SD-Card Benchmark (with Samsung tool in DEV mode)
derderimmermuedeist
  • 1 month later...
  • 7 months later...
Just got the card and tested it. I am comparing it to my Lexar 1000x 64GB card which struggles with higher bit rate stuff it seems.
First the Lexar: 52053KB/s write, 86406KB/s read
Now the Delkin card: 64990KB/s write, 89404KB/s read
I have yet to try it out other than these tests, will let you know how it works. I was hoping it would be faster than the Lexar 2000x though which it does not seem to be.
It seems 100% stable at 180Mbps with AF on. Seems 90% stable at 200Mbps with AF on (first try results in stopping due to card too slow error, then try it again and it stays running for several minutes, then I ended the test). Not stable at 220Mbps with AF on or off.
Samsung NX1:
   1.   68.374 KB/s  Lexar Professional 2000x SDXC  64GB UHS-II U3 /Class 10 [300 MB/s]
   2.   64.990 KB/s  Delkin Devices CINEMA:   SDXC  64GB UHS-II U3 /V90
   3.   60.000 KB/s  Transcend Ultimate           SDXC  64GB UHS-II U3 /Class 10 [180 MB/s]*
   4.   50.740 KB/s  SanDisk Extreme Pro        SDHC    8GB UHS-I       /Class 10 [  90 MB/s]
   5.   53.710 KB/s  SanDisk Extreme Pro        SDXC  64GB UHS-I       /Class 10 [  90 MB/s]
   6.   52.053 KB/s  Lexar Professional 1000x SDXC  64GB UHS-II U3 /Class 10 [150 MB/s]
   7.   44.328 KB/s  Samsung Pro                    SDXC   64GB UHS-I
   8.   37.873 KB/s  Transcend                         SDXC   64GB UHS-I U3
   9.   37.347 KB/s  SanDisk                            SDHC     8GB UHS-I
 10.   36.186 KB/s  Samsung Pro          microSDHC   16GB UHS-I       /Class 10
 11.   35.106 KB/s  Transcend                         SDXC   64GB UHS-I U3 /Class 10
 12.   34.880 KB/s  Lexar Professional 400x  SDXC 128GB UHS-I       /Class 10
 13.   33.727 KB/s  Intenso Professional        SDXC   64GB UHS-I       /Class 10
 14.   32.615 KB/s  Kingston                           SDXC 128GB UHS-I U3 /Class 10
 15.   29.183 KB/s  Lexar Professional 400x  SDXC   64GB UHS-I       /Class 10
 16.   29.078 KB/s  Samsung Pro MB-SGCGB SDXC  64GB UHS-I       /Class 10
 17.   18.217 KB/s  Transcend                         SDHC  32GB                 /Class 10
 18.   16.616 KB/s  ADATA                               SDHC  32GB                 /Class 06
 19.   12.772 KB/s  SanDisk Ultra          microSDHC  16GB                 /Class 10
 20.     3.735 KB/s  Transcend                         SDHC    4GB                 /Class 04
 21.   ??.???
* Camera freezes after each test
Thank you, mnewxcv.
5 hours ago, derderimmermuedeist said:
Samsung NX1:
 21.   ??.???
Thank you, mnewxcv.
is there a reason #4 is slower than 5 and 6 but ranked higher?
Samsung NX1:
   4.   53.710 KB/s  SanDisk Extreme Pro        SDXC  64GB UHS-I       /Class 10 [  90 MB/s]
   5.   52.053 KB/s  Lexar Professional 1000x SDXC  64GB UHS-II U3 /Class 10 [150 MB/s]
   6.   50.740 KB/s  SanDisk Extreme Pro        SDHC    8GB UHS-I       /Class 10 [  90 MB/s]
 21.   ??.???
  • 10 months later...
sandisk ultra 32GB micro SD sdhc class 10: 14955KB/s write, 68434KB/s read
Lexar 64GB Platinum II SDXC 200x U1 class 10: 19853KB/s write, 44119KB/s read
Delkin Devices 64GB SDXC SD 1900X u3 UHSI/UHSII "read 285MB/s write 100MB/s": 45416KB/s write, 88790KB/s read
Samsung EVO 32GB micro SD sdhc u1: 27973KB/s write, 68691KB/s read
PNY "high performance" 32GB micro SD sdhc u3: 38534KB/s write, 68730MB/s read
