Arri Zeiss Super 16mm lenses V Zeiss CP2's
markm
Are Arri Zeiss super 16mm lens set IE 9.5/12/16/25mm better with a super 16mm sensor than a set of Zeiss CP2's
After reading the thread below I believe they must be as the CP2's were designed for a full frame size for a start.
http://www.cinematography.net/edited...16mmvs35mm.htm
Also another review tells how the CP2's can flare quite a bit and you have to stop down at an often limited ability for bokeh to avoid softness.
Has anyone done any real world tests or have knowledge?
