OndÅ™ej NevÄ›lÃk Posted March 23, 2016 Share Posted March 23, 2016 I've recently bought the Sony PCM-M10 as an external recorder to accompany my Sony a6000 camera as it doesn't have any external microphone input. While I really like the sound of the build-in mics on the PCM-M10 I decided to buy a shotgun mic. After listening to the comparison here: http://www.newmediascholar.net/tester/ I decided to go with the Rode NTG-2. I bought a second hand one and couldn't try it out as it was from a guy from different part of the country. Now I am quite disappointed. To get any usable sound with the Rode NTG-2 (with a fresh battery) plugged into the PCM-M10 via XLR-3.5mm jack cable I have to use the 'High Mic Sensitivity' on the recorder a then it is significantly noisier then the PCM-M10's built-in mics. Also (the hiss aside) it sounds muffled and overall much worse than the standalone PCM-M10. Am I doing something wrong? Or is it just not a suitable mic for the PCM-M-10? What would you recommend? Quote Link to comment Share on other sites More sharing options...
Zach Ashcraft Posted March 23, 2016 Share Posted March 23, 2016 You need a recorder with built in XLR Jacks and 48 Volt Phantom Power. The PCM-M10 only has "plug-in power" for small mics with a 1/8 inch jack like the rode videomic. I know the NTG2 has a battery option, but the PCM-M10's preamps are likely not sensitive enough to drive the NTG2. You'll want to look at something like the Zoom H5 or Zoom H4n. Quote Link to comment Share on other sites More sharing options...
IronFilm Posted March 24, 2016 Share Posted March 24, 2016 NTG2 is not a hot mic, it is too weak for instance to make a good pairing with the Zoom H4n because the Zoom has absolutely awful awful pre amps. I'd suggest instead getting the Tascam DR-60D mk2. Quote Link to comment Share on other sites More sharing options...
