Parker Posted May 24, 2016 Share Posted May 24, 2016 @sanveer Here's a link to the one I ordered, I got it from ZenPro: http://www.zenproaudio.com/triton-audio-fethead It works perfectly with the NTG2, I've also played around with boosting other common mics such as a shure sm57, works great for that too. I went with this one because the other model you mentioned, (FetHead Phantom) is the one that I heard doesn't work right with the NTG2's battery, plus you sacrifice quite a bit of gain. The one I got, which takes phantom power from the recorder to power itself (thus leaving the mic boosted but needing to run off it's own AA for power) gives a clean 27 db boost! The phantom one passes the phantom on through to the mic to power both, but supposedly has problems with the NTG2 and is reduced to an 18db boost instead of 27. So my recording setup is the NTG-2+FetHead (it's so tiny, just goes right into the back of the mic, only adds an inch or two) but I run it into my Tascam DR-40, on a rode micro boompole with a rode ws-6 windscreen. Admittedly I'm really not much of an audiophile, but for me it sounds great, even indoors. I use it for interviews a lot, just throw the boom on a C-stand above the talent, and it sounds way better than my lavalier setup. Much richer audio. The DR-40 has super handy dual-track recording also, so you can set one a bit higher and one a bit lower and not worry too much if audio happens to peak. It's definitely a 'poor man's setup' but like I said it really satisfies just about all of my audio needs for whatever I'm shooting. JazzBox 1 Link to comment Share on other sites More sharing options...
JazzBox Posted May 24, 2016 Author Share Posted May 24, 2016 Anyone used the NTG4 or NTG4+? Are they "hotter" then NTG2? Link to comment Share on other sites More sharing options...
sanveer Posted May 24, 2016 Share Posted May 24, 2016 5 hours ago, Parker said: @sanveer Here's a link to the one I ordered, I got it from ZenPro: http://www.zenproaudio.com/triton-audio-fethead It works perfectly with the NTG2, I've also played around with boosting other common mics such as a shure sm57, works great for that too. I went with this one because the other model you mentioned, (FetHead Phantom) is the one that I heard doesn't work right with the NTG2's battery, plus you sacrifice quite a bit of gain. The one I got, which takes phantom power from the recorder to power itself (thus leaving the mic boosted but needing to run off it's own AA for power) gives a clean 27 db boost! The phantom one passes the phantom on through to the mic to power both, but supposedly has problems with the NTG2 and is reduced to an 18db boost instead of 27. So my recording setup is the NTG-2+FetHead (it's so tiny, just goes right into the back of the mic, only adds an inch or two) but I run it into my Tascam DR-40, on a rode micro boompole with a rode ws-6 windscreen. Admittedly I'm really not much of an audiophile, but for me it sounds great, even indoors. I use it for interviews a lot, just throw the boom on a C-stand above the talent, and it sounds way better than my lavalier setup. Much richer audio. The DR-40 has super handy dual-track recording also, so you can set one a bit higher and one a bit lower and not worry too much if audio happens to peak. It's definitely a 'poor man's setup' but like I said it really satisfies just about all of my audio needs for whatever I'm shooting. Thanks for the reply Parker. I like smart people use their research skills to outdo gear limitations. Link to comment Share on other sites More sharing options...
JazzBox Posted August 16, 2016 Author Share Posted August 16, 2016 At the end I've bought a Sennheiser MKE 600, I like it very much. The windscreen foam is quite goot to fight the wind and I'm thinking to buy the Rode Blimp MkII Link to comment Share on other sites More sharing options...
IronFilm Posted August 17, 2016 Share Posted August 17, 2016 On 5/23/2016 at 8:34 PM, JazzBox said: Thank you very much! Maybe the best bet would be Rode NTG3 (or NTG4+ http://www.thomann.de/it/rode_ntg4_2.htm) for outdoor and an Hyper for indoor NTG4+ and NTG3 are quite a different class to each other, NTG3 is the better one of the two. Link to comment Share on other sites More sharing options...
Michael Coffee Posted August 17, 2016 Share Posted August 17, 2016 Hi, regarding Rode mics, letting everyone know I just had a really great customer service experience with Rode.. possibly the best customer service experience I have ever had! IronFilm 1 Link to comment Share on other sites More sharing options...
