John Palmer Posted April 19, 2016 Share Posted April 19, 2016 Ive read some things online about this overheating issue and one person claims to have fixed it (or at least made it less of a problem) by adding a cage to the body. Somehow this disperses the heat or acts as some type of heat-sink (I may not be using the correct terminology so please correct me if so). Also, if you're going to be shooting all day. There are usually plenty of opportunities to turn the camera off when not using it. If you're afraid of overheating why not give the little guy a break, remove the battery and leave the battery door open. Other people have also claimed to have shot outdoors in 4k and not experienced over heating problems Rolling shutter also does not appear that bad to me in most test videos Ive seen. When you pan a camera back and forth quickly on a tripod I'm sure it looks terrible, but that is rarely a common practice when filming anything unless you're trying to shoot a live basketball/ tennis match Does anyone know what the A6300 outputs over HDMI? to the blackmagic video assist in particular would be nice Also, has anyone tried using an E-mount speedbooster on the a6300, I would love to see an example if so Link to comment Share on other sites More sharing options...
DayRaven Posted April 19, 2016 Share Posted April 19, 2016 Just now, John Palmer said: Does anyone know what the A6300 outputs over HDMI? to the blackmagic video assist in particular would be nice Also, has anyone tried using an E-mount speedbooster on the a6300, I would love to see an example if so 8bit 422 over HDMI, I am awaiting my speedbooster, but there has been a manufacturer delay according to my retailer Link to comment Share on other sites More sharing options...
vaga Posted April 19, 2016 Share Posted April 19, 2016 Has anyone tried to use a USB battery source and maybe a dummy battery inside the camera to see if it still overheats? Link to comment Share on other sites More sharing options...
Urthona Posted April 27, 2016 Share Posted April 27, 2016 On 19. April 2016 at 10:59 PM, vaga said: Has anyone tried to use a USB battery source and maybe a dummy battery inside the camera to see if it still overheats? Both aren't of much help. I got 5 to 10 minutes more until the overheating power off occurred, in my case after 40 to 45 minutes total.. vaga 1 Link to comment Share on other sites More sharing options...
independent Posted April 27, 2016 Share Posted April 27, 2016 Too risky for long form interviews and events, but for most other things why not roll out with two of these? You can just hand off the entire camera to your DIT or assistant to offload the footage, swap the battery, and let it cool while you use the other body. It's good to have a backup body anyways. You also have the option for 2 cam setups, or have one camera with a wide lens, another with a long. Or one on a gimbal, the other on sticks. Less setup. I guess a half hour limit doesn't seem like a huge problem because I remember when I had my RED w/ handle and it would last only like 20 minutes anyways (battery and media). elgabogomez 1 Link to comment Share on other sites More sharing options...
YvesBer Posted June 3, 2016 Share Posted June 3, 2016 A question to Andrew ( others are also welcome to answer) : Sony a6300 vs C100 with dual AF. Which AF is better? I got a C100 Mrk 1 and intended to buy the DAF upgrade for 500€. Then I read about the A6300 and its miraculous AF. I now hesitate. For thoses shots which need AF ( i.e. Gimbaled shots) should I go for the C100 + DAF or get a A6300 ?( 4K aside) Ps: I met you on the bridge in front of the Bode museum in Berlin, you were testing the digital Bolex I recall. Link to comment Share on other sites More sharing options...
Grégory LEROY Posted June 29, 2016 Share Posted June 29, 2016 Hello Guys, Would the rolling shutter of the A6300 be an issue with this kind of military training I'm shooting? (shot with a Nikon d5500 handheld): I plan to shoot mainly military training and interior real estate video. Link to comment Share on other sites More sharing options...
kidzrevil Posted June 30, 2016 Share Posted June 30, 2016 @Grégory LEROY you shouldn't have a problem with those kinda shots. Stick to a wide angle to be safe Link to comment Share on other sites More sharing options...
Grégory LEROY Posted June 30, 2016 Share Posted June 30, 2016 7 hours ago, kidzrevil said: @Grégory LEROY you shouldn't have a problem with those kinda shots. Stick to a wide angle to be safe Thank you for your answer, I didn't know wide angle lens prevent rolling shutter. Link to comment Share on other sites More sharing options...
BrorSvensson Posted June 30, 2016 Share Posted June 30, 2016 1 hour ago, Grégory LEROY said: Thank you for your answer, I didn't know wide angle lens prevent rolling shutter. also have an lens with OSS helps kidzrevil 1 Link to comment Share on other sites More sharing options...
