Ed Andrews Posted May 19, 2016 Share Posted May 19, 2016 It looks like I need to get myself a matte box to go with a BMMCC and an monster Angenieux 15-150mm f1.9. Anybody got some recommendations as to a good, reliable set up? I'm willing to sink a bit of money into it as a long term, adaptable set up so not necessarily a budget option. Also, advantages of getting 4 x 5.65 over a 4x4? The diameter of the lens is 110mm so 4 x 4 could just squeeze in. Any any thoughts of advantages of 19mm over 15mm rods? Just can take a greater load out? Any pointers would be really appreciated. Cheers. Link to comment Share on other sites More sharing options...
AaronChicago Posted May 19, 2016 Share Posted May 19, 2016 Bright Tangerine. If money isn't an issue. I've used their normal rail matteboxes, and just got the Misfit Atom for Xeen lenses. Very well made. Ed Andrews and Zach Goodwin 2 Link to comment Share on other sites More sharing options...
M Carter Posted May 19, 2016 Share Posted May 19, 2016 I bought an "indian" one when DSLRs started really taking off, figured I'd eventually replace it. Still use it every week though, guess I got lucky -it was like $250. Look for: At least two stages & at least one rotates; Height adjustable; Detachable flags that don't have gaps between the flags and the main hood assembly - and hopefully the front flag stays put when used without the side flags; A swing-away front is really handy; If you use different sized lenses (DSLR style shooting), I found it's easier to just get screw-on rubber lens hoods to seal the lenses against the matte box opening vs. nun's knickers or swapping out foam donuts. If you use cinema lenses it's not such an issue. (You usually need something though - the first time you get back to your NLE and see the reflections of focus gears in your ND - yeah, that bites!) IronFilm and Ed Andrews 2 Link to comment Share on other sites More sharing options...
Chris Bernard Posted May 26, 2016 Share Posted May 26, 2016 Ed, if you are in London I'd check out Shoot35. Very decent Mattebox for the money. I had their original one and a smaller one they sadly don't make any more. Bright Tangerine looks like the one to beat today. If I could do it over I'd get a box that supports 4 x 5.65. I've found it really hard to find the 4 x 4 filters I'd like to use in the used market. Some filters like the Tiffen Indie IR ND line only seem to be available in the 4 x 5.65 range. https://www.shoot35.com/ Ed Andrews 1 Link to comment Share on other sites More sharing options...
Ed Andrews Posted May 26, 2016 Author Share Posted May 26, 2016 Nice one, thanks Chris! I ended up getting a second hand ex-rental Chrosziel one from AimImage for about £400. Could be worth checking out if you are looking for odds and ends of kit. http://www.aimimage.com/category/kit-for-sale/ Shoot35 looks great though. I need a rig so investigating now Link to comment Share on other sites More sharing options...
