ntblowz Posted May 24, 2016 Share Posted May 24, 2016 https://www.youtube.com/watch?v=Dt-GX5BdcgU I tried on my G7 and it works! though if you change back you lost all the setting Adept and Cinegain 2 Link to comment Share on other sites More sharing options...
Inazuma Posted May 24, 2016 Share Posted May 24, 2016 Ok so it worked on my GX80 (using play button instead of display) but I have so far been unable to reverse it! EDIT: Ok, 15 minutes later I worked it out. Make sure the camera is in P mode when you power it on. Then follow the guy's instructions but make sure to press the display button on the selection screen that appears so that "[STRICT]" disappears. Anyways this is pretty big news. Surprised it's only just been discovered! sgreszcz, Alborat and Adept 3 Link to comment Share on other sites More sharing options...
IronFilm Posted July 25, 2016 Share Posted July 25, 2016 Surprised this is not mentioned more often, this is big news I reckon! Does the new firmware updates for the G7/GX80/etc disable this by any chance??? I hope not!! Link to comment Share on other sites More sharing options...
tdonovic Posted July 26, 2016 Share Posted July 26, 2016 I live in Australia. What issues will I have if I run in NTSC in a PAL country? Link to comment Share on other sites More sharing options...
itsjustrobbieok Posted July 26, 2016 Share Posted July 26, 2016 Does 24p still work? Link to comment Share on other sites More sharing options...
IronFilm Posted July 26, 2016 Share Posted July 26, 2016 It should, both PAL and NTSC cameras have 24p Link to comment Share on other sites More sharing options...
tweak Posted July 26, 2016 Share Posted July 26, 2016 This has been on PV for a while. Good hack none the less. Link to comment Share on other sites More sharing options...
jbCinC_12 Posted July 27, 2016 Share Posted July 27, 2016 Would it work on a G70, and does it have to be the old firmware? Just wondering. Link to comment Share on other sites More sharing options...
Grimor Posted July 27, 2016 Share Posted July 27, 2016 Link to comment Share on other sites More sharing options...