Escapist Posted July 1, 2016 Share Posted July 1, 2016 Erik Naso found that when he switched to faster memory cards, many of the heating issues were improved. Inazuma 1 Link to comment Share on other sites More sharing options...
Inazuma Posted July 1, 2016 Share Posted July 1, 2016 On 03/06/2016 at 7:36 PM, YvesBer said: A question to Andrew ( others are also welcome to answer) : Sony a6300 vs C100 with dual AF. Which AF is better? I got a C100 Mrk 1 and intended to buy the DAF upgrade for 500€. Then I read about the A6300 and its miraculous AF. I now hesitate. For thoses shots which need AF ( i.e. Gimbaled shots) should I go for the C100 + DAF or get a A6300 ?( 4K aside) Ps: I met you on the bridge in front of the Bode museum in Berlin, you were testing the digital Bolex I recall. The c100 can only do dual AF in a central area and only do face AF using certain lenses. The a6300's is more flexible and faster. (source: past owner of the c100 ii and am currently playing around with the a6300) Link to comment Share on other sites More sharing options...
Geoff CB Posted July 1, 2016 Share Posted July 1, 2016 On 6/29/2016 at 3:47 PM, Grégory LEROY said: Hello Guys, Would the rolling shutter of the A6300 be an issue with this kind of military training I'm shooting? (shot with a Nikon d5500 handheld): I plan to shoot mainly military training and interior real estate video. I'm going against what kidsrevil said, if you shake the camera for added "intensity" like you did here the A6300 image will look horrendous. Link to comment Share on other sites More sharing options...
Inazuma Posted July 1, 2016 Share Posted July 1, 2016 41 minutes ago, Geoff CB said: I'm going against what kidsrevil said, if you shake the camera for added "intensity" like you did here the A6300 image will look horrendous. Only in 4K though. Link to comment Share on other sites More sharing options...
Phil A Posted July 1, 2016 Share Posted July 1, 2016 44 minutes ago, Geoff CB said: I'm going against what kidsrevil said, if you shake the camera for added "intensity" like you did here the A6300 image will look horrendous. Wouldn't it be easier anyway to shoot a bit wider in 4k and do the jigglies in post? At least it would give an easier to control result. So far liking the A6300 a lot. It's my favorite cookie cutter solution at the moment after what I tried out. Battery life is absymal and it jellies but besides that I think it's a lot of fun and because it's so small I take it with me a lot more (obviously no concern when using planned/professional). Link to comment Share on other sites More sharing options...
kidzrevil Posted July 1, 2016 Share Posted July 1, 2016 On 6/30/2016 at 8:14 AM, Grégory LEROY said: Thank you for your answer, I didn't know wide angle lens prevent rolling shutter. it doesn't prevent it, it like "masks" it. The wider the focal length the harder it is to see the rolling shutter artifacts but if you shake the camera back and forth like a mad man then RS is to be expected like @Geoff CB said Link to comment Share on other sites More sharing options...
Grégory LEROY Posted July 1, 2016 Share Posted July 1, 2016 6 hours ago, Geoff CB said: I'm going against what kidsrevil said, if you shake the camera for added "intensity" like you did here the A6300 image will look horrendous. Thx, unfortunately shaking was not intentional, I'm tall and I wanted the camera to be in the action so I handheld it at the level of my hips without any stabilization. I will wait for the Fuji XT2 report then. 1 hour ago, kidzrevil said: it doesn't prevent it, it like "masks" it. The wider the focal length the harder it is to see the rolling shutter artifacts but if you shake the camera back and forth like a mad man then RS is to be expected like @Geoff CB said Thanks for advice On 30/06/2016 at 3:23 PM, BrorSvensson said: also have an lens with OSS helps Yes but I've heard (and seen) OSS bring unnatural movement... Link to comment Share on other sites More sharing options...
independent Posted July 1, 2016 Share Posted July 1, 2016 You really need to stabilize this camera. Tightly control its movement, or limit it to slow, deliberate moves. Perhaps ironically, I think it's a terrible run and gun camera, despite its small size, for those reasons. I'd put it on sticks, even. I'd focus on framing and composition to help tell the story, like "Ida." Geoff CB 1 Link to comment Share on other sites More sharing options...
Escapist Posted July 3, 2016 Share Posted July 3, 2016 Here's something I filmed with the A6300 and the 16-50mm kit lens: Link to comment Share on other sites More sharing options...
JurijTurnsek Posted July 3, 2016 Share Posted July 3, 2016 If a steady 4K shot is a priority, go with Panasonic GX85. Link to comment Share on other sites More sharing options...
