NX1 in UHD 23.98
Hanriverprod
I'm shooting UHD 23.98 on the NX1 and when I'm importing it into Premiere Pro I'm seeing some strange behavior. Premiere in the source window recognizes it as 23.98 in the 'frame rate' column but in the column for 'media end' there is up to 29 frames (00;00;20;29), so when I play the clips in the source monitor, it skips every fifth frame. When I create a sequence with the clip settings, it creates it with a 10 fps timebase for some reason.
When I import footage shot in 24fps or 30fps, Premiere seems to interpret it fine.
I know there is no timecode being recorded internally (I'm using a new sandisk extreme pro uhs-I 95MB/s), but I would like to work on this project in 23.98. If this is only possible with an external recorder like Shogun then why are these dropped frame rates available in the menu? The what is the camera recording differently between 23.98 and 24?
I'm concerned that if I create a custom sequence with 23.976 as the timebase, Premiere will alter the footage by dropping frames.
Does anyone have any experience or knowledge with this issue between NX1 and Premiere Pro? Thanks!
In case anyone else is working with projects syncing sound with 23.98, I spoke with Adobe tech and they said this was a bug that will be addressed in the next update. To view this footage correctly in the project window and source monitor, modify the clips in timecode tab under Time Display Format to 23.976 fps Timecode.
