AaronChicago Posted April 24, 2016 Share Posted April 24, 2016 25 minutes ago, JazzBox said: Thank you very much Aaron! I'll try my best to shot in the right way: honestly my only experience with log was with Pocket and I had great results, but GH4 is so simple to use (and V-Log in external is just amazing to not use it!!) Just another question, excuse me if I bother you: do you think it could work in the same video using both V-Log in external and "Natural" indoor (of course with color grading)? All the best and thank you again! Yeah I believe so. Skintones look better in V Log, and are hard to match perfectly, but everything else should be pretty easy to match color-wise. Link to comment Share on other sites More sharing options...
TheRenaissanceMan Posted April 24, 2016 Share Posted April 24, 2016 The common wisdom is that LOG profiles are best for well-lit situations with lots of DR, and punchier picture profiles work better in low light where you have less room to push without boosting noise. Blue Fox 1 Link to comment Share on other sites More sharing options...
Xavier Plagaro Mussard Posted May 1, 2016 Author Share Posted May 1, 2016 From the GH-4R specs: "4:2:2 8-bit / 4:2:2 10-bit (When 4:2:2 10-bit mode is selected, it is not possible to record motion picture or still picture on the SD memory card in the camera unit.)/Auto / C4K / 4K / 1080p/Information display ON/OFF (selectable)/Automatic down-conversion (4K --> 1080p only)" So paired with a BM VA 7" it should work?? 4K 4:2:2 10bit?? Link to comment Share on other sites More sharing options...
Phil A Posted May 2, 2016 Share Posted May 2, 2016 12 hours ago, Xavier Plágaro Mussard said: From the GH-4R specs: "4:2:2 8-bit / 4:2:2 10-bit (When 4:2:2 10-bit mode is selected, it is not possible to record motion picture or still picture on the SD memory card in the camera unit.)/Auto / C4K / 4K / 1080p/Information display ON/OFF (selectable)/Automatic down-conversion (4K --> 1080p only)" So paired with a BM VA 7" it should work?? 4K 4:2:2 10bit?? Sure. HDMI out is 10bit 4:2:2 and, at least when well lit, the VLOG-L stuff I've seen looked like it has great basis for colors. I'm still baffled that no competitor jumps on that opportunity, the GH4 is still your only hybrid cam with 10bit out and that after such a long time in the market. Xavier Plagaro Mussard 1 Link to comment Share on other sites More sharing options...
Xavier Plagaro Mussard Posted May 2, 2016 Author Share Posted May 2, 2016 This weekend I followed a two-day course on Resolve. When you work with RAW or good ProRes files, you can't appreciate h264 the same! ;-) j_one and TheRenaissanceMan 2 Link to comment Share on other sites More sharing options...
TheRenaissanceMan Posted May 2, 2016 Share Posted May 2, 2016 5 hours ago, Xavier Plágaro Mussard said: This weekend I followed a two-day course on Resolve. When you work with RAW or good ProRes files, you can't appreciate h264 the same! ;-) Totally agreed...it's like night and day. Link to comment Share on other sites More sharing options...
