Price drop - Sony F35 and more
Ed_David
If you like the F35 - now's your chance to get one for cheap!
plus other older cameras that give interesting organic looks!
I'm ed.david@gmail.com
I'm in brooklyn, ny
CAMERAS
Sony F35 wiih IF interface box, top handle, PL mount. 444, 12 bit rgb, ccd - I enjoyed this camera very much, but need the money. $5000
Panasonic SDX900 - 24p, interesting organic feel when blown up to hd - can record stream out to odyssey or etc - $300
Canon YJ19x9B4 KRS SX12 2/3" IF 19x Broadcast Lens (657) - $400
leica r 100mm macro lens - iris has been hit - opens but difficulty - focus works okay - you can check it out -optics are in good condition - hence low price for this lens - $1200
Panasonic AG-DVX100B Digital Camcorder, internal microphone missing- $300, with battery and charger
leica r 19mm - has some dust inside the glass, you again can take a look and make sure it works okay for your needs - $600
Letus AnamorphX Adapter - $1700
CODE: LT-ANX
Options: Lens Coating: High Flare (Single Coated 2) , Include a Matte Box: No , Include a Top Flag: No , Include Side Flags: No , Include a QuickSnap Lens Support: Yes (+$99.00) , Include a Snap-on Filter Tray: No , Lens Adapter Ring: 114mm clamp (native) , Additional Lens Adapter Ring: 95mm clamping spacer (+$59.00)
Letus AnamorphX Matte Box Adapter Ring Options: Ring Size: 77mm Threaded Ring
Used only twice - works perfectly.
Still Lenses
3. Sony 28-70m - lens e mount - works with a7s for underwater housing kits - $200
5. Nikon Nikkor 70-200 f/2.8 - $900
6, Tokina AT-X PRO 116 11-16 mm F/2.8 DX AF Lens For Nikon - $300
CAMERA Support
Manfrotto 509HD Video Head w/ 545BK Tripod Legs, Mid-spreader & Bag - $750
Aluminum Tripod 150mm with Spreaders - $600
Manfrotto 529 Hi-Hat with 100mm bowl - $130
underwater housing for sony a7s - cam dive 140ft - works with 24-70mm sony lens (lens not included)!! $200- does not with with sony a7s ii
AJA 3G HD-SDI MULTIPLEXER $300.00
AJA LUT box - $600
Marshall 7' HDSDI V-LCD-70XP-3GSDI - HD-SDI - $350
GeChic 1502i 15.6" 1080p IPS Portable Touchscreen Monitor with HDMI, VGA Inputs - $350. Great second monitor for a laptop or nice huge HDMI monitor in the field
FILTERS
Black pro mist 1/4
Smoque 2
Classic soft 1/4
Polarizer
True polarizer
Nd 1.2
Cavision nd .3
Nd .6 grad
T1 ir
85
85b
RECORDERS and monitors
1. Sound Devices PIX 240 with 2 drive caddies — Comes with 2 ssd cards. Sony l batt and charger. 2 p tap cables 1 USB 3 cable - $900
2. Atomos Samurai Recorder - Very light cosmetic wear screen is in great shape with only two hairline scratches that are pretty invisible unless really looking. Couldn't get them to show up in photo. Comes with a Sony l batt with charger p tap adapter, AC adapter, 3 mini sdi cables. 1 extra long thin sdi cable. 2 120 gb ssds in caddies. - $300
LIGHTING
chimera birdcage later - $200
Litepanels 1x1 tungsten great cosmetic condition. With AC power and mounting plate for battery power. $200
2 x Lowel Rifa exchange 55 LC-55EX- $200 each
rifa light 44 - (250watts) - $100
Chimera Extra Small Video ProPlus - $200
Combo Stand Ultra Low Boy - $200 each
Combo Stand Low Boy - $200 each
CASE
2. 8-hole hard case for pl glass - $300
