johnnyLuddite Posted May 17, 2013 Share Posted May 17, 2013 Late to the party, and thanks for the great info, a big timesaver and will be well-read methinks. To add some info, I've been testing the rx100 on a cheap steadycam gimbal unit (Hague MMC) which I love for the fluid movement and ability to get people very naturally (over a tripod). I've found that keeping Active steadyshot on (rather than turning steadyshot off) to produce the best effects, although this is a compromise. With the Active mode and shutter speed at 1/50th (PAL) when you're panning, the motion is OK (which is where the steadyshot is usually nasty), and when not panning, the presence of the steadyshot gives that little extra stability. I'm also using the magfilter (works well) to add a variable ND filter which enables 1/50 shutter at f1.8 in daylight, which allows some depth of field when shooting yourself or close subjects. I keep the focus on AF-S because I've found that the face-focussing works very reliably in this mode if you give it a few seconds to settle down, including self-filming. The framing can be learned if you keep it wide open. Now the tricky bit! Has anyone tried matching cams with the rx100? I particularly want to set up some profiles which will work with the lovely Canon HV20. The gap between the cine mode (or even Tv mode) of the HV20 an the Portrait -3 -2 -3 setting in the Rx100 is quite big. The Rx100 is still quite contrasty and intense, but does the skin tones well, to my eye. Whereas the HV20 is sometimes billious on the skin tones. So, the question, if anyone can oblige - I'm no pro and skint - what's the best procedure for using various white balance, color correction, gamma, contrast etc. to align the footage to a reasonable extent, between the rx100 and Hv20 or similar? My NLE is vegas pro if that helps.... Link to comment Share on other sites More sharing options...
/p/ Posted May 22, 2013 Share Posted May 22, 2013 Is any of this stuff relevant to other Sony cameras? (alpha and NEX) Link to comment Share on other sites More sharing options...
mschaa Posted May 29, 2013 Share Posted May 29, 2013 Thank you Bruno. Big timesaver ... and good results. I am still searching for settings to match GH3 and RX100...(and GoPro 3 Black with Cineform). Not that easy for me... Regards Michael Link to comment Share on other sites More sharing options...
Bruno Posted May 29, 2013 Author Share Posted May 29, 2013 Is any of this stuff relevant to other Sony cameras? (alpha and NEX) I don't own any of those, but I would assume a lot of it is, since they use the same codecs, stabilizing options, etc. Link to comment Share on other sites More sharing options...
Clermond Posted July 20, 2013 Share Posted July 20, 2013 new to this forum and very late for the party.. shame on me I own this little beast for month but just found now the time to concern myself with video mode. I was really shocked when I tried the recommended settings and ended in interlace trouble. After some test I found that shooting 50p converting with clipwrap and throwing all in a 25p FCP X project makes no visual difference to a 50i clip converted by ClipWrap (looks still interlaced!) in the same 25p project. No visual difference either after export. For myself I switched back to 50p that gives me the chance of real slo mo too Link to comment Share on other sites More sharing options...
Bruno Posted July 21, 2013 Author Share Posted July 21, 2013 Be careful, keep in mind that 50i is actually 25p in an interlaced wrapper, but you can deinterlace it easily and get perfect 25p. So you have 50p at 28mbps vs 25p at 24Mbps. Shooting 25p (50i) will give you the highest bit rate per frame. Also, shooting 50p so you can have slow motion in case you need it later is not that simple. Your shutter speed should be set differently depending on whether you're shooting for 25p or 50p, so you might be shooting yourself in the foot! Link to comment Share on other sites More sharing options...
amadeus67 Posted July 21, 2013 Share Posted July 21, 2013 Hi Bruno, I am very late to this thread. But what you say makes perfect sense to me. Can you just say, what kind of tool you use to deinterlace the 50i video. I am not an expert, so I would like to know what you are using. I am working with vegas video 10. Thanks in advance amadeus67 Link to comment Share on other sites More sharing options...
Bruno Posted July 22, 2013 Author Share Posted July 22, 2013 Not sure about Vegas, I think Final Cut Pro X deinterlaces it automatically as you import it, other packages should have a way to interpret interlaced footage upon import, or a simple deinterlace filter. Link to comment Share on other sites More sharing options...
