posted June 17, 2016 Did not have time to look into this since: http://***URL removed***/forums/post/57641348 http://***URL removed***/forums/post/57635337 But there's no way I can see to influence this from di-camera-app or any Tizen-land application. From the looks of it it is managed inside the T-Kernel. And this I don't even know where to start on. Link to comment Share on other sites More sharing options...