CoolColJ Posted July 23, 2013 Share Posted July 23, 2013 Vegas should do it automaticly, providing you set the options for it properly in project properties wondow, and right clicking on the video file in the time line and see the settings there Link to comment Share on other sites More sharing options...
ride_on_the_rhythm Posted September 19, 2013 Share Posted September 19, 2013 Great read. This post has been a valuable resource not just for me, but likely many other RX100 users. I wanted to offer some experience and tips that will hopefully help guide others, especially with LUTs and color grading. I am by no means a pro. I like to make creative use of my skills to in essence "pimp" out my home movies, using cinematic principles. It's a hobby, nothing more. I have done a few weddings and bridal showers etc. for friends. I have been using Sony Vegas for many years. When HD first came out on a consumer level, I got the Canon Vixia HF10. When the RX100 came along, I jumped on the opportunity to have a portable device for better video abilities. I absolutely realize that the quality of high-end DSLR and pro video equipment is more or less superior to the RX100, but that doesn't mean we can't play around with RX and do some similar stuff on a diluted level. I've had the RX100 since February, and recently sold it for the M2 because I wanted native 24p. No matter how much you conform or overcrank, true 24p just looks better. I haven't been disappointed. Even in low light indoors like at a restaurant, the noise is quite bearable, in fact it looks very much like film grain. Other than that, I haven't noticed anything different video-wise between the 100 and 100M2. I recently started playing around with Davinci Resolve Lite and it is a pleasure to work with. Once you get the hang of it, color correction is a breeze. My workflow is this, on a Windows PC, using footage shot at 60i from the RX100: Import clips into Vegas Pro, set deinterlace to blend --> Do basic cutting and moving of clips --> Batch render the clips as Sony MXF 50Mbit files @ 29.97p along with an .xml --> import the mxf clips and .xml to conform the timeline in Resolve --> color correct as needed --> export clips as Sony MXF --> import back into Vegas, add effects, text, music, blends, etc --> render to completion (I like mp4 @ high bitrate). It seems tedious but in reality Resolve renders much faster than Vegas even with lots of color correction so I'm happy. The conversions from AVCHD to MXF is also very fast, not much transcoding involved and since it is being done at such a high bitrate I don't notice any degradation. LUTs Pro cameras that shoot in RAW are easier to color grade because video is not so compressed and has a higher bitrate. There are many LUTs available for film emulation and other looks. I decided to try and duplicate a flat Cinestyle-like profile for RX100 footage which might be able to have LUTs applied with decent results. Straight out of the camera I've been using pretty much the same recommended settings that everyone else seems to like: Portrait Mode with DRO2 and sat, contrast and sharpness dialed down. The one part I question is whether or not reducing sharpness is a good thing. Most LUTs seem to need log video, but the RX100 by all accounts is in rec.709. I found a LUT that can convert non-log into log. When applied as the first node in Resolve, it flattens the image even more, approaching something very close to "Cinestyle" and other pro cameras. Then as a secondary LUT, you can apply almost anything else and the results are very impressive, all things considered. This gives the footage a very cinematic look. For example, the modern "orange-teal" film look can be achieved with just a few clicks without masking skin tones and applying different layers for mids and highs. Often some basic work with lift and gain in the original is all that is needed to get a great look. I don't want to link the sources for these various LUTs because this is not a sales pitch, but a little googling can get you there. Bottom line, this camera is lots of fun to use because it is so easy to take around. I don't care that the zoom is slow, because who zooms during video clips anyway? DOF is very nice at the wide end. I simply compose most video @ 1.8 so it always looks pretty nice. I use Reelsmart Motion Blur rather than carry around an ND filter in bright light. I also tend to underexpose images because they are easy to correct in post. That is all for now. Hope this can be of help to others. Link to comment Share on other sites More sharing options...
jgharding Posted September 20, 2013 Share Posted September 20, 2013 Just as a note, I regret selling it. I wasn't particularly enamoured of the video image or the slow lens, but the convenience and the stabilisation.... top notch. May have to re-buy... Get the pal version though. Link to comment Share on other sites More sharing options...
332 Posted September 21, 2013 Share Posted September 21, 2013 Anyone got problems with oversaturation in videomode with the RX100 II? In contrast to stills, all video modes appear to create a colour oversaturation which I don´t have with my other Cyber Shot cameras! I only use the PS 50p mode. Link to comment Share on other sites More sharing options...
ride_on_the_rhythm Posted September 21, 2013 Share Posted September 21, 2013 Anyone got problems with oversaturation in videomode with the RX100 II? In contrast to stills, all video modes appear to create a colour oversaturation which I don´t have with my other Cyber Shot cameras! I only use the PS 50p mode. I haven't experienced that at all, even when I leave the color settings at 0. Sounds like something you need to look into, or there could be a defect of some sort. Link to comment Share on other sites More sharing options...
kif Posted February 14, 2021 Share Posted February 14, 2021 thanks for your post. is that a mk1? im thinking of getting a mk1 as long as it shoots video in flat picture profile. iv also got the tiny dscrx0 mk1 which shoots in 'flat' but not if you want to have the thing in focus?? you have to choose.. yes, choose your picture profile, or get to use the AF .. Link to comment Share on other sites More sharing options...
